What kind of 'grime'? Is it oily in nature? If so, perhaps a little isopropanol (rubbing alcohol)  may lift it. However, if the 'grime' has soaked into the wood, this may be ineffective.
Don,
A while back I happened to pick up a couple of boxes of alcohol wipes for a few dollars. You know, the kind that come in the little foil packs that Dr.s use to wipe your arm before a shot. Now, whenever I see something which needs cleaning I wipe it away before much of anything builds up.
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
I use various techniques including: alcohol (IPA > 90%), very fine sanding. 0000steel wool with alcohol. Scraping, etc.  Pre-staining, sealing etc. is a great help.
I will try alcohol wipes, intriguing idea.
Jaxboat
Edited by Jaxboat
I believe that the swabs are 70% Isopropyl OH.  That is the concentration that is
most harmful to bacteria.  The 91% probably works better for cooling and
as an after shave- if you are a nonsmoker and do not need perfume.
I predict that the cost per volume will weigh heavily against the swabs.
If removing the top layer of the planks does not work out, you could always
drop back and punt:  Stop by Wood Craft - get a packet or two of thin veneer
with an appropriate grain and cover the soiled planking with a new layer.
If you choose Maple,Birch,or Beech, it can be dyed or stained and sealed before it is
attached.  Just protect the glue surface side with masking tape or painters tape during
 the stain and seal steps, not necessary if you dye.  The veneer - you should be able to
cut with scissors and a metal straight edge and #11 blade.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Yeah Jagger....I guess your right.....for 2 cents a piece (Amazon)...the convenience just isn't worth it. J.
Member:
Model Ship World
Hello Les here. Another option is lacquer thinner. I know its volatile, but I use it in furniture refinishing to remove all sorts of contaminates. Especially oils. Gloves and a ventilated space such as outdoors I would recommend.
  • 2 months later...
Thanks everyone for the responses, just now having the time to work on my boats again.  The grime is caused by oils in my skin, so I think going forward I am going to wear gloves when building sections where the wood will show.  The alcohol wipes worked a little, but they were great in showing spots that needed further sanding.
Don
