eyfeinsod
About eyfeinsod
  • Birthday 11/08/1949
  • Gender
  • Location
    Califon NJ
385 profile views
  1. Hi, I have experience as a luthier, We use hide glue(available from Woodcraft supply). it comes in flake form dissolve in water @ 104 * F or find an new or old glue pot . all Violins etc. are glued together with hide glue very very strong but can come apart for maintenance and or repair. Many other trades used hide glue furnaturemakers etc.
  2. getting started color matching image.thumb.jpeg.380b6221c4fb48771e307c12e2746e8a.jpegimage.thumb.jpeg.fe00795d9a424350aa9c9e8db6b2b79c.jpeg
    1. eyfeinsod
      eyfeinsod
      replacing missing buildings.  Trying to keep craftsman ship in line with original and age to period image.jpeg.b410ede7b05556f1be6fdcd0ae1e0459.jpegimage.jpeg.de0eed4d5f5e0cc7dd47ebf26f6a2789.jpeg
  3. Not knowing where to start so I decided to build a rudder that was missing. I inserted a brass tube and pin to attach to the wheel post. I'll prime and paint to match paint or lack thereof on keel. Help would be greatly appreciated
  4. thanks for your rapid reply! I'm trying to learn to navigate your site. I'm not a digital/ web guy. Jewelers supply is a good lead I guess your opinion is I should try and reproduce the way the ship was originally made. All my research just shows rigging using string/rope nothing about chain. I'm comfortable with coming as close to the way it was originally built if I can. There are some major questions as I'm not a "Modeler" nor do I have plans on becoming one. I'm just a retired educator/artist/craftsman (sailor) that is constantly finding challenges I can't resist. Your and other suggestions are much appreciated!
  5. this is how I documented the removal of the masts and sails along with many photographs that have been printed and mounted in a journal
  6. what do I do next? I have carefully disassembled and documented down to the hull. I was surprised to find it still weighs 20lbs. I found out it's a poured keel and appears to be a carved hull possibly out of Basswood? I cleaned the decking with soapy water and "Q" tips about 100 "Q" tips and a toothbrush to remove 100+ years of grime and dust. after that lightly cleaning gunk with denatured alcohol got some bad spots off. Do I work on the deck Items (cabins,and hatches) first or restore and mount the masts? when working on the deck items a few were missing and some like the main one with rescue boats on top had the windows painted or on with paper decals now falling off. Question on the masts: all yardarms were hung with fine chains? along with metal casting around masts. should I be faithful to original and replace chain and where do I locate such fine chaining?
  7. Restoration scratch built Flying Cloud, This is my first clipper ship restoration . I'm not an experienced modeler. Scale ? Measurements 55 1/2" bow sprint to stern, 41 1/2 keel to top of Main mast 8" beam. original build possibly 1930"s just started taking apart and documenting one step at time. Finding things I did not expect like use of fine chain to attach yard arms to masts
