EricWiberg
Everything posted by EricWiberg
  1. Finally worked on the scuppers after much internal debate. After looking at lots of build logs and the finished models and any historical references to scuppers that I could find.... I placed three scuppers on the lower gun deck and then five on the next gun deck above. I will certainly add 5-6 scuppers on the weather deck as well. I decided to make "boxes", if only for visual interest, instead of just tubes for the scupper exits. I was using the St. Phillipe monograph for scupper dimensions and placement, but then it just seemed to make sense to only have several scuppers on the lower gun deck (as I have also seen on some builds). After painting, I will affix blackened/grayed metal rings on the scupper exits, as believe the scupper tubes were lined with lead. If you had asked me two months ago before I started this build... "would you ever spend 45 minutes using an X-acto knife to make a tiny slot in a tiny piece of plastic..?", I would have laughed at you.
  2. Marc/Henry... I got them at Eugene Toy and Hobby... I searched and searched all over the 'net and found them. If you type in "rivets" in the search box, their various sizes and types come up. I have ordered 5 packs from them and they have been very prompt, but I need 20+ packs now, so I emailed them and they have contacted the supplier for an extra large order... they have been great to work with. https://www.eugenetoyandhobby.com/pages/have-questions-get-in-touch I finished the port side ladders today. I have settled on having TWO ropes, one on each side, so I will install some eyes in the hull after painting.
  3. Both hulls now have all of the holes drilled for the wale bolts (plastic rivets). I noticed that a few of the rivets that I had applied yesterday had fallen out. I had been putting the end of each 0.03" rivet shaft into a blob of Revell contact cement, and then inserting into the hole. I switched to Loctite Super Glue Gel; the Gel is viscous enough that a small blob is apparent on the end of the rivet, and sort of spreads out under the rivet head as the rivet is inserted (whereas the Revell cement was thinnly spread out on the shaft). Now I am wrestling with scuppers, of all things. I have seen wonderful models and period pictures with scupper boxes that just protrude out over a wale. Then there are other period models/drawings with a simple hole in the side of the hull! I may just go with small box scuppers to add a bit of visual interest so someone thinks "what is that thing?". Also waiting in the bullpen are the revised ladder steps for the hull.
  4. Since I have to wait several weeks for 4,025 0.03" round head rivets to arrive, I might as well drill all of the holes for bolting the wales. I had no desire to drill the holes freehand, so I experimented making several different types of hole patterns/spacing in Word (after examining what Hubac's Historian and Michael Saunier did on their creations). I settled on a pattern that I liked and cut a narrow paper template out, and affixed it to the wale by a little Elmer's glue (I tested the pattern first on the old hull). After 30 minutes of drying, I simply drilled a smalll hole at every black dot. Then I washed the paper template/Elmer's glue away and went back to every hole to drill it through the plastic hull. It's fast and very easy for me.... I should be done in a few days with a long wait for rivets.
  5. Marc, this video is very helpful (I also looked at some of his other videos... jaw dropping!). My main takeaway is that I was on the right track by using blackened brass tubes in the lanyard hole. His lanyard holes pierce the wales as needed.... Another main takeaway is that as much as I am enamored of the leather waterproof shield/tube system that I created ala HMS Victory... I don't see them on Fleuron (50 years after Soleil Royal), nor on any VDV drawings. Sooo... I think it is accurate to just have the blackened tubes in the lanyard holes. There are many other takeaways as well! Also, I finished bolting all of the scarf joints on the port side. The hard part is simply drilling the holes (it's not hard... just going to be a lot of holes!). Inserting the rivets is very easy. I am 75% of the way through my initial order of 350 rivets... as soon as I saw that they worked, I ordered 23 more packets (4,025 rivets), so I think I will be set.
  6. Thank you, Marc! I can't thank you enough for sharing your experience... especially how critical scale is. Sigh... that is a lot of drilling, but... with a few sharp bits it will go very fast. Now I just have to make sure I can get about 1,500-2,000 more of these rivets!
  7. Very good start to the day... affixing the fenders to the hull, and starting to bolt up the scarf joints. I found some 0.03" round head plastic "rivets" online. I make a dot with a marker, then drill a hole at each dot. Pick up a rivet and dab the end in glue, then just push the rivet in. It does work best to drill each rivet hole all of the way through the hull; I tried cutting the rivet stem to 1-2mm, but there simply isn't enough room when I grab the rivet head with tweezers. Leaving the stem at 4mm makes it so much easier. The only bad news is that 10-20% of my rivets pop out of the tweezers and fly off into the universe.
  8. Thank you Marc! This is great info, and it does appear going through the wales is an accurate representation.
  9. Thank you Marc! FYI - I saw a Royal Louis drawing today, where the aftmost lower deck gun port lanyard holes started right above the gun port and just below the wale. As the gun ports proceed forward and the wale dips down closer to the gun ports... the lanyard hole jumped up above the wale, but not through the wale.
  10. On to drilling gun port lid "anchor" holes and making fenders. So I needed to drill two holes above every gun port (that was to have an open lid) with a 0.016" bit... these holes would accept two lengths of 28 gauge wire anchored into the gun port lids. The first go-around with the old hull I used a pin vise. This time I purchased a Yakamoz variable speed drill... and was absolutely amazed at how much easier and faster it was to precisely drill holes. All without wobbling the prior pin vise just enough to snap a bit! My first attempt at fenders had been made with 2mm wide x 2.5mm proud Evergreen sticks. Way too thick. This time I simply laminated two 2mm wide x 0.75mm thick pieces together, then simply cut 2mm wide pieces as needed to fit in between the wales. Sometimes the wales were very proud and I used 1mm thick pieces.. some wales were barely proud and needed only 0.5mm thick pieces. I also beveled the ends of the pieces so that they matched the bevel of the wale on either end. Then one piece at a time, I put on a tiny drop of glue and pressed the fender down onto the hull, and it would pick up the piece that was between the wales. A bit of Tamiya Extra Thin was then added and it effectively welded the two pieces together. It takes me about 15 minutes per fender. After drying I will need to do a minor amount of sanding to smooth away any gaps (a few light passes with 60 grit sandpaper adds wood grain mark and wipes away any gaps between pieces). I almost went out to buy a caliper, but this seems to work very well for me. Finally, you can see how much thinner the fenders will be compared to my first attempt (the "new" fender in the foreground obviously is not pressed into the old hull, so it isn't seated flush)
  11. OK... much happier with the anchor linings now than on my first attempt on the old hull (just have to finish scribing the plank lines and give it a wash). At first, I hung an anchor up and just penciled in the swing lines on the hull. Wasn't satisfied with how that looked, so I put the port side on a scanner and scanned the bow; I drew in some lines and got a a sweep that I was satisfied with. I printed that out and then cut out a paper anchor lining, which I then put on 1mm thick sheet styrene and traced two identical anchor linings and cut them out with scissors. My first attempt I added individual planks to make up the anchor linings; doing it this way and scribing in the plank lines was much easier and faster. I also sanded the plank edges if needed to make them flush with the wales.
  12. Johnny and Henry - thank you for the comments, as I find any and all to be helpful. I reread Dafi's post, and I wonder if I missed what he was asking... ? Dafi's first picture shows the Vasa chase gunport pointing almost straight ahead. In other words, if the ship were on a compass and pointed straight north, the Vasa chase gun port is also pointing straight north (I think this is due to the rather bluff bow?). Note the spacing between top and bottom gun ports appears very consistent all the way up to the chase gun port. Now, if you look at the chase gun port that I put in on the Soleil Royal, the spacing between top and bottom gun ports is also very consistent... and yet the SR chase gun port is basically facing much more to the east. Now, I wonder if Dafi is asking if the SR chase gun port should be pushed over to the centerline as far as possible, so the chase gun port would be facing much more to the north, i.e. to a potential target ahead of the Soleil Royal. I might be misinterpreting his question though. but if I really wanted to have the SR chase port facing north as much as possible, I would have to fill in the hawse holes, locate the gun port there, and locate the hawse holes further aft a bit?
  13. Great pictures Dafi! Does the Vasa have a more obvious bluff bow than Soleil Royal that would alow the gun to point forward while still being set further away from the centerline of tbe ship? Also, is that one hawse hole per side instead of two as Soleil Royal has?
  14. Ian, l first saw the reference on this page of Marc's build log (Hubac's Historian). I believe they were never armed, but used for assistance with the anchor... I know you can see them on at least a few VDV drawings, but my overall knowledge on the subject ends there... there are obviously other people with much more knowledge.
  15. I installed the starboard hunting port today and it went better than I thought. My first intent was to scribe it like Marc (Hubac's Historian) did. But even with a jig, I realized that I was going to butcher it if I scribed it. I have several spare gun port lids. I took one and carefully sanded the back down from 1.0mm thick to 0.25mm. Then using a needle file and Dremel, I gradually cut a recess that the lid popped right into and is essentially flush to the surface. it needs a little cleanup, of course, but I am quite happy that I could figure out an installation method that matched my skill set! I won't bother installing the hunting port lids until the rest of the gun port lids go on.
  16. Marc, those pictures illustrate the sweep of the anchor lining beautifully! On my first hull, I actually thought the hawse hole plate wasn't flush on purpose... that the anchor lining was intended to stop right at the edge! I see where the extra timber build ups flush between the two lower wales... I think that I have seen on some models - yours as well? - that thickened timber between the two bottom wales goes back several gun ports, as many as two or three more gun ports? I will attach the actual anchor off of the cathead and move it back and forth so I can pencil in lines for the actual sweep of the flukes. And regarding the scribed scarf cuts... I have resolved to create a jig for just about every situation that requires any cutting or drilling of holes! Finally, on the second photo of Marc's SR build... is that a scupper hole in the lower right? After looking at so many drawings and model builds, I have thought about making my scuppers a 1.5mm brass tube in the hull with a blackened brass flange around the scupper (this is the old hull that I am experiementing on and the tube isn't blackened yet). Marc's looks a lot better but is the same general idea... I have toyed with the idea of making nice boxes that stick slightly out of the hull, but this approach is a lot easier for my skill set at this point. .
  17. After my last post on Jan 17... I stuggled for a week. Did I still want to push quickly through this 45 year old model by experimenting with a lot of things to hasten my skill development for the next model (and keep using a lot of Tamiya putty as I experimented), or... did I want to to see how beautiful this kit could be. I spent a week looking doing a deep dive into the countless SR build logs of various sizes and kits and materials. Marc at Hubac's Historian has been very helpful - thank you! I did nothing for a week... until an EBay add popped up on my phone... an SR hull for $29 (gee, it was almost like they were tracking what I was looking at for a week). When I hit the "purchase" button, my path forward was set! So the new hull arrived four days ago on Thursday. I have 1) sanded the hull, 2) thickened the gun ports, 3) installed the hawse hull pieces flush, 4) cut off the hull ladders, and 5) am almost done with the the scarf joints. I need to drill gun port lid lanyard holes, make the fenders, add my ladder steps, and... I am now confident enough to try and create hunting ports. Regarding hunting ports, In some of the VDV drawings it appears that the hunting port might be pushed forward a bit further, in other words with not exactly the same spacing as the other gun ports? Or is that a perception/parallax issue? So in another week, I think I will be right back where I was on Jan 17... but with a much better hull ready to paint and a completely different goal for this kit.
  18. Dafi, thank you for the observation on friction; I will make sure to have the leather tubes pointing down. Looking at photos of the HMS Victory, I think the leather tube was a bit flexible? I say this because on pictures where the gun port is raised and the lanyards are in a horizontal position, the leather tubes stick out almost straight to the side; when the gun port is lowered and the rope is almost vertical, the leather tubes point downward. Whether the weatherproof leather tube for gun port lid lanyards was even invented at the time of the Soleil Royal, as you say, who knows? But they must have have made some attempts to weatherproof the gun port lid lanyard hole, and I just can't imagine that they would let a lanyard slide back and forth over wooden edges without some kind of tube in the hull wall for the rope to pass through and reduce friction and wear/tear. But, I have almost all of the discs in place, so you could say I am committed to the idea and can't skip it! I do find the question of one vs two gun port lid lanyards interesting, just from the point if there is ONE pulley system internally to raise/lower the lid, there is no mechanical advantage to have two lanyards vs one lanyard. And I suspect that since a first rate ship was about the most complicated mechanism that mankind could design at the time, the people operating it would naturally be looking for ways to improve efficiency, to make things simpler and more reliable for them to use. Thank you for the links - it is very interesting to see what other people are doing!
  19. After much experimentation, I have found a method that might make the waterproofing leather disc/tube that seal the hole in the hull where the gun port lid lanyard runs through. I tried lots of substrates, but rolling out a very thin sheet of Apoxie Scuplt and then "stamping" 2mm circles with a brass tube seems to work the best (compared to foil, wood, paper, plastic, you name it). However, I wanted the disc flush with the hull as in the HMS Victory pictures that I have seen... so I got a tiny, bunt grinding bit on my Dremel and made a very slight concave dish in the hull. I then glued the resin disc into the hole, let it dry, and... very easy to push my leather tube through. I wont bend the tube down until actual installl as it will need to have a lanyard through it. After a lengthy social media search of how the leather disc/tube was colored, I can NOT find any pictures of anything but the actual HMS Victory, or models of the HMS Victory or a few other warships of that period that show the leather disc/tube, as other models run the lanyard through a hole in the hull. The leather disc/tube is blackish on the HMS Victory but sits on a black painted portion of the ship. On the Soleil Royal, the disc/tube combinations all reside on a section of hull that will be painted light brown, soooooooo..... I think I have some license to do my own interpretation. And I think I will leave the leather disc/tube combination a darkish brown on my Soleil Royal... they will stand out, but I am not sure they would have painted them. Of course, if anyone has any thoughts, I am all ears! So I think I am ready to start painting the hull, as think the leather disc should be applied after hull painting... and then the tube inserted and bent after a 6" length of lanyard is in place for the future gun port lids.
  20. The bitter cold is still keeping me priming the hull and other pieces (I have to spray in my garage with the doors open as I don't have a hood!). So working on other things, like settling on a method to attach gun port lids, using some unblackened brass pieces to experiment. I first tried glueing on 1mm wide 0.5mm ID brass tubes to act as the hinge, and then placing an "L-shaped" 28 gauge wire in each hinge and pushing into the hull. It worked, and I only had to drill two total holes for the gun port lid (into the hull), but it placed a lot of stress on the tiny hinges. I wasn't satisfied as it was too fragile. I then tried what Dafi did, and that was much better (shocking, right?). This method requires four holes for each lid (two in the hull and two in the lid). However, it was much easier to insert the lid into place, and the hinges (not added to this lid yet) are not involved in the anchoring process. It will also be very easy to make further adjustments before affixing into into a final position. Finally, I have not found a suitable material or method to duplicate the circular patch around the leather waterproof tube for the gun lanyard. I need something paper thin and 2mm wide with a 0.7mm hole in the middle. Polystyrene, wood, foil, paper, etc... no go. I then rolled out a very thin layer of Apoxie Sculpt and "stamped" it with a 2mm ID brass tube. This just might work, but I will let it dry for 24 hours first.
  21. Henry, I immediately tried that! And if the next 119 attempts work as easily as this one did... you saved me many hours and curse words!
  22. The finished gun port lid photo that Dafi posted above has made me think, especially regarding the leather tube/wrap that shields the hole in the hull where the gun port lid lanyard come out... but first, my biggest issue is... how can I reliably put a 0.012" rope through a 0.019" ID hole? Any needles and thread pullers are too big to go through the 0.019" hole. I have succeeded several times gently pushing the thread through with tweezers on the bench, but most times I fail, even after stiffening the thread a bit with beeswax. I need to resolve this issue before I can proceed. Dafi said he made his leather sleeve by boring out a piece of sprue. That is not in my skill set yet, and I already have blackened tiny brass tubes to insert in the gun port lid lanyard hole, but I wasn't going to have them project out. But I think if I do, my leather sleeve issue is solved... below is an unblackened brass tube that I bent very slightly down, and certainly could bend down more. I inserted a blackened tube into a hole without bending it down, and I added a very crude polystyrene circle, as photos of HMS Victory show a small circlular "patch" around the base of the leather tube... I don't know if the circular patch is leather, but I could make this patch with a hole punch in some paper-thin polystyrene after sanding the attachment point in the hull. In photos, the circular patch isn't quite flush, but is raised from the hull the tiniest fraction.I can't tell if they painted these leather tubes on the HMS Victory, as the leather tubes are on a black painted section of the hole, and perhaps the leather is naturally black? On my Soleil Royal, all of these leather tubes are going to be in areas that are painted a light brown... I think I would paint the circular patch to match the hull, but leave the leather tube in a blackened state; in real life would it work to paint the leather (maybe they used standing rope "tar" on the leather tubes?). It looks in photos like these leather tubes were somewhat flexible, meaning if the gun port lid were closed, the leather tube pointed down (as the lanyard was down), and if the gun port lid were open, the leather tube pointed out more so as the lanyard was about 90 degrees from the hull. My single biggest issue is getting a 0.012" rope through a 0.019" tube!
  23. Marc and Dafi... your observations and input have been extremely helpful and have allowed me to make several decisions.... and I have a question about making eyes and eye bolts! 1) Marc, the painting of the cannon is exceptional, no doubt I will use the Heller cannon on the (visible) upper deck and also adjust the trunnions per Dafi. 2) I will stay with one lanyard to raise/lower the gun port lids, and I immediately noticed on the La Reyne drawing that there is one eye on the inside of the lids; now I am very comfortable in using one eye on the outside and also one eye on the inside of all gun port lids. I was going to use two ropes on the stern chaser gun port lids as they look heavier... but if one pulley system is used whether there is one rope or two ropes... I might as well stay with one rope on the outside. 3) Dafi, I love the idea of the brass wires anchoring the gun port lids... I will do that! I was trying to figure out some way to replicate a leather sleeve like you have shown... my first thought had been a 0.5mm ID brass tube in the gun port lid rope hole that I would blacken, and then perhaps bend down a bit to replicate the leather waterproofing sleeve. But it might be easier to get that look like you have down with bored out sprue - I will experiment with both methods! 4) I saw somewhere that in that time period, ships may have had some kind of cloth or fabric "sock" hanging from their lower scuppers that acted as a sort of check valve that allowed water out, but kept seawater from splashing back in. I will have tiny blackened tubes in my scupper blocks, as I read that the scupper tubes were made of lead? But I have no idea - yet - on how to duplicate a 3mm long fabric sock... I think in that case bored out sprue might look stiff? 5) Finally, eyes and eye bolts. I had no idea where to start, so I experimented with various gauges of brass wire and am now using 28 gauge brass wire. For eyes, I have been wrapping the wire around a drill bit of appropriate size as you show in your photo Dafi. As for eye bolts, I just experimented with my own by putting an eye on a brass wire and then twisting the wire... so now I have an eye on an eye bolt that I blacken after cutting the eye bolt shaft to a 1mm length. I see in the picture that Dafi puts the eyes on pre-made eye bolts. If that is best practice, I will make my own eyes and order eye bolts and go in that direction. It almost seems easier to put an eye on a wire and twist the wire into an eye/eye bolt combination? However, if it is faster to use pre-made eye bolts or if they also simply look better in scale, etc. then I will happily buy eye bolts and not make them!
  24. Thank you for the tip, Ian... I looked it up and there is a big difference. I may well use the Heller cannon on the visible upper decks (and use the bigger cannon as Marc has noted). The Heller cannon do have very nice decorations. Also, I think that I may run the breeching rope on those cannon through the gun carriage, instead of on the gun barrel itself, as that seems to be a way the French did it at the time... thought that may be many months out!
  25. Ian, I ordered 60 "below deck" guns first, as it will take me some time to get to the upper decks. Thanks for the advice on the distance between the wheels... I looked up what you are referring to and it makes complete sense. I thought at first the metal cannons might be too big, but it turns out that their dimensions and scale are accurate. I hope the heavier, more robust appearance of the guns will stand out and make the ship look like the floating wooden castle that she was.
