Unit66
  1. Update: I may have ruined my airbrush by misusing AK758 Grey as it has left a fair amount of residue in the barrel so I will need to figure out how best to clean it. IPA seemed to help but we will see. I was attempting to use the primer to add in some weld lines with the help of some masking tape, however I feel like this didn't really work as the edges although crisp add little to no bumps or ridges along them. I am wondering if there is a technique or better primer to use to get the raised edges, in any case I will clean the airbrush and practice adding in rivet lines. Some sections came out ok, with a little raised edge but the majority is barely noticeable. Any tips for future attempts as this one may have failed but we will continue? Regards, Ryan
  2. I was originally planning on it, but I wasn't confident in my ability to sand down the bow and then raise the deck correctly. So I chickened out, I'll have to find a way to make smaller alterations that don't run the risk of potentially ruining the model for practising with.
  3. Good Evening, The ship has had all it's portholes drilled and I was tempted to run some fibre cables through them to add some lighting, but the hull is a little to cramped so I'll work on getting that in the next build. I dry fitting the parts and drilled in the guide holes for the pedestals, as far as mounting goes it looks messy but it'll be hidden so no matter. Some of the ladders also have no PE parts and without spares I'm going to drill in and use 0.1mm wire to add in some depth. I'm forgoing the original mount and getting a wooden plate made, courtesy of my father as he seems to have every tool in existance, I've also ordered a rivet tool to try and get the marking on the hull showing. Kind Regards, Ryan
  4. Good Evening, I've been looking for some reference pictures of this ship, but it appears that these are some what uncommon or from a distance, making them not ideal. Additionally the ship seems to have had a variety of paint schemes as the photos I did find show this, so that part of the build is up in the air at the moment. I did find a really nice diorama of Eskimo on Brit Modeller which shows a lot of detail. For now, the plan is to drill out the port holes and sand off mould lines on the hull and figure out the where to place the pedestals. Kind Regards, Ryan.
  5. Good evening, It has been a very busy period so I haven't been able to sit down and continue with Saratoga (who is now sitting on top of a display cabinet in a mess), but now that things have calmed down a bit I've decided to work on a smaller model to clear out the backlog a little faster. I picked up this kit a little while ago that came with a few extra parts from the seller, I then ordered a White Ensign PE kit and some RN crew to get some extra detail. I am planning on modelling then printing off some more detailed parts for the gun mounts and torpedo launcher, this will have to wait until I can keep the printer in a warmer area as it is currently to cold. For now I will settle on preparing the hull for mounting on a wooden base. Kind Regards, Ryan
  6. Progress Update: I have bitten the bullet and primed some of the parts now, the planes have also got their silver paint scheme until the yellow paint arrives for the upper wings. I do not really fancy trying to mask the wings for that stage so I may just hand paint them, they came out a little better than I thought they would even if I dropped and then stepped on one. Thankfully it stayed in large pieces so nothing went missing. I did try out the stick wrapped in tape to mass paint them, thank you for the idea, but I have some weak tape, fortunately the crocodile clips can just about hold onto the tail wheel bump. I will try out some other tape. I'll need to go back over the guns and life boats as I seem to have missed the parts where the clips were and thin layers in other areas. Hopefully now that the stands have arrived I can go back to the hull and give it another sanding to clear my poor attempt at gap filling. But first the planes need their decals. Kind Regards, Ryan
  7. Progress Update: All turrets are now complete and join the planes to await priming. Unfortunately it appears that by having 2 PE sets for the same ship has led to a mistake being made with the funnels; I had put them on the outside rather than the inside. After some careful prying and some help from a lighter I managed to detach the funnels and put them on the correct way. Going forward I'm going to split the PE kits and use the best elements for each, as one comes with arrestor cables to place on the deck. Kind Regards, Ryan
  8. Thank you Steve. I'll hopefully be painting them once the final few paints arrive, for now my attention is split between this and modelling an Arado 196 and turret for my next build. Kind Regards, Ryan
  9. I have seen these in the past never really knew what they were. I've got some on order now so hopefully they'll work a treat. Cheers for the recommendation. Kind Regards, Ryan
  10. Progress Update: Turret C now joins turret A in completion. Looking back on it I wish I'd got the brass barrels as the kit ones feel like they're bent, also that I didn't fat finger one of the periscopes on the turret as it is now drooping. Might add in some crew around the turret in question to make it look like it is undergoing maintenance. I was also trying out a new setting on the camera to try to make the images look a bit clearer, especially on the smaller parts although they were compressed when moving them onto the computer so may forgo this in future and stick with the phone. Kind Regards, Ryan
  11. Progress Update: Another short one. These full PE parts are very fiddly and without a suitable brace point means that aligning the parts becomes very difficult and the solution was to add super glue and accept that we can fill in any gaps later. The railings for this part I cut them into pieces for the bends to try to better align them, an idea I got from a video. Plan for tomorrow is to finish the armament so that the priming can begin on the smaller parts. Kind Regards, Ryan
  12. Progress Update: It's been a busy week so the updates have been a bit sparse; my attention is split between this and the next build that I've been planning on doing, which I am aiming to begin building probably next month once this one is complete. Today's session was spent adding the stairs on the conning tower and gluing down the structure on top with the support beams. I may regret the lower stairway as I have yet to add the PE braces to the underside of the platform above it, we will find out tomorrow. Kind regards, Ryan
  13. Good Evening Mike, It is Eduard yes, not a massive fan how they split their PE into different parts as it sometimes gets confusing. I'd love to see that Enterprise, I like the more modern air wing, especially the helldivers. I was tempted to print off some of the more modern aircraft seeing as Saratoga did get some towards the end of the war. I've seen your destroyer and really love how you've done the armour sheeting on the hull. Think I might try something similar on the carrier with some melted sprue sanded down. Regards, Ryan
  14. Progress Update: I have continued with the conning tower adding in the support beams and some of the hanging decks. I didn't realise at the time that I got one of the railings back to front so there's some minor overhang, I'm going to try to link the stairs into it to hide it. I have been spending some time looking at how different modelers address bending and placing railings to try to get better. So far it has definitely made it a little easier, right up until the piece gets fat fingered and bent. Regards, Ryan
  15. Progress Update: A bit of a short one as England is having a heat wave and building whilst overheating is not something to be enjoyed. I have moved onto the funnel spouts as well as the bridge. Both of these PE parts required parts of the original model to be removed to facilitate them which always feels uncanny. The grills on top of the spouts were a pain to bevel but I did find some success with the handle of a chisel. The PE bridge was very fiddly to try to get aligned correctly, for now it will work. Regards, Ryan
