Everything posted by DavidG
Hi Snow, I started the Occre Diana 10 yrs ago, but the work stopped with the birth of my children. This is how it looks at the moment: During the build I deconstructed the model several times as I updated/ replaced the kit parts with aftermarket or scratch build ones. Apart from the basic hull very few of the original kit remained. If you are not too critical about the historical accuracy this is an entertaining build. Wish you good luck and ask, if you feel I can be of any help. best David
the channels are precut ply parts, the slots were too big, I filled them and cut them again. The chainplates also preformed from a single piece of wire, soldered along the vertical edge. Some of them came loose, and I had to solder them. The joint must withstand drilling a hole, where they are fixed to the hull.
Guys, thank you for the nice comments and likes. The basic hull structure is done, let's paint. A ton of shiny stuff waits to be glued on. They are mixed quality, these two guys are some better pieces. In size they match the drawings, fit quite well, with no or minimal adjustment. I underestimated the time needed to paint them.
finally the framing filled with gratings cut to size. This is a scary picture to look at. By now I don't like the scale of the gratings, and can't recall why didn't I sand it properly. Anyway, it is painted black at a later stage, which hides most of the unevenness. Neither it was a good idea to paint the grating on the model, pretty difficult to cover all the holes, in and out, up and down. But the construction of the head is ready, huhh... Next, the decorations and painting and painting.
Hi Jan, thanks for looking in. You certainly set the standard how to build this kit. You are right, the scroll ended up too high, and later in the build I had to lower it. The overall headrail assembly should be at a lower position, on the other hand the lower posts (which connect the lower edge of the rail to the stem) must maintain the upward angle, which restricts the downward positioning. Nevertheless, everything could be fine if I had my figurehead level with the upper edge of the scroll, but it was too late to adjust.
now let's see a major mistake in the construction. I tried to illustrate it on the picture below - my black piece above the scroll is too short. I can't recall why. Could be a bad piece supplied, or I just screwed it up. As a result, my figurehead (of which the position is guided by the scroll cover piece) is too low, and I had to insert a filler piece to connect the yellow decorative element end the scroll cover.
the next step is fitting out the deck with various hatches, gratings and decorations. If I was to do it now, should have replaced the gratings to smaller ones. but that time there wasn't such a supply of aftermarket parts. It is one area of the model I'm the least satisfied now. In this stage the first step is also taken on the road of endless painting of parts.
after the inner bulwarks planked, the posts glued in place. there are a several hundred of them.. this is the point when the kit switches to beech strips, not a favorable move. in such a small section (2x2 mm and like) they don't hold the edge at all, and it makes cutting them nicely very difficult.
the quarter galleries are carved from a block. they are preshaped in section, but the forward profile must be carved in. a pretty difficult task, especially I used a very basic toolset. If it is inevitable to have some blood in the model... this one has mine. Seriously, do not carve hardwood, held in your hand, with a knife in the other hand. Lesson learned. The blocks finally glued in place. As they will be planked and heavily decorated, there is still opportunity to adjust the shape.
start of the second planking with the highest wale. as for the first layer, the wood was well cut, straight, and uniform in width. not uniform in color, so some sorting was needed, but now after ten years I see the planks of different color blend together nicely. The dark strips became lighter over time. A spacer, made up from the required number of planks helped to position the wale strip near the stern.
thank you for the comments. can't believe a year passed since the last update.. log writing goes as slow as building.. here is a picture of the first planking, actually my first properly planked hull. I was satisfied with it, but most importantly the whole planking was trouble free. I wasn't sure in the beginning, but it gave me the hope that I will be able to build the ship to a reasonable standard. I still like the idea to have the flow of gunports defined by the planking strips above and below.
