moreplovac
Everything posted by moreplovac
  1. Thanks GrandpaPhil, Sultana is my second build but i am contemplating to work on one more, since i have some better understanding what to look for. I purchased unopened Sultana kit on garage sale for barely any money... but let me finish this one first... Cheers
  2. Wrapped up head rail building process today... Worked on second head rail, transfered the shape from first one to the piece of wood, carved, shaped, sanded with sanding paper and files. The shape was transfered to the scrap piece of boxwood. Cut excess wood with hobby saw and removed wood with carving tools. And carving.... more carving.. checking shape to the original one... Making the grove with home made scraper... Once done with carving, painted the layer of flat black and mount on the ship.. Happy modeling..
  3. No special tools, I cut excess wood with a hobby saw and continue carving with carving knife, #11 knife, sanding paper #80, #400 and #800. The time was the most useful tool since plenty of testing, shaping, retesting has to be done. There is no clear, usable plan drawing for this item... Cheers
  4. After some time spent in bending setup, the head rails were cut, painted and glued to the ship to meet with cheeks already on the stem. To provide as smooth as possible transition between two parts i used wood filler to fill out gaps. Sanding part will come up tomorrow. Using wood filler might not be quite acceptable in ship modeling but i think that end result is more important than material used in building process. These pieces are very tiny and fragile so it would be very difficult to make them in one piece. At least for me. Now, lets see how can we build/carve the head rails. I started with laminating few left over parts, boxwood, into one piece acceptable for carving correct shape. The shape was transfered from plans, cut and glued to the wood. So lets begin carving. I must say i am beginner carver, still have challenges visualizing an end result of carving process so this was a good exercise in proper direction. Repetitio mater studiorum est.. After about two hours or carving, sanding, measuring, testing, carving, sanding, retesting.... i was able to come up with a decent result. Then using my home build scraper, i made a a groove in head rail, then shaped and cleaned it with a piece of sanding paper folding to the size that can fit in the groove. The rail edges were sanded too with 800 sanding paper. Testing on the ship... I must admit that the hardest part of this whole process was testing and retesting. The reason for this is that is extremely hard to hold a ship and carving part in correct position, and mark with pencil extra wood that has to be removed. Unfortunately, only two hands available but managed to have it done... A bit more shaping so the curve is as smooth as possible and final testing on the ship.. I am still not 100 percent happy with a groove, it appears to be a bit choppy but will try to clean it tomorrow. In the meantime i made another laminated boxwood piece that will be used for second head rail... Happy modeling..
  5. Continue working on cheeks. Started with making a piece of wood that will be used for carving out of few pieces of leftover planking boards, glued together like in few previous posts. Transfered shape and start sanding and carving.. After light layer of black paint i glued them to the ship head. Then part of the cheek that extend to the ship was carved next... This part do require a bit of a curve so quick bath in the water for a few minutes and curved for tomorrow assembly.. Happy modeling..
  6. Timberheads are completed and painted in black. Finished carving of second cheek. Both of them were painted in black and glued to the ship head. Must say that carving is time consuming process especially on these small items. Then i applied a protective layer of varnish on whole deck and all deck furniture. That was all for today, not many pictures but time well spent.. Happy modeling..
  7. Timberheads completed, just a layer of black paint is left. Usage of pins appears to be really good move. Most likely without pin, timberheads will be very fragile parts. I have left few spares (with inserted pin) just in case something gets horrible wrong.. I have made plenty of plan copies so i can cut it and trace to the timber if needed. I had to make two holes in stem (not quite sure what technical term will be for these two holes), cut and traced the shape .. .. with a needle point tool made marks on the stem and then drilled holes with 0.44mm. First with 1mm drill bit and then with 1.3mm the holes were widened. A bit of file sanding and work completed. On this picture it is better visible that length of the stem is not quite appropriate and extra patch will be needed (or planing ahead and have longer stem at the beginning). Cheek knees.. another small and tiny parts to deal with.. now, i red Chuck' practicum ahead of time. During the making process i broke three knees. Most likely the wood is either tiny or i was not following wood grain but i ended up using "laminated approach". I glued three planks (1x3mm in size) lengthwise (like this ---), then glued two planks on the top of it ( --) and two another planks on the bottom ( --) getting it all in layers. This should be strong enough to take abuse by #11 knife and other shaping tools.. Since knees will be painted in black visible layers will not be an issue.. Started to carve... Completed for today; tomorrow a bit more carving... Happy modeling.
  8. It would be much better to get them in one piece but i did not pay attention to that. Following kit plan to the letter get me to this stage and not reading Chuck' practicum ahead of building time, just added a bit of spice to it. If i would do the stem again, i will make sure i have extra length. This goes into my building notes for future references.
  9. That could be used as well... Depends on audience... If i understand your question right, the reason for two pieces in stem area is that the stem is actually shorter than needed. It is visible when you test position of bowsprit after opening for it is cut. I did not read Chuck's practicum that diligently so made the same mistake he did... Now a added small "patch" and after all other parts are in place it should be hardly visible (hopefully). Thanks for following..
  10. Timberheads are next. Those little things gave me some hard time, tiny, hard to keep between fingers but managed to get them all built. I built 30 of them, and picked 14 that happened to sticking out from crowd as best looking. I was thinking to organize a beauty pageant but was not quite sure if i would be able to come up with 14 different "i will fight for a world peace" sentences.. For building process i marked all 20 timberheads on one piece of plank, started from the top by sanding edges and with #10 knife, carved the shape and cut of the plank. Building process.. And the winners are ... Then i added a small pin to each timberhead to make sure it will stay in the place, once mounted and glued.. A small pilot hole was drilled to the bottom of each one, proxxon with .44mm widened the holes and pin glued in the place. I marked the position on the cap rail for all timberheads, drilled a pilot holes and mounted them all, well not quite all. Still 9 to go. Tomorrow. Once all are mounted a nice coat of flat black will be painted.. Happy modeling..
  11. The gunstocks are next. The rest of gunstockes were build, 10 in total. Cut them to the size as per plan; on the bottom i did a small angled cut and shaped each gunstock as per plan. Each gunstock received a small hole filled with wood filler to simulate trunnel. The hole for a swivel gun was drilled on each gunstock as well as on two already mounted on the ship. That was a scary part but managed to have it done... To drill holes i put all gunstock on the piece of scotch tape and get them all into vise. Then marked approximate center of the gunstock with pencil, drilled a small pilot hole with hand-drill and with assistance of proxxon rotary tool made first 0.5mm hole than widen it with 1.3mm bit.. All done and ready for electric tape to simulate iron band.. 1mm electric tape strip was applied to each gunstock, the drop of cyano glue added additional strength to tape. That tape is fairly stretchable and if stretched to much it will shrink afterwards leaving a gap between two strip ends. Each gunstock received a quick bath in wood stain.... and here they are, ready for assembly.... but that is something for tomorrow.. Fitting testing... Happy modeling..
  12. I dont think it is you, i believe the way i inserted picture was wrong.. It should be OK now.
  13. Not very productive afternoon; went to my post office to pick up scrapers i have ordered few days ago.. Looking forward to make some moldings... Happy modeling
  14. Following Practicum, i started adding details on cap rail area... First i cut a notch for the bowsprit with a hobby saw and using files the opening was rounded but not completely... The main tweaking will happen at the time of bowsprit installation. Despite the fact that i do follow practicum, i missed one part. The steam was to short. Good part is it is no just me. Following Chuck's suggestion i will add a piece of wood to lengthen the steam to correct dimensions. This is task for tomorrow... Now looking at the pictures it looks that notch is a bit wider that needed. Something to deal with at the time of actual bowsprit installation. Bit more work to do. As Chuck mentioned, mistakes do happen... Then i worked on hawse holes; marked, drilled and shaped with a file. Gunstocks were made next. Cut a piece of wood, a tin strip of electric tape was simulating iron band but i forgot to drill a hole on the top, for a swivel gun. It will be a bit hard to do it after but... The other gunstocks will be done with a hole before mounting. Also i simulated trunnels by drilling a small hole and fill it up with wood putty. A nice little detail. Before mounting, i dip both gunstocks into stain, leave it for 15 sec and dry it out with paper towel. The notch for gunstock was cut in the cap rail, shape corrected with a file and before mounting gunstocks, i run a layer of flat black color on cap rail area where gunstocks will be mounted. This is to prevent messing gunstocks with black color since i am planing to lay one more layer of black color to cap rail before putting a protective layer of varnish. Tomorrow few more gunstocks and will work on fixing short steam.... Happy modeling.
  15. Today i started with painting catheads in flat black and mounting them on the ship. Next part was interesting one. Molding. I never worked with molding in such a tiny scale. First making scraper that will be used to shape molding and then actually make few. Following Chuck' practicum about the shape of molding i started making a scraper. After few unsuccessful attempts, i made one out of a razor blade. Using carbon file i made a groves that will assist in scraping the correct shape. Cut few pieces of boxwood strips in 2x2mm, i started scraping the molding. Fortunately i had plenty of boxwood strips in this dimension since several attempts ended up in broken or uneven moldings... Finally get few usable moldings that will be installed on the ship. Paint them in flat black and assembled to the ship. These dudes are tiny for my over-sized fingers... But luckily there are tweezers... First i marked the locations where they will be mounted... Then after some time... The stern still requires badges to be installed; after that remainder of moldings will be glued. Bow moldings have to be bended to follow the bow shape; 10 minutes in water bath and slowly bend them over a electric tape... Making sure not to squeeze molding and damage the shape i used small clamps just to keep molding in shape.. No rush to mount then; moldings will be left overnight to dry and tomorrow a coat of flat black paint and assembly.. After mounting the moldings and doing some touch ups on the rudder i will give it a nice layer of varnish to protect the whole model. Happy modeling..
  16. Catheads are on today's menu.. this sounded very weird.. Took a measurements from the plan, and cut the basswood strips to length. Shaped them based on the plan and Chuck' practicum, made cutouts to help seat the cathead in the position on the bulwarks. The scariest part was cutting the notch in cap rail for both catheads. Three times measuring = one cut... After making the basic shape for the catheads, i drilled few holes, made a groove that will simulate sheave. I decided to use cleats from the kit. Sanded and filed them nicely as they were fairly rough out of the box. Cleats were glued to top of the catheads, and two eye bolts were also mounted to the side of catheads. I used eye bolts that were supplied with a kit. Everything will be painted in black so did not spend time blackening eye bolts. Catheads were painted in black and tomorrow will mount them permanently to the ship... Happy modeling..
  17. Finished day with binnacle lashed down to the deck on both ends, and start with a work on catheads. Happy modeling.
  18. Then i mounted all (well not quite all, pawl for windlass has to be made and assembled) deck furniture i have build so far. I put two small nails in windlass supports and marked place where windlass will sit. Then a hole was drilled for nails, carpenter' glue was used to glue it to the deck. The galley stack was next, then binnacle with two hooks mounted on the deck... Pumps and ladders... The view of the whole deck. Then i give it another layer of stain to make all furniture the same (or similar) shade as the deck is... work on traveler rod was done but it appears to me that it should be a bit shorter in overall length. I will redo it sometimes today... And through magnified glass... Here is the whole deck for now.. Happy modeling.
  19. Rudder has been installed. I decided to leave pintles and gudgeons colored in black. Some touch-ups still have to be done..
  20. Work on waterways was completed yesterday. The only building step left is to give a concave shape to installed waterways. Today. After shaping i give waterways quick dip into stain, leave stain to penetrate about 10sec and wipe it off with paper towel. The waterway at the bow was dipped into water for about 5 min and the curve was achieved by twisting it on the plastic cover. It was there until all other waterways were installed. The gained curvature was giving to waterway perfect fit at the bow. Other waterways installed.. Then i marked places for drilling the scuppers. Used one unsuccessfully shaped waterway and marked 5 dotes. Transfered it to both main deck waterways and drilled the holes. The holes were not drilled all the way thru, the drilling bit was 0.8mm. In the hull, scuppers were drilled under the angle, again not all the way thru. Holes were then shaped with a small file. The bow waterway was installed the last. And the whole assembly.. Happy modeling.
