Adrian Hunter
  • Location
    Hampshire - UK
  1. Nem0, I have the bottom of your pictured kits. Maybe they are just different editions of the kit? Ian, Many thanks for your input. I do take your point on historical accuracy. At this point I must temper this against my own capability! We shall see. I only finished a few shrouds on the jig, and their rigging is still so far in the distance that I may well attempt what you suggest when I get there. If nothing else the jig has improved my miniature clove hitches!
  2. My kit does not have the printed decks. Instead I have marked the centreline along the whole length of the model, and I will use this to start off when I get to decking to that it is all uniform. One other thing - My kit came with an etched metal sheet containing doors, nameplate etc. I do not like this medium and bought a wooden equivalent online quite cheaply that I am far happier with. You can see it on the crew accommodation in my pictures. It seems it is luck of the draw what you find inside the box sometimes! Good luck with your model - this one is quite challenging!
  3. Hi All, A quick update on recent progress... As you can see not too much added. I did get some rigging done on holiday, this has been set aside until such time as I make the masts! On my return I did have a look at the stern (thanks for the advice again Johnny), but decided that I am too far down the road to make any major structural changes, and in honesty it is probably beyond my current skill level! So, I will be keeping to the plans even if they are not totally accurate historically. I have been cracking on with some smaller pieces, the hatch covers are done and I have painted a bit more of the boats. The only other thing is the wheel. The plans said to take the provided wood block, chamfer the top and then make some legs out of wire to give it the height for the wheel to clear. I didnt like this so I have built up the botton of the block instead. And that is about it. I am back at work so it will be the end of January until I get any more done. Until then Happy Holidays and Happy Modelling!
  4. Nothing on the hull to report - I am on holiday, But... to feel like I was doing something whilst I am away I thought that I would start some of the rigging. I decided to use an Amati Loom-a-line. I know that I could have achieved the same thing with a bit of plywood and a few nails, but as it was fairly cheap (about $10) I went for it anyway. As you can see my first attempt on the left is somewhat wayward and will be discarded, although I am happy enough with try two for the mizzen. And the frame - I think worth the money. The pins are a bit tight in some places and fall out of others, but now I am getting used to it it is helpful, and also very adaptable for exact requirements and scale.
  5. Johnny, Thanks for your thoughts, the stern is certainly different so i may have a play... Happy Modelling!
  6. So,,, Model number 2 I chose the Thermopylae as who doesnt love clippers and I got on quite well with this brand in my first build. From the forum I see that others have tried this model, and to be honest if I had read their posts before I bought I may have thought again, but here we are... Luckily I am fairly pragmatic in my building and not being too anal about absolute authenticity will within reason 'adjust' the instructions to suit my ability and a pleasing result. Initial thoughts - I agree with others. If you want a kit where you folow the instructions and get what is on the front of the box this is probably not the kit for you. I am already finding that fettling is required and see that at least some parts will need to be scratch built. The instructions basically come in plan form. Luckily I am an officer in the Merchant Navy so I can read a general arrangement with some confidence, but without this I think that I would be lost. Written instructions are in Italian, although quite a good English translation is available to download here. So far I have spent a couple of weeks on this project off and on, so lets have a look... The basic framing and sub deck seemed to go in quite easily. Forward and aft frames were chamfered as suggested. The main deck was then glued in place and then the focsle and poop decks. So far so fairly good. On to the planking. This is a double plank model, which I have not tried before, but I enjoy a challenge! The runs seem quite reasonable except up onto the stern without too much bending required as yet. Progress to date is below, you will see that I have also started on some of the deck structures. The deck house that positions just aft of the Foremast is meant to have a convex roof, but I decided that this was more trouble than it was worth and sanded it flat. I think this looks quite acceptable and saved me a lot of stress! The Lifeboats are as suggested by Popeye in his write up being Amati 50mm. I think they are a bit big for the model looking more like a longboat than a lifeboat, but they do look good. I will probably finish painting them and then decide if I will use them. And that is about it for now. I will add more as I work, but due to work it may be some time before anything is forthcoming...
  7. Welcome aboard!
  8. Good looking hull! Welcome aboard!
  9. Welcome aboard!
  10. A nice looking first project. Welcome aboard!
  11. My condolences, and welcome to the forum
  12. Hello all, Just a quick intro to myself. I am very new to wooden ship modelling. In the (dim and distant) past I made many plastic models, and re-found this during the Pandemic lockdowns, also making one wooden plane. Given that I have served as a Master Mariner and Ships Pilot in the British Merchant Navy for many years this is a thing that I will most probably enjoy and given that my Batchelors degree is in History it should be a match made in heaven... I plan to work my way through a few kits of increasing complexity, and I have now finished the first. One day I would like to scratch build, perhaps a ship that I have served on... We will see!
  13. Popeye, I would just like to thank you for this thread. I am just starting this kit, and you have me considering problems that I did not even know that I had! I will post my progress as it goes along
  14. I would just like to wholeheartedly endorse the central tenet of this post. I have just finished my First Project HMS Bounty. For this I deliberately chose an entry level kit, and while it stretched me at times the problems that I found were not insurmountable. I now feel that I can move on to something a bit more complicated. Time will tell if this is a good idea... As they say you have to walk before you can run... Happy modelling!
