Rustyj
Posts posted by Rustyj
  1. Thanks Pete, Mark, Paddy, Martin, Bob, Ben and Grant.
    Thanks Russ, I was hoping the colors would look good and was pleased with the results.
    Thanks Chris. Sounds like a good way to do them and I’ll try it next time.
    Here they are the hatches just set in place.
    And here I have glued them in place and started the deck planking. I'm continuing to use
    Holly planks with black paper for the caulking
    I'm off to continue the planking and will use boxwood for the tree nails like on the lower deck.
  2. Well I’ve had to spend the weekend before building a deck for one daughter and t
    hen went on a little 4 day vacation and just got back. Here is an update on what I
    had done but didn’t have time to post. Also there is a whole lot posts I have to catch
    up on. Wow you all have been busy. ;)
    Thank you Shannon, the Byrnes saw makes all the difference.
    Hi Bob, I do like the color. Of course I got it from Hobby Mill.
    Hi Joe, It has been quite a while now hasn’t it? Great to hear from you.
    Hi Ben, Yes it is hard. Might even be harder then Boxwood. As I said it’s the saw.
    Now that you have one I expect you to practice and be able to do it too. :D
    Thanks Wayne.
    I’ve made the hatch grate using a technique I copied here. I’ll try to explain it in case
    others haven’t seen it.
    I used 1/8” boxwood and a saw blade that is .040” thick.
    First I used a piece of scrap basswood to make the jig, I cut a channel in the basswood
    the width of the saw blade. I then cut a strip of wood the same thickness as the blade and
    inserted it into the channel so that 1/16” showed. I then clamped it to the top of the Byrnes
    table saw making sure that the blade was the 0.40” away from the channel.
    Next using the jig I cut a series of slots in the underside of the boxwood board,
    and then sliced the board into strips on the table saw using a fine tooth blade.
    The strips were cut the same thickness as the blade. (0.40”).
    I then assembled the gratings like we do when we buy them precut.
     I hope that makes sense
  3. Thanks Russ, Joss, Grant and Pete.
    Grant. You can see the difference between the earlier picture and the close up
    of the completed one. The completed one is the color with a coat of wipe on poly
    applied. No touch up. It’s that red.
    Paddy. One thing they say is the Red Heart can fade some over time especially if
    exposed to sunlight. This is some I have had on hand for a couple of years and it
    hasn’t faded. Also I plan on keeping it out of direct sunlight once completed.
    Daniel. Nope not Blood wood but Red Heart. Blood wood is a deeper darker red. I
    have used it in the past but I didn’t have enough for this so I couldn’t use it now.
    Again thank you all! :)
  4. Hi all. Thanks for the kind words. I hope it works for you as well as it did for me.
    Here I’ve added the waterway and have started on the hatches. Both are being cut from red heart.
    Here the sides are cut to length with the bevel cut into them.
    Here they are notched for assembly.
    And here it is assembled.
    Are here they are set in place but not yet glued down.
    Next I'm going to make my first attempt at making my own hatch gratings. :wacko:
  5. Hi Ben,
    That’s great you’ll love it! The wood is swiss pear and the false keel
    is ebony. I have a little left and figured it was a good place to use it.
    After gluing the two sections together I cut out the pattern that shows the
    rabbet location, transferred it to the keel and then cut it out using a V grove chisel.
  6. Hi all and thank you for your kind words.
    Hi Daniel I used the following sizes. Ledges 1/8” x 1/8” and carlings 3/16” x 3/16”.
    Not sure if they are 100% accurate but they worked for me.
    The way I used for cutting the mortises is what worked for me. Experiment and
    see what works best for you. We all add our unique touch to how we do things.
    Well here it is with all of the carlings and ledges in place. Now to sand it all smooth
    then next up will be adding the waterways and decking.
