I'm new at this game and have encountered a problem that I'd like to correct in a sensible manner (i.e. I don't want to damage what I've done!).
When I planked the Bluenose bow I allowed the strips to overlap the false keel. I need to clear that space so that the stem, under-stem, and keel can be fixed to the false keel.
In the photo below I've drawn yellow lines to indicate the line of the false keel.
I can file or sand away the planks (easy), or I can try to cut them (seems tricky).  I can't really visualize which will look  ok once the keel pieces are attached.
I was considering painting the hull rather than second planking it.  I suppose I can use filler to try to fix things but I'd prefer not to have to do too much of that.
Suggestions?
Doug
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
I went ahead and filed out the channel where the stem and under-stem pieces fit.  I wasn't too difficult a fix after all.
Doug
Is the 'false' stem and keel already fixed ? If not, the sanding-down of the planking will be easier without them ...
No, not fixed, just put it in place to check the fit.  Hull preparation still in process although I'm also keen to get on with deck planking for a change.
Doug
Doug
Doug,
Your fix looks very good. If you are concerned about the rabbet, then you can glue a thin strip to the outsides of the keel  after you mount it and after that a thin strip to the bottom, a false keel. Since the planking will tuck under the sides of the thin strip attached to the keel, this will give you a real rabbet although it is simulated.
I hope this helps.
Edited by ca.shipwright
Nice idea.  Thanks very much - I'm going to try that!
Doug
Doug
Put the sides on the keel first. then the false keel bottom and sand flush to the sides. It looks better that way.
