Posts posted by Mayohoo
Will follow with interest! Am kit building but would like to learn scratch building some day ;0)
Thank you for coming back and reposting! I am plodding along in your wake (so to speak) with my HMS Surprise. It's amazing how long it takes when you do this for the first time
Hrs 701-705
Some. Went on vacation to Spain and so has been slow. Was not happy with quality of bulwarks so did a lot of reworking. Also added trenails to make more realistic. Hard to see but they are around gun port frames and on end of stern bulwarks.
Also hooked up one light for the stern lantern.
Still need to touch up paint job.
Went to a museum in Barcelona and they had a replica of a galley gunboat on display. Pretty cool. Big too. May add a pic if they come out on my iPhone
- billocrates and mtaylor
2
I did actually. I was not sure if it was the entire mainmast or just the lower mainmast, which would be a thicker diameter lower mainmast. In any event I added a small amount of length to it. According to the resources the formulas were not precisely exact and the distance overall length between a 28 and 36 gun frigate was (to scale) only 1-2 inches different. In addition, there was a suggested range for the masts and the formulas were sort of an average. I plan to make up the difference up by not pushing the length of the lower mainmast as deep into the hull using a screw extension off the base. (I haven't put the main mast in yet). The fore and mizzen are in already.
But thanks!
Hrs 691-700
Got the last carronades from Jotika and am working on them. Nice detail with screw elevation on back and the slide.
Also made 2 brass "Long Nines" for bow chasers which were Jack's favorites. Made the gun carriages green and did not blacken the barrels. I will call them "Catherine's Claw" and "Henry's Hammer" after the kids.
Here's a view compared to the regular cannons on the gun deck and the carrondes.
Note height differences of the bow chaser, regular cannon, and carronade.
- mtaylor and billocrates
2
Hrs 683-690
To temporize I made a trap door, just have to figure out how to conceal it.
The bulwarks are a little bit of a challenge. The carronades are significantly taller than the included cannons from AL although they should be 24 pounders by scale. So I have to increase the size of the upper bulwarks.
Also, after looking at the painting, the gunports are not red on the upper deck on the outside, so I had to repaint them.
And the inner bulwarks
Off to take a little vacation and sit in the sun playing golf with college buddy in Palm Springs... 81 degrees vs 8...some choice!
- billocrates, mtaylor, Jason and 1 other
4
Greater Weevil
Lesser Weevil (naturally)
Spotted Dog
Lobscouse
Six more...
Nelson's Salt/Honor/Duty
Death to Boney
Spanish Flea
Blaster
Bollocks
Marine Mauler
I'll keep thinking...
Any name suggestions from the blogosphere?
(For the cannons, not my singing)
I like the music Jerome! Course if I played it while Iworked, the dogs would howl...
I wish youtube was a little higher resolution, but it is nice to see the Surprise come to life. Thanks for the find.
Thanks Jason. Looks like I'm going to have to figure out hour to put two stern chaser ports in. Hmmmm. Hate to disturb the transom ast it is handsome (rhymes too). Will have to think on it
Thank you Scott! I try, it's a learning experience every step of the way.
I'm thinking of putting a trap door in on the deck to be able to show off the captains cabin. Mulling it over in the ol' noggin...
Hrs 671-675
First a pic showing the washer screw I added on the end of the foremast and mizzen. Seems to work.
Added the plywood underlayment with camber.
Cut out the 7 carronade positions on the starboard (right?) side. Of course the AL kit has the uprights exactly where they are on the Lavery plans... grrr.
Am building a carronade from the Caldercraft kit to see what the size is compared to the ports. Am going with yellow as I did the same for the other guns. I think I might name them too...
Question for gurus: for sternchasers, did they have permanent ports cut out? Or did they chop them open as needed? Or did they simply put the guns at elevation and shoot over the rear bulwarks?
- klimi, billocrates and mtaylor
3
Good idea. I sort of extended it by adding a screw into the end with a washer then loaded glue in and on top so it has more to grab on to. The holes I drilled into the new mast placement areas are not perfectly squared down so its more v like. Worked so far on the forward mast.
Am adding the plywood underlayment with camber in the middle of around 4 inches to scale.
The other thing...this thing is BIG. The picture is 55 cms (22 inches long) in frame and the ship dwarfs it even without the bowsprit.
I may have to build a room for it...
Hrs 662-670
Finished the masts! Of course I made a mistake and had to take down some stuff and redo it, but a least I am done. I think I will place the masts and do the quarterdeck...I am in need of something different. Plus the yard and rigging look hard to do...
Been thinking of placing the masts and I think I need to add a screw or something solidly in the base as the bottom ends are a little short. Then epoxy in place and allow to solidify for 24 hours.
- mikeaidanh, mtaylor, billocrates and 3 others
6
Hrs 651-661
I'm getting faster on the second mast. Mainmast done in similar fashion.
Now working on Mizzenmast. Diameter is 0.37 inches or 3/8 of an inch with a little sanding.
Doubling area is 1.1 inches, squared down to fit cap. Thought I'd show how I do it with a my Dad's plain old file and some sanding.
Also, marked the front and flattened the sides slightly
2
2
After consulting the gurus, I have decided to try one mast seated now and one mast completed with yards seated later. Both Mtaylor and Gil Middleton said they have done it both ways and had success. Since this is an opening ship build for me and I don't know better, I'll try both techniques.
Have finished foremast (pics to follow). Question: Is it better to place the yards now or put into ship and add yards later? Beginning mainmast...
Hrs 625-637
Masts are not just sticks poking out of the hull...
Foremast
Working my way through the instructions and using a couple generic sources for hints. Applied styrene rings to mimic iron reinforcements as mentioned above. Then applied wooldings using thread at 3 inch scale using bamboo flute knots to bury knots. Not perfect, but the first tries...
Bottom view of platform showing cheeks, woolding
Top view of platform showing eyebolts. Unfortunately the black is so dark I had to remedy with a lot of exposure so background is very white.
And the doubling area with fore topmast and cap
A couple are upside down...
Then the topgallant platform is under construction
The vocabulary is pretty arcane and the directions are sparse so am using the modeling books for help. It all starts to make sense after awhile thankfully.
And the young lad is rowing at the Pac-12 Championships. The team took 3rd, his boat took 5th. Another way to move across the water
- billocrates, avsjerome2003 and mtaylor
3
Hrs 611-625
Revamped the lower foremast and have put on the metal hoop reinforcements using styrene. Have had difficulty getting them to stick together using cya glue. Tried Plastic model glue with no better success. Eventually got them in place but it was slow going.
Put the side reinforcements on above (cheeks?) and square cut the coupling area and test fitted the cap on top after cutting to the right length.
Then started building the platform and discovered the sapele/mahogany is brittle and cracks easily. After repairing and covering got it together pretty well.
Drilling the holes for the ropes to go through and the ironwork is not easy as the exact precise vertical angle is really hard to maintain so some of the holes are not exactly even. I am hoping the rope work will cover the minor errors.
Second layer of paint and done!
- ianmajor and billocrates
2
After working on the foremast I have come to realize the mast is going to be disproportionately too large. So after thinking about it, I measured the greatest beam of the model itself which is 7.75 inches. Using that, I will recalculate all the masts.
Lower Mainmast is then 2.28 x 7.75 inches long or 17.67 inches long
Lower Doubling is then 0.13 of this or 2.3 inches long
Topmast is 0.58 or 10.25 inches
Upper Doubling is 0.06 or 1.1 inches
Topgallant is 0.31 or 5.5 inches
Total is 17.67 -2.3 + 10.25 - 1.1 + 5.5 = 30.02 inches
Lower Foremast is then 17.67 x 0.9 or 15.9 inches
Lower Doubling is the 15.9 x 0.13 or 2.1 inches
Topmast is 15.9 x 0.57 or 9.1 inches
Topmast doubling is 15.9 x 0.06 0.95 inches
Topgallant is 15.9 x 0.29 or 4.6 inches
Total is 15.9 -2.1 + 9.1 - 0.95 + 4.6 = 26.55 inches
Lower Mizzenmast is 17.67 x 0.84 = 14.84 inches
Lower Doubling is 14.84 x .095 or 1.41 inches
Topmast is 14.84 x .43 or 6.82 inches
Topmast doubling is 14.84 x .095 or 1.41 inches
Topgallant mast is 14.84 x 0.22 or 3.26 inches
Total is 14.84 -1.41 + 6.82 -1.41 + 3.26 = 22.1 inches
Will try with dummy masts to see if it looks right.
2
Found another source, Ship Modeling from Stem to Stern by Milton Roth. He quotes Mungo Murray for determining the length of the Mainmast and divides the Mainmast into the Lower, Topmast, and Topgallant mast.
For a 1750 ship (next point is 1850) the Lower Mainmast is 2.28 x Beam or in this case 2.28 x 35 feet or 79.8 feet. So to scale of the model, this would be:
Model Lower Mainmast/Model length = Ship Lower Mainmast /Ship length
or
Model Lower Mainmast = Model Length x Ship Lower Mainmast/Ship length
" " " = 34.25 inches x 79.8 feet/130 feet therefore
Model Lower Mainmast = 21 inches
The Lower Doubling (Overlap I guess) is 0.13 or 2.73 inches
The Topmast is 0.58 of the Lower Mainmast = 12.18 inches
The Upper Doubling is 0.06 or 1.26 inches
The Topgallant mast is .031 or 6.51 inches
So the total length is 21 - 2.73 + 12.18 - 1.26 + 6.51 = 35.7 inches
Now that is in the ballpark of 31.62 inches from the Lavery drawings! (Especially as I am guesstimating the distance to the gun deck...)
I am happy with that...
Mainmast diameter is 27/28 of each 3 feet of Mainmast length. So at 79.8 feet/3 = 25.65 inches in diameter. At 1:48, then the diameter is 0.53 inches.
The mast also needs to be tapered to 3/4 maximum thickness at the Top Trestletree doubling.
Progress!
Foremast is: 21 inches x 0.9= 18.9 inches
Lower doubling is 18.9 x .13 = 2.46 inches
Topmast is 18.9 x .57 = 10.78 inches
Topmast doubling is 18.9 x .06 = 1.13 inches
and the Topgallant mast is 18.9 x .29 = 5.48 inches
Total length is 18.9 -2.46+10.78- 1.13+5.48 = 31.571 inches
Foremast diameter would 79.8 x 0.9 x 27/28 = 23.1 inches at 1: 48 = 0.48 inches
Mizzenmast length is:
Lower mast is 21 inches x .84 = 17.64 inches
Lower doubling is 21 x .095 = 2.00 inches
Topmast is 21 inches x .43 = 9.03 inches
Topmast doubling is 21 x .095 = 2.00 inches
Topgallant mast is 21 inches x .22 = 4.62 inches
Total length is 17.64-2 + 9.03 - 2+ 4.62 = 27.29 inches
Mizzenmast diameter is 15/22 x 79.8/3 = 18.13 inches at 1:48 = 0.37 inches
To bed... ;0)
2
HMS Surprise by Mayohoo - Artesania Latina - Scale 1: 48 - after Aubrey-Maturin series - First wooden ship build
Hrs 706-720
Working on forward bulwark details including the openings for the bow chasers and the catheads. Also the half circle, large square and small square on the Jotika model (not exactly sure what they are for, but what the heck). Unfortunately, one of the AL braces is right in the middle of one so I sized it down a bit.
So cut outs of the gun ports for carronades
and the other openings, all of which are lined.
Painted and covered with the railing.
Slow and steady wins the race...
