Everything posted by wefalck
.... patience, I am still many steps away from the finished product. One of the next steps will be the creation of the ice-surface and, thus, blending in everything. Actually, the gaps between the piles and the Plexiglas sheet will be filled-in with acrylic gel, which has a similar refractive index as Plexiglas, so that the gap will disappear. I had been debating with myself, whether I should give the piles an iron capping or not. I think I have seen both versions on old photographs. Modern piles do have a cap. In the end I decided on the more picturesque version without caps. wefalck
Well, before disappearing on a ten-day scientific mission to the moutains of Kyrgyzstan, here a small update on the work on the scenic display. In real life the various members of the jetty would have been fastened together with iron bolts. Square washers prevented the bolt heads and nuts from being pulled into the wood and splitting it. The bolts and washers were imitated by taking simple brass nails and milling a hexagonal head and a square on to them with a set-up of an indexer on the mill. The shaft was thinned down and parted off on the lathe. Brass nail ready to be milled into a bolt Milled bolt head Milling machine set-up with indexer The wood was stained in 'medium walnut', which gives it a greenish-grayish weathered appearance. The pile-heads were painted white (which gave them a better visibility in bad weather). The effect of the seawater was reproduced by letting the wood soak up some black stain from below. The jetty etc. under construction Details of the construction The jetty etc. under construction To be continued ... wefalck
As the material used for sails on models usually is way over-scale, perhaps by one order of magnitude, furled sails inevitably look to bulky. Some people, therefore, make the sails smaller than they should be, resulting in less volume, when stowed. Other people use paper for the sails. And again, other people use papier-maché for furled sails. This depends on the style of the model. wefalck
There seem to be several ways of doing this: stowing it on top the bowsprit etc., much like square sails are stowed on top of a yard, with or without gaskets; or sort of turning it around itself after unhitching the sheets, then hooking the halliard into the clew and hitching the sheets back on - so that it is suspended like a sausage in the air: wefalck
Yep, started on it, but have to produce the ironwork for it first. Pictures will follow. Haven't had much time, being out of the country a lot, to catch up with all the building logs since MSW 1.0 went down the drain. Just looked at it, you cutter has been growing very nicely, John wefalck
Enamle vs Acrylic
wefalck replied to Timothy Wood's topic in Painting, finishing and weathering products and techniques
Neutral grey would have the effect of toning down the 'brilliance' of a colour, without changing its spectral properties. I guess, when painting a wall etc. in red on a white basecoat, the effect could be just too stark. A grey basecoat would reduce the 'brilliance' of the red without changing its tone. For small parts on a small modell, however, you may want a brillian colour, but it depends on the circumstances. A too brilliant red may make a part jump too much out from the rest of the paintwork. It also depends on what other colours are nearby: a brilliant red spot on a green background, for instance, would appear to be floating on it, which is not what you may want. So toning it down with neutral grey would bring it visually down into the same surface. wefalck -
Just a small update on the scenic setting today, too much travelling and other activities recently. With the Plexiglas sheet to simulate the ice in place, the positions for various piles that carry the planned jetty were marked out. The design of the jetty followed that seen on various historical pictures (see my Web-site). Holes for inserting the piles were drilled throught the Plexiglas into the wood. I cut some square strips of soft wood on the table saw and from these 'piles' of the appropriate length were chopped. The wood was roughend and shaped using a rotary steel-wire brush in the hand-held drill. Cross-pieces etc. were shaped from the same wood. wefalck
Enamle vs Acrylic
I'm on the third coat now and the blue molded plastic is still showing through. To get a good coat of red you will need to prime it in white, ... The cause and the cure: many red pigments do not have enough 'body' to provide full coverage. By definition red pigmentes/dyes reflect/permit only red light. The blue plastic only reflects blue light. So, after going through the red paint almost no light arrives that can be reflected by the blue plastic and it appears sort of black. Providing a white or (neutral) grey underpaint means that all the light travelling through the red paint can be reflected. wefalck -
I just noticed that when re-creating the building log from MSW 1.0 I missed out part of the work. Perhaps because it concerns some small and delicate parts that look simple, but are not so easy to manufacture at this scale. Well, the smithy of the boatyard has been busy and turned out various pieces of ironwork for rigging and other purposes: The mast is held in its tabernacle by a latch hinging on eyebolts. Mast tabernacle There is a complex piece of ironwork that guides and holds down the running bowsprit (which will not be shown on the model, as it was normally left home during the winter season, when a reduced rig was used). The ring was turned from a piece of brass rod, while stay was fashioned from a piece of steel rod on both the lathe and the mill, as it has partially a square section. In fact, various parts of the ironwork do have square sections, inter alia to prevent them from turning, or because they have made from square bar, hammered to a round cross-section where needed. Bowsprit guide The leeboards are held by sort of square rings that slip over the leeboard-bollards. These rings were made from brass strips soldered together and filed to shape. The leeboard pivots on a bolt that is held by these rings. Various ironwork A major challenge were the various belaying and thole pins. On the prototype their maximum diameter is just under 40 mm, the cylindrical sections generally being around 20 mm. So, in the 1/90 scale this means they are 0.2 to 0.4 mm in diameter, with a length of 3 to 4 mm. There are five different types and the literature (VAN BEYLEN, 1995; DORLEIJN, 2001) gives the typical dimensions and shapes for each them. Turning them from the available brass was impossibe, so that 1 mm steel wire was used as starting material. Even then turning them flying, i.e. supported only in a collet in the headstock proved impossible. This lead to the design and manufacturing of a tailstock-held micro-steady. The spherical parts on the pins where shaped free-hand using files and strips of abrasive paper. Belaying pin Specially made micro fixed-steady for turning small slender items on the watchmakers lathe. wefalck
I am using a piece of thick cardboard on which I put the sail drawing. The whole then is wrapped in clingfilm, making sure no creases appear in the area of the sail(s). wefalck
I have used the same technique for larger scale sails (1:60), but used very fine silk cloth that is commonly used for model airplanes. I first prepared a sheet of impregnated silk and then cut the individual sail cloth from it. These then were again stuck together with the sanding sealer. The cellulose-based sealer has two effects, one is that it fills up the structure of the material, making it less coarse looking, and second, you can correct the positioning by applying thinner. Otherwise, diluted white glue would do a similar job. wefalck
I was actually wondering about this, but it seems that the Volendam dyke hasn't changed much in profile. The buildings on the dyke front (e.g. the auction? house) are still there, the slope neither and on the back there wouldn't have been any space to make the slope less steep because of the house immediately behind it. wefalck
druxey - yes it is a cellulose-based sanding sealer Thanks, amateur, for this bit of information. I have been trawling the Web, but couldn't find any data on the height of the (astronomical) tide in the Zuiderzee, but guessed that it would be probably in that range. With the scenic setting I am taking a few artistic licences, mainly so as not to overwhelm the real subject, the botter, and to keep the size of the display reasonably small. So the jetties and related infrastructure are not as high as they probably should be, the slope of the dyke is too steep and the dyke is too low (if I remember right from a couple of visits, the crown is about 5 m above the present-day Ijsselmeer level), plus, as amateur noted, it should not be covered in brick. In spite of this, I think in the end the overall impression will be reasonably authentic, giving context to the model. wefalck
You put me into a dilemma now ... yes, it seems to be hardrock on the slope and bricks only on the dyke's 'crown'. I am also aware that the slope in the model is far too steep (dykes' slopes have become shallower and shallower over the years). Considering the amount of time I spent on it, I am not going to break it up again. wefalck
Amateur, you are right (after all I am sort of also working/teaching in coastal protection). However, I couldn't find any photographs from Volendam that showed the face of dyke in front of the town. I was also wondering, whether in the last quarter of the 19th century hardrock was imported in sufficient quantity into Holland. I guess the basalt from the volcanic mountains near Bonn at the river Rhine would be the closest source. I know that e.g. Scandinavian ships brought granites as ballast. wefalck
The dyke section was covered in a thin layer of wall-repair putty from a tube that I had around by chance. Otherwise, I would have used plaster of Paris mixed with some wallpaper glue, which improves its sculpting behaviour. Once the putty was dry, it was sanded down smoothly and then single bricks engraved by rows with a needle held in a pinvise. The fact that corners broke out of the bricks was approvingly tolerated, as it will enhance the weathered appearance. Baseboard with sculpted dyke Close-up of the engraved bricks In order to reduce the porosity of the putty and the wood the whole surface was treated with cellulose-based woodfiller, before the dyke was airbrushed in English Red (Schmincke AeroColor), while the water area received a basecoat of burnt umber, partly mottled with black. In a next step individual bricks were picked out with blue and brown washes to enliven the dyke surface. Since the acrylic paints dry satin, the whole was lightly sprayed with Winsor & Newton acrylic matte varnish. A restrained weathering using artist’s pastels followed. Painted baseboard The brick surface of the dyke The model of the botter in place wefalck
Thanks for the kind words ! @mtaylor: the carving isn’t actually mine. The figures are based on commercial products by Preiser (http://www.preiserfiguren.de) that were modified using putty etc. The building has now reached a stage where I need to think seriously about protection against dust and mechanical damage, which is not so easy once the mast has been erected. Therefore, I started with the building of the scenic display, around which a display case will be fitted. The basis is a piece of blockboard Harbour and dyke in Volendam (www.geheugenvannederland.nl) The ‚story board’ for the scenic display assumes that the Marker botter is moored at a jetty in front of the dyke behind which Voldendam hides from the Zuiderzee. The botter is ice-locked in Voldendam. The dyke runs obliquely through the scene and was given a frame from pinewood cut-offs and filled with balsawood. Baseboard and core of the dyke The frozen Zuiderzee consists initially of a sheet of 2 mm Plexiglas. A screw piercing baseboard and Plexiglas will eventually fix the model in place. Trying out the model in place All wood parts were dyed in mahagony and varnished as will be the other wooden parts of the display case. Baseboard dyed and varnished Once the varnish is dry, this report will continue. Wefalck
The actual painting proceeded with Schminke-, Vallejo- und Prince August-Airbrush paints, but of course using very fine (10/0 and 5/0) brushes. The painted skipper But I had to fight with the brushes. The art materials department in the famous Bazaar de Hotel de Ville (BHV, www.bhv.fr) which has the best DIY department in Paris wasn’t the same anymore after a recent revamp. It turned out to be very difficult to find such fine brushes in Paris, but I needed to replace some worn out ones. Eventually I ordered some via ebay in Germany. Their rather fat three-sided handles looked as if they would be very comfortable, but their turned out to be really ‚rat-tails’. I gather you get what you pay for. Also: one should really try the point in the shop, which is obviously not possible when ordering through mail. The back of the painted skipper The painting technique was largely the same as for bigger figurines. However, at the 1/90 scale one needs to simplify, particularly when painting the faces. Thus, the eyes were indicated only by the shadows beneath the eyebrows. This I learned from Canaletto, who was able to render a very lifely population in his Venice pictures with just a few strokes of his brush. The effect is calculated form normal reading distance – on your computer screen the 18 mm high figures appear several times magnified. Painting the faces in acrylics was an experiment. The open time of these paints is just too short for painting soft transitions and I will return to artist’s oils for this. The painted mate. Photographs show you the coarseness of your work glaringly. Observed from normal reading distance, I believe, the figures look quite convincing. The painted mate from the back. The scenic setting will be eventually populated by a boy belonging to the botter, a Volendam couple enjoying a walk on the dike and another couple, where he is pushing her in a sledge on the ice. wefalck
I have been watching the development of these techniques for five or six years now and slowly gets to the resolution I need. Around 2007 the institute I was working in at that time bought a 3D-prototyping machine, but there were two many 'steps' on the parts still at that time. I got some basic AutoCAD training there out of European Union's taxpayers pockets though I think I will have to re-hone my CAD skills soon ... Another avenue for access to machine time could be the FabLabs: http://en.wikipedia.org/wiki/FabLab. wefalck
The Dutch Boeier De Sperwer- The 'James Bond Yacht'
wefalck replied to Salty Sea Dog's topic in Nautical/Naval History
Thanks for publicising my pics Perhaps the most comprehensive treatment (albeit in Dutch) in literature of the boeier is this one: VERMEER, J. (2004): De Boeier. – 528 p., Alkmaar (De Alk & Heijnen Watersport). The books contains numerous lines drawings, including one for DE SPERWER, if I am not mistaken. Larger versions of these and other drawings are available through the Dutch Modellers' Association: http://www.modelbouwers.nl/tekeningen.php wefalck -
Pulley sheaves out of plastic hangers
wefalck replied to Walter Biles's topic in Masting, rigging and sails
Walt, I seem to have seen brass sheaves by various modelling suppliers on the Web. Whether these would be viable sources depends on the cost of shipping, I suppose - and what size you need. As I do tend to make such things myself, I cannot be more specific. Google seems to turn up a few links. wefalck -
True, if you don't have access, for whatever reason, to raw materials, you have to make do with what you have. I just wanted to warn that plastics in consumer products often are of low quality, contain a lot of plasticisers and, therefore, are not very durable. One has to be aware of that, when building a model. wefalck -
OK, recycling is fashionable and a good thing to do. On the other hand, there are better and more durable plastics in rod-shape available. wefalck
