Everything posted by Herby63
Hi Jölle, I'll try to make the build log as interesting as the model
- 156 replies
- Mikasa
- Merit International
Next is collecting all the brass parts to make the 3" huns and the 47 mm guns, which replace the Merit parts entirely. Lots of modellingfun
- 156 replies
- Mikasa
The 6" guns in Merit step 3 are entirely replaced by Pontos brass. They are soldered together, no glue used at all. Happy modelling,
- 156 replies
- Mikasa
Before putting on lots of photo-etch around the casemates, I want to be sure the guns and the hatches around them will fit. So I started the construction of the guns. I started collecting, preparing an assembling the parts for step 2: the 6" guns. The different stages of completion, seen from left to right. The completed guns. Happy modelling,
- 156 replies
- Mikasa
I glued on more than a hundred "ordinary" pontos portholes using PVA-glue. Then I indicated on the Merit-instructions where Pontos brass replaces partially or entirely the original kitparts, and on the Pontos-instructions in which step of the Merit-instructions they are needed. Happy modelling,
- 156 replies
- Mikasa
I put the propellershaft and their struts together. Next I adapted them to receive the Pontos propellers and mounted them on the hull. I also worked a bit on a propellerblade to see if I could ameliorate it. Both shafts adapted and mounted on the hull with Tamiya extra thin cemlent. Happy modelling,
- 156 replies
- Mikasa
In order not to damage the portholes I first placed the bilgekeels, taping them down and gluing with extra thin cement. After removing the tape I glued the remaining places. Happy modelling,
- 156 replies
- Mikasa
I put on the porthole etch with the bars ar the stem, before and under the achorplates, and at the back, o,ly the last 3 portholes on the bottom row. I aplied slightly dekuted PVA-glue around the hole in the hull with a toothpick, then positioned the photo etch over the hole and with a pointy tool I adjusted the position of it. Any excess glue was removed with a damp brush, but I hardly ever had to do so. Wishing everyone lots of modellingfun,
- 156 replies
- Mikasa
- 156 replies
- Mikasa
Hi Yves, I will certainly paint the entire ship, as it is hard to keep the shine over the years. I am tempted by the early colorsceme of black and white, in order not to fill my livingroom entirely with grey ships.
- 156 replies
- Mikasa
Thanks Chris, I have seen lots of names pass by. As long as we know what we are talking about ... For cutting the photo-etch, I use an old CD and a half round x-acto-knife. So, next I covered the resting places for the anchors with brass. and gave them a shine with a fiberglass pen. Kind regards,
- 156 replies
- Mikasa
Thank you, Yves, although I must admit this will probably be the only adaptation I shall make to this kit, as it is rather obvious when looking at pictures of the hull. Next I used the Pontos-templates to drill the 0,4 mm holes for the footirons (handholds?) Wishing everyone lots of shipmodellingfun,
- 156 replies
- Mikasa
An other modeler noticed that the most forward porthole, above the anchorcluise, was too big, but somebody else noticed that it wasn't even in the right place and that here was no porthole under the anchorcluise. So I filled them up and in acordance to the present-day ship, I drilled 3 aditional portholes on the port side and 1 on the starbord side. Kind regards,
- 156 replies
- Mikasa
Then I reinforced the seam on the inside with epoxy putty and used the same to fill the minute differences on the bottom of the hull, which i wetsanded with a medium sandingstick and finished with 600-grit sandpaper. Kind regards, Herby
- 156 replies
- Mikasa
After visiting Japan in 2019, and searching for a 1/200 plastic model of HMS Dreadnought, I discovered that the only remaining pre-dreadnought was still laying there, open to visitors. I found the kit at a reasonable price and ordered the Pontosset from Australia. The aim of building this kit is mainly to practice the extensive use of photo-etch in order to make a stunning model of the Bismarck. I finaly started this build, painting the underdeck bulckheads Insigna White and the floor Dark Green. Then joining the two hull halves, the bulckheads and underdeck together. Kind regards,
- 156 replies
- Mikasa
Hi Dave, no, still the same
Hi Sjors, I think I know hou too The page you see is what I get after clicking "acount settings". I think I need new spectacles, for I don't see "signature", only a list of 7 options starting with "Overview" en ending with "Content view Behavior" So where did they hide "Signature"? Greetings, Herby
Thanks for the reply, but my problem is that I don't see a tab "signature" in the account settings. Kind regards, Herby
You shure do may suggest, but i have searched an tried, but cant find how to put in a signature
only against an overwhelming delegation of the Royal Navy
Thank you Allan,for your welcome, Herby is perfect
Hello to all members of MSW. I have been foloming this forum for some time now. I make models of historic sailingships (for which I am not afraid to do a little kitbashing) as well as models of "sailing" ships if one can say that of a ship with motors and propellers. My most recent build is an operational Trumpeter 1/200 DKM Bismarck with realisticaly turning turrets and elevating barrels of the main armament, a little lighting and turning radarunits of which i put a build log here: Trumpeter 1/200 DKM Bismarck - R/C-conversie - werfregister | ModelbouwForum.nl Text is in dutch, my mothers tongue, but pictures say more than a thousend words. My next project will be a static model: the Merit International 1/200 Japanese Battleship Mikasa 1905 with full Pontos upgradeset. I hope to get some inspiration on techniques on this splendid forum. Kind regards.
