drtrap
Everything posted by drtrap
  1. Another today's question: have you stropped the deadeyes using the standard kit wire? Thanks
  2. Hi Jason, and thanks for typing so much helping info.... Yes, I saw your previous post but I thought the chain length discrepancy as a theoritical complication which I should be solving away...but given that the chains are all of the same size, yes this might be a cause of concern.... I'll start to place the deadeys first and I'll see... Thanks again. Stergios PS: Why to use some epoxy and not some cyanoacrylate ?
  3. Basically, now I'm thinking to attach the wire-stropped deadeyes and chain assemblies to the channels and afterwards glue the channels on the hull....
  4. I've attached temporarily the channels in place. Learning all the time from your experience, I'd like to ask you my friends about the order of channels, deadeyes and chain-links assembly. I've read a relative post by Jim, but I did not realize exactly the right conscecutive steps of the whole procedure. Thank you in advance!!
  5. I've attached temporarily placed the channels in place.
  6. I've tried to improve the gunports profile this morning adding a second layer of red ochre paint.... Bedides the fact that I placed tamiya's tape for security, the accident of leakage to the outer (natural wood) bulwarks has happened thrice... After a couple of efforts to handle this problem I really felt that I liked that cherry-wood like "camouflage" appearance of the wood. Took the decision to extend that looking to the rest of the bulwarks using 1-2 drops of red ochre diluted in matt vallejo's varnish. I like the short-time results, I'll wait to apply a second layer tommorow trying to have a more uniform coverage of this strange-mixture and I'll see... In case of unwanted results, a more formal (walnut ?) painting of the wood will be one-way solution....
  7. Thanks to a good friend (and mate) of mine I can use the profile gauze and shape the channels curvature better. I've read the manual for channels placing, I consider that as a harmless procedure...
  8. Wow Jim sorry, I did'nt see its reference in you build log! Thanks for your help. Stergios
  9. Hi Jason, as I' m about to start the channels and drill the ringbolts holes etc Could you please please help to locate the "Rigging Period Ship Models" pages that illustrate the whole procedure? Thanks. Stergios
  10. Now, working on the pinrails skeleton....
  11. Don't worry! My next, consecutive steps are: the pinrrails, the channels and finally the guns.
  12. Jason, as always your help and comments are so precious....
  13. Copy that, Vasileios (as aviators use to say... )! Thank you. Do stay joined with the company!!
  14. I think there is a mismatch between my kit's sheets as far as parts No 50 & 55 are concerned....
  15. I can't locate parts No 165 (4 pieces, casting) on my "3 of 7" plan... Could you please upload any relative photo for understanding better? Thanks
  16. Hi Mort, this was my point of concern. I think that Jason (so many steps ahead) knows better...
  17. Thank you again, Jason! By the way, from your experience what;s the best next step you advise me to follow: placing the pinrails etc or placing, fixing and rigging the cannons & carronades? Cheers!
  18. Building like a turtle.... The slots of the capping rails (that unfortynatelly I've permanently glued) are undersized comparing to the timberheads. Should I use my dremel for a bit of enlargement?
  19. Jason, I've seen a type of spray for the dust at the yard... Is it an anti-dust type for compiouters etc? Some kind of them extrude small quantities of a liquid material (wich evaporates immediately) with the air, but I dont know whether is safe for the paint, varnish, etc...
  20. Thank you Jason, finally I did my own (custom-made) posterior capping rail.
  21. Lateral bulwark capping rails glued in place. I've left unglued only the anterior and posterior thirds just to have the option to manipulate the edges later to obtain a equally spaced placement on the bulwark's rim and a better symmetrical adaption on the anterior and posterior platforms respectively.
