What is the purpose of the staggered wale in Amati's Revenge? Doesn't it lose it's main purpose of strengthening the hull when its interuped in this way? I can't find any other examples like this. Chris Watton puts a lot of thought and reasearch in his models so there must be a good reason it's there. I am going to build this kit but I not sure about this feature. I'll probably lose the stern gallery also, although it does look cool with one.
Kurt
Link to comment
Share on other sites
I seem to recall a contemporary drawing or print of such an arrangement, but can't recall where I saw it. Presumably the logic is that the foremost port and hawsehole don't cut through this wale. And, as you say, Mr. Watton does his homework.
Link to comment
A few examples are there in "The art of shipwright" from Matthew baker.
post-24614-0-38252500-1486493688_thumb.pngpost-24614-0-61842000-1486493691_thumb.pnghttp://nautarch.tamu.edu/pdf-files/Myers-MA%201987.pdf
Why this is so. Who knows.
But Matthew Baker was very respected as a shipbuilder.
Groetjes
Greetings
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72
Shore leave,  time consuming projects :
a new bathroom
Si vis pacem, para bellum
Link to comment
I have a Baker print that shows this. I can't figure the purpose. I would think it would greatly decrease the wales strength, which I am assuming (dangerous I know) is their only purpose, proving additional structural strength to the hull. How prevalent a feature was this, or is this the only example? There is very little on a ship that isn't there for a definate purpose.
Kurt
Link to comment
It appears, based on the position of the one gun port and hawser hole relative to the other gun ports that there is a change in the elevation of the decks at the point.   This is seen in the picture and the two drawings.  Is the forecastle a "split level" relative to the decks in the waist?   There could be some construction detail that ties this staggered wale to the deck shelf.
Another question:  is this really a wale, or just a plank (wale or not) painted black for aesthetic reasons?  To my understanding, the wales are a set of planks, not a single line.
Lastly, I not certain that wales are always continuous.  I've studied a few plans that seem to show cuts for gun ports.
Bruce
Stay Sharp - Stay Safe
Judgement comes from experience:  experience comes from poor judgement.
  • USS Constitution: Scratch build solid hull 1:96 scale
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
