Hello everyone,
I need some help, I want to make my sails to look inflated, like wind is blowing into them.
The problem is that I already installed them on the musts. Is there any way to do this withaout using wire, with some lacquer, fluid or any other way?
Thanks in advance
RaNikola
I have not tried this yet but I have a notion that a soaking in very diluted PVA and applying a hairdryer  might do the trick.
Set the vessel on whichever tack you like, put a bit of "heel' on the hull, and apply wind!
If your model is a full rigged ship then this process could take some time.
Mike.
Previous Build: LA gun deck cross section.
Previous Build: Lancia Armata. Panart 1:16
Previous Build: HMS Pickle. Jotika Build.
HMS Triton cross section 1:32.
Shelved awaiting improved skills:
Chuck"s Cheerful.
Current build.
Tender Avos.
HM cutter Alert.
I think you could apply a stiffening agent then clamp the model in a bow down vertical position. Gravity would pull the sailcloth into the billowed sail shape. I know of one case where the modeler used a plastic bag of rice draped into the sail and the weight of the rice caused the fabric to bulge.
I have had great success using a fine art supply product called GAC-400 sold by a company called Golden. Designed specifically as a fabric stiffener Its a water based acrylic and it hardens in the fabric. This product works better than white glue, better than "Stiffen-It" and "Stiffen-Stuff"( two names for the same product sold at sewing stores) and ordinary laundry starch too.
Check out my HMS VIctory build log, which is really mostly about how I am making the sails. Sails like the ones you describe, shaped like they are drawing wind.
Quote
 Niagara USS Constitution
  • 2 years later...
A long long time ago this subject was addressed some what and one molder had pic of what he did.  He made a stand ( two vertical poles) rigged the sail as if it were on the ship ( spar in place) tied the four corners to the poles with a short line from the pole to the corner of the sail, turned on a fan, filled the sail to desired look sprayed with hair spray (final net ) or applied deluded glue.  I thought this was a grate idea.
TJ
  • 2 months later...
