Posts posted by Rustyj
- gunslinger4hire, fatih79 and Ferit
- 3
- fatih79, Duanelaker, Wishmaster and 1 other
- 4
Hi Robert and thank you.
The wire I used was craft wire. It was copper wire clad with
a black covering. I believe it was around 24 gauge. I measured the shaft I
wrapped the wire around and it was .054” (a little under 1/16”) so the rings
should be pretty close to that. The size of the rings is just what I thought
looked right and not taken from any measurement. Thanks again.
- Ryland Craze, fatih79, aviaamator and 1 other
- 4
Hi All, I've been digging through my file and I'm putting to gether the pictures for my scratch build of Chucks Model Shipways Syren. The build is in the 1:64 scale. The main wood used was Boxwood, Cherry, Holly and Swiss Pear.
This log was started back in 2007 and I was bad about taking pictures but here is what I have.
- fatih79, Chuck and Ryland Craze
- 3
- Duanelaker, augie and fatih79
- 3
- CiscoH, Duanelaker, Wishmaster and 1 other
- 4
Hi Pete,
I glue them in place and then cut the notches. It will be harder to do it this way
but for me I feel I can get a better fit in the end.
Very well done Mario. It's a great reference for the rest of us. Thanks.
- Duanelaker, fatih79 and Wishmaster
- 3
- 3
Hey it's no problem Ben. Love the talk. Yves having been one of the lucky ones I understand your wishes.
- fatih79, Chuck, Wishmaster and 4 others
- 7
- fatih79, Wishmaster and Saburo
- 3
Well done Augie, I know what a bugger they can be and you nailed it!
Hi Neill,
IMHO the accessories you will need the most are the Extended Rip Fence, Miter
Extension and Zero-Clearance Inserts. How many inserts depends on how many types
of blades you will be using. I have one insert for each type. Other accessories
are nice but these are the ones I use the most.I hope this helps.
- Duanelaker, fatih79 and Saburo
- 3
Hi Ben,
I have to give you a big “ummmm not sure why”. I would guess it was because
I was thinking lets plank the interior before putting the window frames is so I
don’t put a plank through them or just cause I wanted to do the planking then
and not later. What ever reason it was it was not really important.
Just me being me as they say.
- fatih79, Saburo, Duanelaker and 2 others
- 5
Hi 42rocker,
Lucky for me I had already gotten well underway with the Triton Cross Section
before finding the Bomb Vessel plans on MSB or I too may have wandered
the path you are about to take.
Good luck and it will be fun and interesting watching this build.
US Brig Syren by Rustyj - FINISHED - 1:64
in - Build logs for subjects built 1801 - 1850
Cutting the copper tape to make plates and coppering the hull.
