HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Hi
I need some help on ships boats for the Hms Victory scale 1.98
what size in mm and what sort.
the best i can fine is 1x launch 1x barge 1x pinnace 3x cutters 1@25ft & 2@18ft.
tried scaling from AOTS but the sizes don't work out!
Harvey
Current Build: HMS Victory
Harvey,
My recollection (from reading AOTS notes (I think the drawings were slightly out from the notes) and I think the AOTS notes are supported by Longridge, though I'm away from home at the moment and can't check):
Launch - 34ft
Barge - 32ft
Pinnace - 28ft
Jolly Boat - 18ft
Cutters (x2) - 25ft (these being the ones carried on the quarter davits and clinker planked).
As for scaling, the math is fairly straight forward.
If "X" is the actual size in feet, then to convert to mm at 1:98 scale:
"X"ft x 12 (inches per foot) x 25.4 (mm per inch) / 98
or, more simply:
"X" ft at 1:98 scale = "X" x 3.11 mm
So:
34ft = 105.74mm
32ft = 99.52mm
28ft = 87.08mm
25ft = 77.75mm
18ft = 55.98mm
Hope that is helpful.
Hi
Grant
Thank you so so much for the help
In the AOTS book
On the quarter davits it shows sea cutters 2 @30ft, and on the skid beams it shows 34ft launch - 28ft pinnace - 32ft barge and 18ft cutter,
but on the plan view of the ships boats I think the pinnace and cutter are the wrong way round!
I think I have got my head around what i will do. In the book the quarter deck cutters go from the back stay channels to the fire buckets measure the distance on my ship and blow up the image until I get the right size. will let you know if this looks right.
Thanks again for your time.
Harvey
Hi Harvey,
Glad to have been of help.
You're right about the drawings being the wrong way around in the AOTS book.  I'm pretty certain that the Sea Cutters are 25ft though.  Not sure of my source - I'm still away from home.
Hi
You are right about the cutter size 25ft the AOTS book must be wrong  see 17
Going to make cardboard shell of all the boats @ the new size i will post a picture when done.
Thank you again
Harvey
