Everything posted by wefalck
  1. What period are you working on ? Be aware that, after jack-stays werer introduced, the sails where furled on top(!) of the yard and not below. wefalck
  2. A couple of thoughts: - in order to look to scale when furled, the material for the sails should be of scale thickness; for most, but the largest scales, it is virtually impossible to get woven cloth of suitable fineness due to the limitations of thread-size and weaving practicalities. - one answer is, as noted before, to make the sail shallower/shorter. - actually, as only the outside and the clews will be visible, a narrow piece of cloth draped around a suitable filler, e.g. made from papier-maché or modelling clay may be the better solution. - other people, like myself, make the sails from silk paper. - most text-books decribe naval practice; in the merchant navy things may not have been as 'ship-shape and Bristol-fashion'. - each navy had its own rules for furling. - the way of furling depends on the shape of the sail, which in turn depends on the period; the relatively rectangular and shallow sails say of clipper-era ships were not furled towards the mast, but parallel to the yard (with no bulge in the middle); the earlier trapezoidal and deeper sails were furled towards the mast, resulting in the characteristic bulge in fron the mast. wefalck
  3. Make one ... I had contemplated using a curtain rail as the basis, before the optical bench came my way. Many people use wooden boards and threaded rod for the bodies. All can be done with a hand-saw and a drill-press. The ropewalks of old also were not pieces of precision engineering (ignoring the big industrial ones, such as the one in Chatham Dockyard). Mine was designed for making ropes from extra-thin fly-tying silk. wefalck
  4. Now the rigging begins in earnest. As different sizes of rope are needed for the various parts of the rigging, they are made on my ropewalk as the rigging progresses. A special difficulty arose from the fact that fore-stay and fore-sail have to be set up simultaneously: the eye-splices of the stay do not fit throug the hanks of the fore-sail. Hence the stay has to be first reeved through them and then hooked into the hook of the dead-eye. This operation cannot be performed on the worktable, but has to be carried on the model. Rigging of the fore-stay In a first step the various blocks, namely the sheep’s head-block for the fore-sail halliard had to be hooked into the bolt-rope and a single sheet-block with second eye had to spliced to the clew of the fore-sail. Fore-sail with hallieard and sheet read to be set The halliard is an interesting item, as it also serves as a down-haul, i.e. it sort of endless its ‚free’ end is spliced around aone of the hooks of the sheep’s head-block. In real life the halliard is a pointed rope, meaning it becomes thinner at the ‚free’ end. However, this cannot be reproduced seriously at the 1/90 scale. Head of the fore-sail with halliard and down-haul The sheet is also lead in an interesting way. It is lead like a gun-tackle, but the second single block inboard is missing. Instead, the sheet is lead around the groove of a half-cleat on which it is also belayed. Clew of the fore-sail with block attached (actually, the block should have been spliced into the bolt-rope, but I didn’t notice this when making the sails) BEYLEN (1985) describes alternatives for the arrangement of the fore-sail sheet, some of them lead like a gun-tackle, but with one or even both single blocks missing. He does not explain the rational for the absence of the blocks. The increased friction would be of advantage when holding the sheet in strong wind, but would make it more difficult to haul it in. wefalck
  5. Indeed silver paint tends to be a bit to shiny (though new galvanised parts are rather bright in real life). I tend to start off with a layer of silver and then apply a wash of umbra to tone it down. Or, I start off with black (or gun metal) and then apply a thin coat of what is sold as 'rust' paint (e.g. Vallejo), which essentially seems to be a mixture of silver and umbra. One has to experiment to get the right sheen and tint. wefalck
  6. Elia, I consulted a 1903 German textbook on rigging (written by F.L. Middendorf, who designed the 5-mast ship PREUSSEN) and he says that in the past (counting from 1903) ash and elm was used with sheaves from ironwood or bronze (or cast-iron for wire rope). Actually, for blocks with internal straps (which came into use in the last quarter of the 19th century) the wood is not so important. The wood there is not load-bearing and just serves to prevent the iron 'cage' of the sheave from fouling and chaving rigging and sails. So, I guess you can paint the blocks in any tint you like. wefalck
  7. Blocks with internal iron strops are a pain ... so far I have not had a good idea how to make these, particularly in smaller scales/sizes. There is just not enough 'meat' at the top of the blocks to glue in the eyes or hooks. At the bottom end this is not an issue. I don't think blocks and mast/spars would be of the same colour. They would have be made of different kinds of woods. In the late 19th and 20th century blocks also were often painted, e.g. white or 'mast colour'. wefalck
  8. Nothing is 'permanent' in life ... except stains on your favourite trousers Actually, sometimes(!) incompatible paints and varnishes can be used when applied by airbrush. The respective solvent evaporates before any dissolution and diffusion of the underlying paint can occur - provided one applies thin coats only. This is also a method to applly several layers of the same paint or varnish that would dissolve previous layers when applied by brush. In any case, I would try it out on a test piece. wefalck
  9. Right - acrylics are not resistant against ethanol/methanol, which is the solvent in traditional shellac (... a lot of cabinet-makers in the old days were alocoholics ) ... For same reason one should be cautious with alcohol-based varnishes that are sold in spray-cans e.g. for water-colours or pastels. wefalck
  10. Britannia metal probably is best primed, as the tin alloy has a slightly hydrophobic surface. This holds particularly when using acrylics. On the model of the Zuiderzee-Botter I spray-painted the homemade Plexiglas-blocks in a light tan and brushed on washes of burnt umber acrylics. They then were sprayed in a semi-gloss varnish. I would avoid simulating any wood grain, as for good reason tough fine-grained wood would habe been used for blocks. Another method of painting I used is to first spray-paint the blocks in a light tan and then to apply a solvent-based tinted wood varnish. wefalck
  11. The old painter's rule is fat over lean, meaning never use water-based paints or varnishes on oil-based paints or enamels. In other words, you can use almost anything on acrylics. I don't know anything about the brand of the varnish you mentioned, but presume that it is acrylics-based. Acrylics may need a certain time, some days, to fully harden. They may de-swell, giving off excess water during this time. So it would be a good idea to postpone varnishing a few days or even weeks to avoid tensions between the layers. If, however, paint and varnish are similar products, it may be a good idea to apply the varnish layers quickly, as they would better key into the fresh paint. wefalck
  12. Not much progress on the Botter-model since I came back from vacation. Once reason is also that in the meantime a little item ordered in China had arrived: Ever since I came across the LED ring-lights for cameras and microscopes, I thought something like this would also make a good illumination for the milling machine. However, all these lights were to big and too expensive for the purpose. With my limited electrotechnical and electronics knowledge I did not dare to put something together myself. Then I became aware of the so-called 'angle eye' cosmetic tuning parts for cars. Apparently, these are fitted around the bulbs in car headlights to give the headlight a aetherical appearance. They are produced, guess where, in China and sold via ebay at a price at which I cannot get the components, not considering the hazzle of soldering everything together. I ordered a couple (for obvious reasons they are always sold in pairs) and fabricated a lamp around these rings made from epoxy base-material. The components of the lamp As I wanted to protect the LEDs from oil splashes I chose a Plexiglas-offcut of suitable size and bored an annular groove into it. The groove has a shoulder on which the epoxy ring rests so that the LEDs do not touch the front cover of the lamp. Turning the lamp body The outside of the lamp was milled to shape by holding the body in a three-jaw chuck mounted on my upright collet-holder. Shape-milling the lamp body The backside is covered by a washer-like lid turned from a piece of bakelite sheet. Into the 'handle' of the lamp a neodynium magnet was embedded that holds the lamp to the spindle of the milling machine. Turning the lid The lamp was painted using a stainless steel acrylic paint. The finished i-Mac-style lamp As LEDs require a current-stabilised power-source, I ordered, again from China, a small electronic transformer or 'driver' for LEDs. The lamp in action More: http://www.maritima-et-mechanika.org/tools/attachments/attachments.html#Ring-light Now work on the model recommences ... wefalck
  13. I have used artist's acrylics (by the German manufacturer Schmincke) for some 30 years for air-brush application (it comes in bottles with the right consistency to be applied directly). More recently the Spanish manufacturer of artist's paints Vallejo, came onto the market with a good range of modelling air-brush-ready paints. I use the same paints also for application by brush, but this needs priming on certain materials. I also use traditional artist's oil paints, e.g. for painting details on figures. wefalck
  14. This is an air-turbine. You need a good compressor for it ... wefalck
  15. You may want to go through this Web-site: http://www.plasticsoldierreview.com/. It concerns figures that are nominally 1/72, but in reality there is quite a variability of the 'average' height chosen by the various manufacturers. You may find an 'oversize' set that is more towards 1/64. Otherwise, dive into virtual 3D-computer modelling and have the results printed in real 3D. I believe that 'anatomical' virtual 3D people are available as a starting point. Could be an interesting small business idea ... wefalck
  16. Historex only works in the 1/32 or 54 mm scale. The problem is that 30 mm is the classical flat figure scale and rarely any fully round figures were produced. For a short period there were one or two UK manufacturers (one of them had been later sold to Sweden, I believe). They had an outlet in Shepherd St., Central London, but have long gone. wefalck
  17. The purpose of an independent 4-jaw chuck is to very precisely center stuff, round or square, to the point you want to have it on. So this is not defect due to low price, but intentional. It is tedious to center stuff, e.g. with a feeler gauge, but the most precise way, sometimes more precise than with self-centering chucks. wefalck
  18. These wargaming figurines in general look more like garden gnomes than normal humans, their proportions are not good at all. Some years the United States Post Office made a rather customer-unfriendly decision and stopped what was called 'surface mail'. Stuff did take 8 to 10 weeks to arrive in Europe, but with a bit of planning it didn't matter and it was a lot cheaper than 'airmail'. It is quite strange, as you can get stuff from China for almost nothing ... not a good move in a globalising economy. wefalck
  19. You can gain height by rigging a tackle (or using the braces) at the opposite yard arm to tilt the yard. You loose some clearance off the ship's side though. As noted above this was a common arrangement to load/unload at the quay-side. wefalck
  20. Sounds pretty dangerous in anything but a dead-calm sea. Harland describes/illustrates exactly the same procedure as popey2sea described. wefalck
  21. Not specifically for the ENDEAVOUR, but this book give a detailed description of how it would be done: HARLAND, J. (1985): Seamanship in the Age of Sail.- 320 p., London (Conway Maritime Press). wefalck
  22. My God, what are you going to do with such a huge lathe, turning soup dishes ? What modellers need (e.g. for masts) is a good centre distance. And remember: you can wood on a metal lathe, but not the other way around. If you only have money and space for one lathe, get a metal one, though they are a bit more expensive. wefalck
  23. Actually, it is almost certainly not stainless steel. Stainless is not normally used for such things, too difficult to machine and usually cannot be hardened easily. If it is for 'one-hand operation', than it is a different animal from the plastic chuck for the Proxxon: it means that it is a centric 4-jaw chuck, all jaws move in and out together. Such chuck is really only useful for square stock. These days you can get quite cheap chucks of all kinds from Chinese sources. Check on ebay. The Sherline ones are quite good and come with different threads in the back, so you may find one to fit your lathe. wefalck
  24. I didn’t like the sewn-on fore-stay in the end. So I went and fabricated a minute hook from copper wire. Once the hook is tinned and soldered together it is actually quite resistant against the forces on it during the rigging operation. The now correctly attached fore-stay Lucky me that I am not dafi working on his VICTORY and that I don’t need hundreds of them ... wefalck
  25. I still found time to begin with the rigging. Work will progress only slowly since the parts are rather delicate and the work is rather nerve-wrecking. At the prototype one would install, of course, the fore-stay first. The fore-sail would be attached with its iron hoops. In my case, however, the hoops have already been sewn onto the sail, a work that would be largely impossible to do in situ. Therefore, the fore-stay has to be installed with the fore-sail attached to it. Form a modelling point of view sailships of the late 19th / early 20th century are quite difficult to rig. In previous periods ropes were often either spliced directly into eye-bolts or sewn on, which both are quite easy to reproduce in a model even at small scales. In later times, to the contrary, shackles and hooks became ubiquitous. It made the rigging and repair easier, but making shackles or hooks of 0.5 mm or 1 mm is quite impossible (the smallest shakles I managed to make are about 2.5 mm long). Just the fore-stay of the botter is hooked into an eye-bolt of the mast. Wire with a scale diameter would bent open under the load. So I had to take a shortcut and to sew it on. Reeving of the fore-stay deadeye with the help of a tripod There were various methods of rigging the fore-stay of a botter in use up to the end of the 19th century. I chose the somewhat old-fashioned method with a dead-eye. The lanyard was made from a rope made on my own rope-walk: three strands of Veevus fly-tying thread 16/0 in golden brown. The colour was chosen because the lanyard would have been tarred. I wanted to put a real wall-knot onto the end, but the fly-tying thread works almost like wire and is well nigh impossible to splice. The fore-stay deadeye The first picture shows my rigging aid: a small tripod that came from deceased father’s estate and was used to suspend a pharmacist’s balance (not sure sure what he ‚above’ would say to this re-use ...). A wire loop suspends the dead-eye so that it keeps clear. To be continued after my vacation ... wefalck
