drtrap
Everything posted by drtrap
  1. Hi again. I'm having a look at the aftermarket carronades. It seems to me that the more comparable (with the kit standards, in length) are the 18lbs (2,1 cm). What do you think?
  2. Hi Jason and thnaks fot the feed-back! I'm thinking to use cannon 9lbs kits instead of carronade kits (standard or aftermarket). Is there anyone who believes that this option will affect seriously the whole "matching"? Thanks
  3. Well jason I thought that the below mentioned kit was your choise of the weaponry. I was wrong? C85090AK Cannon Kit 9lb 1:64 c1790 39.5mm Cheers
  4. Nothing it's fixed. I placed the captain just to estimate the relative dimensions...
  5. Hello to everyone. It's very interesting to me to know which type of guns (size and type of carronades) finally you are about to place... I'm waiting to see relative pics. Thanks.
  6. Fine Jason, I'll change my plans. I do appreciate your experience and your mind of deep insight! By the way, have you tried to order these 24lbs instead of the 32lbs ?? Thanks C85824AK Carronade Kit, 24lb, 1:64, C1795 (2)
  7. In my turn I think is better to place the tiller arm ropes first. This way, I'll be more free in case of need to modify the inclination and treads of the aft ladders later without disturbing the so closed aft space .
  8. Thank you again for replying so promptly !
  9. Jason, Jim do you have any special comment regarding the length of the tiller arm I've placed? I dont feel very safe with the plans and I'm about to start the wheel's rigging. Thanks
  10. Jason, I;m currently seeing the rigging of the wheel and tiller. Have you use wire or black rope to strap the blocks (3 mm)? The white rigging rope is of 0,25 mm? Thanks
  11. What do you think Jason for the 24lbers ??
  12. I plan to shape the swivel brackets in a "rectangular Z" fashion (profile view) to decrease the distance of the carriage to the deck and accomodate better its fixing to the sill with the pin....In my work we call this a "Z plasty". In the other hand i'm thinking seriously to buy the aftermarket carronades that Jason ordered, or alternatively the cannon 9lb kits which I prefer better. I don't know what's the reason of the "huge" (per pair) cost difference (15,29 Vs 6,71 pounds)....
  13. Hi Pete I can't locate the pic you have uploaded showing the tip with the wood removal just to have seated better the trunions....
  14. So Jason with the carronades you plan to use you don,t need to fix or mount them on the sills... Have I understood right ?
  15. That's for tonight. I'm waiting your help and thoughts about the placement of the guns. In case I'll keep the standards guns of the kit, I'll be obliged to not place in position the sills, just to decrease the hight and the inclination of the carronades.....
  16. Tiller arm in place, dry-fitted, no trimming needed. Can you estimate from the relative distances and especially from the aft platform and the last gunport whether I'm in right place to start the tiller's and wheel's rigging?
  17. The best team for me, just to create a warm and sweet matt black layer...
  18. One step before paint it black? Possibly, but for the moment I'm trying to diminish the abnormalities using my pen sander. Next step, two layers of matt varnish just to restore a kind of sea-wear walnut....
  19. I have tried temporarily to place a couple of carronades on the deck. It's clearly obvious that the 1st gun completed on the carriage is too high (and without placing the relative sills into position (!!!) ). In my opinion besides that the 2nd carriage without the swivel bracket and back wheel assembly is more suitable acoording to the gunport.... Any thought or suggestion? Possibly another indication and option to call for aftermarket guns and carriages ??
  20. I was trying all the day to deal with the 1st carronade's assembly just to familiarize myshelf, but it's impossible. So I should be grateful if you would kindly help me about the consecutive steps of this procedure. I've glued firstly the swivel bracket and the back-wheels easily but when I tried to fix and glue the trunnion brackets, the carronade and the 1,5 mm brass rod (en block) that was a nightmare.... Thank you in advance. Stergios PS: 1] Did you use carpenter or CA glue for all the above? 2] I'm very dissapointed with those cheap materials of the standard Caldercraft's kit. I would prefer to pay more just to have the opportunity to deal with precise and of upper quality basic units of the box......
  21. Hi Jason you drive us crazy every time you demonstate any extra-purchased item like the carronade carriage! I'm lloking forward for your next steps. Cheers Stergios
