Kris Avonts
Everything posted by Kris Avonts
  1. An even less expensive source is the cyclopedia of Abraham Rees, that you can find on the internet: https://en.wikipedia.org/wiki/Rees's_Cyclopædia. At the bottom of that page, you can find the section 'digitised copies' where you can find also images of the plates. I attach here plate I so you can see what to expect. I also found an even larger copy but that is a bit too large (40MB) to show it here and apart from a more flat scan of the plate, the readability of text is the same. Best regards, Kris
  2. This is what Brian Lavery has to say about the subject in 'The Arming and Fitting of English Ships of War 1600-1815'. So for Bellona, I would go for the sides of the ship between the gun ports. best regards, Kris
  3. Hi Duck, If you want a plain 2D drawing program that is free, you can take a look at DoubleCAD XT5 which is an AutoCAD LT look-alike. If you like to work with a sketcher and use constraints, then I also recommend FreeCAD which just reached a 1.0 version. It is free and allows you to make parametric designs. As with every 3D CAD program, if you have no experience yet, the learning curve can be quite steep. Good luck with whatever choice you make. Best regards, Kris
  4. Hi Olli, There is a replica build of Duyfken and you can google for pictures. Here are some: You can also see some detail here from Batavia 1628: best regards and good luck with your lantern, Kris
  5. The proportions for masting and rigging as mentioned in James Lees book were also discussed in this topic here some time ago: On that occasion I looked into the spreadsheet 'Masting and rigging' made by Danny Vadas and corrected for some of the mast lengths and diameters. Thanks to ccoyle it was then also updated in the Articles Database. I hope you find what you need. Best regards, Kris
  6. Thanks Toni, the corrected spreadsheet will reach more modellers that way. I'm happy that I could be of help in this matter so that correct dimensions are available to everyone. If people have doubts about resulting values from the spreadsheet, you can always contact me to have a look at it. best regards, Kris
  7. Hello, Because the Danny Vadas spreadsheet is so helpful, it deserves to be fixed for the period 1670 to 1710 that was mentioned by Allan (not Greg of course, as I wrote in a previous reply). Going over the formulas for that period I encountered the constant 8.2296 that was used in a comparison with a value expressed in feet. Now 8.2296 is 27 feet in metres and that is strange because mixing feet and metres can never give you a correct result. The subsequent addition or subtraction to the mast length in feet also used the constant in metres. That can explain why the results are judged way-off by the experts here on this forum. So, lets fix that and check if the results are more in line with expected dimensions. To do that I need some data the enter in the spreadsheet. A Wikipedia search delivered me the following data for 3 ships in that period to cover all cases that need to be handled in the spreadsheet (beam > 27 ft, < 27 ft and = 27 ft). These are the selected ships: The Royal James will be used to check the case ‘beam > 27 ft’, the Greyhound for case ‘beam < 27 ft’ and for Sapphire I will cheat and set the Beam to 27 feet to check the last case. These are the results from the original uncorrected spreadsheet: And these are the results from the corrected spreadsheet (except sprit topmast diameter, see later): I have no data on the mast dimensions of the 3 ships I used as a test but if someone here on MSW can evaluate these figures, I like to hear your comments. The original spreadsheet did produce the correct mast length if you set the ‘Metric Entry?’ input to ‘Yes’, and you entered all values in metres. The mast diameters are however always a little under the correct value, as I did explain earlier in this thread (see #26). Another issue I see for ships of the time period 1627 to 1719, is the diameter of the sprit topmast. According Lees, it should be in relation to the sprit topmast length but the formula in the original spreadsheet references the AU column which has the fore topmast diameter. So that was also corrected. Here is the corrected spreadsheet: Masting and Rigging-DV-open-corrected-KA.xlsm I did not take a look at the tops, yards, stays and all the other ropes, so be careful and check if you can. Best regards, Kris
  8. As promised this morning, I can now provide you with an updated version of the Danny Vadas spreadsheet. Masting and Rigging-DV-open-corrected-KA.xlsm This version should produce correct diameters for all masts. Next I will also do a check on the 1670 - 1710 period that was warned about by Greg. Hopefully I can find some issue there and make a correction. It would be of great help if anyone could provide me with real data (beam, length of keel and depth of ship) of a ship from that period. best regards, Kris
  9. Just an addition: do not use the above provided excel, it has no correction for the fore mast diameters. I will provide an update of the excel file soon. best regards, Kris
  10. Hello, I found this topic while searching for mast and rope dimensions and I also already downloaded the spreadsheet made by Danny Vadas from the Articles Database. It's a well appreciated effort by Bob Fraser to provide this spreadsheet in an open form so one can look at the calculations done under the cover. That is why I’m reacting in this topic. I think that almost all masts diameter calculations are slightly under the value that results from the rules given in the book of James Lees. Let me explain a bit more in detail what I think is the problem. I entered a beam of 46.83 ft for a 3rd rate 74 gun ship in the 1769 section. According to Lees rules for that period ‘main mast to length of beam is 2.27’ and from that length, its diameter is ‘15/16 inch per 3 feet in length’. That gives me: 46.83 ft * 2.27 = 106.304 ft for head to heel length of the main mast and (15 / 16) * (106.304 / 3) = 33.22 in = 2.768 ft for its diameter. The results from the Danny Vadas spreadsheet are shown in the next screenshot. The mast length is spot on but the diameter is about 3 inch shorter. Then I looked at the spreadsheet formula for the diameter: ‘=(Z89*($AR$2*(15/16)))’. The Z89 is a cell with the calculated mast length value and $AR$2 refers to the cell AR2 that is preceded in the spreadsheet by the explanation ‘Inch to 3 Feet in Metres’ and has the value 0.0254. I expected this to be (1 / 3) * (1 / 12) = 0.0278, the combined division by 3 for the mast length and by 12 to get the result in feet like it is displayed in the Masts and Tops page. The strange thing is that cell AS2 has that constant 0.0278 but is not used. The next image shows a graph where the value of cell AR2 is used. So that is about everywhere. And this one is for the use of AS2. No graph could be shown because there are no formulas using that value (in Dutch in the image). To me it is now clear that we can only get the correct diameters (and all other proportions derived from the diameters) when we switch AR2 and AS2. That is what I have done in this excel sheet. Masting and Rigging-DV-open-corrected-KA.xlsm Because the error made in the original spreadsheet is less than 10%, I think it was overlooked. In any case, the Danny Vadas effort is a massive help to every modelship-builder. The Masts and Tops result page now looks like this. I hope this helps for all who are looking for masting and rigging dimensions. Best regards, Kris
  11. Hi Rafael9, After a little googling: And here is a link to this motor: https://www.batteryspace.com/dc-motor-heavy-duty-90v-dc-motor-40w-2000rpm.aspx If your data is correct it should be a match. Also the 2000 rpm is what is reported for the Byrnes sander with variable speed control. I hope this helps. best regards, Kris
  12. Hi Daniel, Sorry for this delayed reply to your question. Yes the zero button works as expected so you could use it the way you describe for each next 6 mils. But I would do it just by moving form 0 to 6 then 12, 18 and so on. You may have noticed that I removed the button 'metric/inch' since I never use inch measurements. I have found this DRO very useful when milling some larger cavities and also for making holes that need to be positioned at accurate places from one another. Next pictures show examples. The only negative issue I encountered so far is that with larger workpieces on the mill, it can be difficult to see the readout. In that case I use a small mirror but that of course gives a 'mirrored' image. I know there exist digital calipers that have an output with serial data (clock and data signal) so that you could capture it with a small microcontroller and direct the information to a better placed display. I checked but mine did not have such interface. best regards, Kris
  13. Hello, It’s time for some evaluation of this modified proxxon KT 70. As a test I made a setup to use the xy-table over its whole range with fixed steps in both x and y direction. In x it was 8.9 mm step and in y 3.1 mm. That way the whole range is covert with 15 steps. I use the scale ring to make the steps and note the DRO display values. Here you see the setup with a camera positioned to show the readings. This is how the table is stepped from bottom-right to top-left. I also did the inverse movement from top-left to bottom-right and again noted all displayed values. When entering the values in a spreadsheet and plotting things you get the following results. You can see that the curves are not ‘flat’ and that moving up and down follow a different path. Not flat means that the pitch of the xy-table is slightly off its nominal 1 mm. In the x direction we have about 0.3 mm error after 120 mm and that can be explained with a pitch being 0.9975 mm. For the y direction it is about the same result, a pitch of 0.9980. The different paths are a result from backlash, that is ‘play’ between nut and screw. For both x and y it is about 0.1 mm. I assume the DRO is correct and has no play. To be sure I also checked a small movement (8 mm) in the x direction somewhat in the middle of its range with a dial indicator. The result is shown next. The dial indicator and the readout give almost identical values. Ok, then I trust the DRO from now on. It is convenient because it keeps track of the millimetres already moved and it eliminates the backlash error. That is it for now, hope you liked it. Best regards, Kris
  14. Hi Mike, I understand your wish to position the display at a more convenient location. The display is an LCD type and requires a large amount op signals to display the information. The power and signal connection to the pcb is done with a 'zebra strip'. That is a kind of foam with alternating layers that are isolators and layers that conduct current. It is compressed between PCB and display, so no connector is used. On some PCB's of digital calipers you can find 2 interface signals intended for connection to a remote interface. These are clock and data signals. In combination with a small microcontroller board (e.g. Arduino) you can then decipher the data and put meaningful values on an extra display. This type of caliper had no such interface. So I had to use the display as it is positioned over the ruler. You are right, the Y-axis hand wheel is very close to the readout but it is possible to use it. I should have cut the extruding bulb before mounting. That gives about 5mm extra play. Now that it is already glued in place, I leave it as is. I'm glad you like my report on this modification. best regards, Kris
  15. Hello, The next thing is to make a hole at the right of the cast aluminium block where the dowel pin will be inserted. I made a quite complex setup to drill that 3 mm hole as correct as possible. First job was the fixation of the xy-table to my work surface and checking its squareness (see the next picture). Then a rather unusual setup for my drill press where the base was turned to the back and using a counterweight to stabilize the drill press. That went well and the dowel pin fits with very little play. As a last adaption for the Y-readout, I soldered some wires to the metal battery clips in order to power the readout from a power supply. That should avoid battery replacements in the future. The X-DRO was made following the same principles but the ruler will be fixed to the mill table with a support instead of a pin. The next picture shows the readout already prepared with wiring, the ruler and both supports. You may notice that I cut away some plastic at the battery location to bring the readout as close as possible to the X-table side. Then the supports need to be fixed. The ruler support is attached to the mill table. With the threaded hole for the readout support I had bad luck. The M3 tap broke off but there was just enough of it sticking out so that I could remove it with a good forceps. The next picture shows the parts of the X-DRO ready for glueing to the mounted supports. Then with some metal epoxy glue all parts are glued, compressed and left for 24 hours to allow the epoxy to cure to its final strength. As a last addition I soldered the wiring to a small step down converter that will supply the 3V DC for both readouts. At the back is now a connector that mates with an old 12V DC supply of a laptop. Here is the finished KT 70 with its added DRO. Next time I will try to report on some test regarding the precision of this setup. Best regards, Kris
  16. Hello All, I use my Proxxon micro-mill a lot when it comes to precise shaping of wooden parts. The complete setup consists of a MB 200 drill stand, a MICRO compound table KT 70 and a 230V ISB/E drill/grinder. One of my frustrations with this setup is keeping track of the position of the end mill relative to the workpiece. How many turns did I already gave in the X or Y direction? Of course each decent mill is equipped with a Digital ReadOut system (DRO). But adding such hardware to the KT 70 is not obvious, especially because the KT 70 is a ‘MICRO’ xy-table. I also didn’t want to spend a lot of money on it, so I parked it in a wish list. But then I saw that digital calipers were sold at 7.99 euro in a supermarket. I couldn't resist and bought 2 calipers guided by ‘it’s now or never’. So I will describe here the process of adding these calipers to the KT 70. It is certainly not the only way to do it but it is what worked for me. And maybe it can inspire other members. So lets start. The first thing is to dismount the complete caliper. Then the metal parts need some cuts. I used a small hacksaw but soon experienced that the metal was quite hard and I had to replace the saw-blade twice before finishing the job. I was afraid that these cuts would disturb the measurement principle. I quick check gave me piece of mind. Then you have to decide where you want to attach the ruler part of the caliper and where the readout unit. After some puzzling, I decided to position the readout units close to the respective hand-wheels. The ruler then needs to be attached to a moving part of the xy-table. For the Y-direction I will use a 3 mm dowel pin glued in a filed grove at the ruler end. To mount that Y-ruler as low as possible, a small cut had to be made at the right front corner of the xy-table. This way the Y-ruler can be positioned horizontal as the check on the next picture illustrates. Next the Y-readout needs a support. I found a complex metal (zamac) part that could be used when all excess material was cut away. It will be fixed in place using the right screw (original screw replaced by a longer one) in the lower cover. That is enough work for today, have a nice evening and see you back soon. Best regards, Kris
  17. Hi Wefalck, You are right, it was a serious challenge but I'm glad I could make it to a usable tool. In a 3D cad program it all seems very simple (no tolerance and no misalignment) but in the real world it requires some skills to get it done. Your solution is indeed simpler and very robust. For me it comes a little too late. I hope my tilting table will serve me well for upcoming ship projects. best regards, Kris
  18. Hi All, After the metal epoxy glue had set (24 hours), 2 bolts are added just to be sure it will withstand vibration and forces during milling operations. Curious about the outcome of the glueing I measured the misalignment. As you can see in de following picture there is a small gap (0.1 mm) between the highest point of the cylinder and the tilting plate. Next was again a check of the flat surface on the xy-table over a 50x50 mm area. I was disappointed but the inclinometer showed it as ‘flat’, so I will accept the result and start making the last parts: the 2 plates that lock the tilted plate in position. The tilt-locker plates have an arc at its top and a slit also in the form of an arc. All arcs have the same centre point. First I start with marking and drilling 3 holes as a reference. To mill the arcs I will use a jig that I already made earlier and consists of a base plate with 5 positions, spaced 20 mm apart, that can hold a pin that will act as the rotation centre. The next picture shows it on the xy-table. For wooden parts I use a plate with some sandpaper glued on it and lots of holes that have an M4 nut at the back of the plate. A workpiece can then be fixed with some small clamps. For the metal tilt-locker parts I need firmer clamping, so I will construct a different plate from a scrap piece of MDF (shown bottom left in next picture). It starts with marking 3 positions: 2 holes of the tilt-locker and the centre of the arcs. For the arc slit, a number of holes along the arc are marked and drilled. Next I use my mini saw to cut off some excess material of the plates. Then both plates are fixed on the piece of scrap MDF. Milling starts with positioning the base MDF plate: the centre pin is mounted in the proxxon mill and lowered to make a fit in the middle hole of the base plate. Then the base plate is fixed in place to the xy-table with the 2 sunken bolds at its sides. The proxxon mill is brought up again and the centre pin replaced with a 2 mm end mill. The center pin is now placed in the lowest hole. That makes the distance from rotation centre to end mill centre exactly 40 mm. From there the y position can be set at the required position to start milling, see next picture. The result of milling: For the final shaping of the tilt-locker plates I convert my mini saw into a mini disc sander. The finished parts are shown next (you can see that at least 1 hole was drilled a bit to much off centre). And here is the tilting table, set at a 20° inclination. It can hold the MS4 machine vice as well as a small rotating table (if I ever need that extra degree of freedom for a workpiece). As a last tip to set an inclination with good precision, you can use a long M4 bolt to make fine adjustments before tightening all 4 M3 bolts. That ends the making of a small tilting table. Hope you enjoyed it and maybe you start making your own. Best regards, Kris
  19. Hello All, As announced work on the tilting table now concentrates on fixing the bad alignment of the pins that connect the tilting table to the bearings. The ‘plan B’ is presented in the next figure. As you can see the 2 pins are replaced with 1 cylinder that is mounted to the tilting plate with a V-groove. The 1 cylinder will result in better alignment to the bearings. But that shifts the problem now to the fit of the cylinder in the V-groove. I have no equipment (larger mill) to make this accurate groove. So I will make it to the best of my abilities and use a clever interconnection technique to join cylinder to the tilting plate. First things first: the V-groove. I first removed both steel pins and then cut off a small strip of the edge. This is to assure that the new cylinder which has a 6 mm diameter will be in the same position then the former pins. Next is the V-groove that I will make with 2 saw cuts at 45°. For that I need a fixture to hold the tilting plate at 45°. The fixture is made of some scrap wood glued together and then sanded a bit. It is not perfect at 45° but will do. Then the V-groove can be sawn. The next close-up of the V-groove show that it is far from perfect. When the cylinder is pressed in the groove it shows small misalignment to the top or bottom of the tilting plate. Then I realise that gluing the 2 parts together can compensate for the misalignment on condition the I can position both correctly to one another. So lets start, the next picture shows all parts involved before gluing. I have 3 dowel pins that are ground accurate at a diameter of 3 mm. That is exact the distance between base plate and tilting plate in horizontal position, see the picture below. The 2 dowel pins under the cylinder will support both the cylinder and the tilting plate so that they are level. The 2 small plates at both sides of the base plate will align base and tilting plate. A weight on top covering part of the tilting plate and cylinder assures that everything stays in contact while the glue sets. As a last measure I put 2 calipers set at 73.1mm over tilting plate and cylinder at both sides. Now I hope I cancelled most sources of bad alignment. The whole setup is shown next. Now its time to take a break and cross my fingers. Best regards, Kris
  20. Hello All, This is my mini proxxon mill. It consists of a MB200 drill stand, a KT70 xy-table and a 230V ISB/E drill/grinder. I already added an extra z-control on top of the drill stand as you can observe in the next picture. Milling small wooden (or aluminium) parts to precise dimensions is possible but you must take into account that total run-out at the end mill can be up to 0.2mm. From time to time I need to do milling at an angle and I used to make small wedges to be placed under the workpiece. An example is shown next. It requires some calculation of the wedge dimensions and precision sawing to get it right. The problem is that a next piece more often then not requires a different angle and a repeated effort to make the wedge. That is the reason I want a small tilting table on this mini mill. Looking around on the internet, I could not find any suitable solution for such a small mill. So I started my CAD program and tried to design something that would support the MS4 machine vice at an angle. See below an animation of this design. And here is a view with all parts made semi transparent. So I started construction. First ordered some aluminium parts of different sections: 6x70 mm for a base- and the tilting-plate, 3x20 mm for the bearing-holders and 2x15 mm for the locking plates. The base and tilting plate were sanded to make the surfaces clean and flat. Then some machining followed: threaded holes for M3 and M4, 10 mm holes for the MF105zz bearings and 4 mm holes for the cylinder pins that connect the tilting plate to the bearings. Here you see some finished parts. These parts could be assembled and checked on the xy-table. While the result was quit good (< 0.1 mm over a 50x50 mm area) I could see that when tilted the tilting plate moves different left compared to right. That is because the holes for the cylinder pins are not positioned equal at both sides (see next picture). I already noticed that the 4 mm drill was wandering a bit to much at 1 side when making the hole. Also drilling the 10mm holes in such small parts is not easy to keep them at the wanted position. I tried to fix things by enlarging the M3 holes to 3.5 mm in the bearing holders. It helped a little but not sufficient to meet my requirements. So it is time for a ‘plan B’ to fix this. But that is for a next update. best regards, Kris
  21. Just as a check for the angles, I made a superposition of the top view in the pdf document over a contemporary drawing of 1775 (see post #8 in the 'Gun Carriage questions' thread). The image from the pdf (red colour) was scaled, respecting the ratio, to align both wheel axles. The comparison of the angles seem to give evidence for druxey’s observation. best regards, Kris
  22. Hello James, I just tested the fix and it all works again. Thank you and best regards, Kris Avonts
  23. I get an error when I wanted to make a reply to a post. This reply had a link tin it to a previous post I made in October 2022. After pasting the link, it was replaced by a picture of part of that reply. When I hit 'Submit Topic', I get 'access denied'. Its a firewall issue: Any help to avoid this is appreciated. Best regards, Kris Avonts
  24. Hi Gary, I went to a local printing shop and asked if they could do binding with metal rings. I was lucky they could do that. It requires some special tool that can insert the perforated sheets in this metal ring. I prefer this binding because you can open the document at any page and it will lay flat on the table. I hope you can find a shop offering the same binding system. best regards, Kris
  25. Hi Alan, I once scanned all the articles written by David White and published in the Model Shipwright magazine. They are an invaluable treasure for information on 18th century shipbuilding. The scans are bundled into a pdf document and I printed it out to have it on my workbench. See the next 2 pictures that show the result. If you are interested in the pdf, here is a link where you can download it: https://we.tl/t-kKyChhdXqo This document is made and intended strictly for personal use. I hope you can find good information in it. Best regards, Kris
