Everything posted by scrubbyj427
Excellent work Rusty! looks fantastic!
- 642 replies
- winchelsea
- Syren Ship Model Company
Thanks Chuck. What exactly do you mean by feather board? Just something to hold the plank that’s being cut, down? It seems as you get close to the end of the cut the large board wants to dive into the blade and then it screws up the next cut. By the way, what blade are you all cutting with? Thanks, JJ
Finally got some lumber nailed to the side of this thing. Good thing this is going to have another layer over the top, there’s going to be just a little filling at the bow. How are you guys ripping your planks? Are you setting the rip fence once and just pushing the block through or are you moving the fence each time? I need to perfect ripping yesterday! JJ
Model looks great Rusty! Curious to know what red you used on your gun ports as I’m getting close to that stage. JJ
- 642 replies
- winchelsea
Looks really nice Rusty. I’m just a few steps behind, carefully following. JJ
- 642 replies
- winchelsea
Last night and today I worked on the stern frames, that was a little tricky, I stared at it a lot and constantly was making adjustments in fear of getting something a little off. I think it turned out ok though. Lots more sanding tomorrow and hopefully onto the quarter galley framing. Im not quite certain of the lower sills on the transom, I installed them perpendicular to the frame where they sit, should they be more towards horizontal?
Finished all the port framing today, just need to add the vertical frames tomorrow and fair it up. Hopefully I can get the stern frames mocked up this weekend. That Byrnes saw changed my life! I also corrected and error I found on frame 28, I noticed that it shifted over to the stbd side so everything was high on the port side, thankfully it was easy to correct by softening the glue and clamping it in its proper location until dry again.
I really like how Minerva is finished, I’ve seen the model up close many times and it’s very attractive. Dubz, I like the idea of painting the blue and then printing a decal set and maybe finish over the whole thing with a satin polyurethane to blend it all together. JJ
- 1,784 replies
- winchelsea
I started adding the laser cut lower framing today it’s going ok but I ran into some big adjustments on #3, I had to take off around .0625” on each piece to get the ends of the bulkheads to match the measurement at the BF and bulkhead intersection. Did anyone else experience having to trim these parts up at all? I feel like these parts should be gimmies... My new table saw should be here tomorrow and I can start making some more frame pieces. JJ
Outstanding work Chuck! Can’t wait to get to this point. happy thanksgiving all! JJ
- 1,784 replies
- winchelsea
Think I’m pretty good on the stbd side, planks seem to be laying down nicely. I may have to make some minor alterations at the Lower bow after I start the upper planking down to the whales. At that point I’ll have a better idea of the actual runs of the lower planks. There’s very little signs of laser char left and where there is char, the planks are laying down nicely.
