Hi, here we go again!
What Google remembers of the old log:
____________________________________
Hello dear friends!
Not that I know any of you in person but the climate on this site the best I've ever found
So, after 20 yrs of neglect time has come to continue a POB build. The kit as such is discontinued by BB. I started the kit right after I finished Wasa 1628 but it came to a halt when it was time to do the ships boat. Well, there was this thing called raising kids also, and well a few other things too...
Unfortunately I have no pictures of the build until now. Pictures seen here is here present state. I realize that even way back then I did some bashing. F.ex, the skylights, are build ups instead of the supplied blocks of wood. The panels on the deck houses sides are an addition by me. Note, the deck houses are not glued in position yet. What really did not came out that good is the caulking of the deck. But what the heck, I will not redo it now.
About the hull, it is ballasted and floats on here waterline
Single planked also as is BB's standard for kits. It is possible to see where the bulkheads go, but it is not that easy. No putty here, just good old sandpaper. There are a lot of plastic fittings that I already back then thought of replacing and now I have the skill (I hope! ).
It will be cutter rigged, meaning single mast and bowsprit. Sails will be main gaff, stay sail, jib, flying jib and gaff topsail. Dont know if I will set them all. Time will tell.
And please, any criticism, constructive ideas or just plain old praise is appreciated!
Cheers
Håkan
The story behind the build.
At the age of 10 I received a boat kit from my dad. It was the Billing Boats Dana. While I did most if it on my own, my dad helped me out with the tricky parts. After that it took some five years before the urge to build something arose. The Kings ship Wasa of 1628 was a BIG story in Sweden (and worldwide I guess) back in the 70s. I remember the first time we went to see it, it was when it was still housed in a corrugated sheet metal shed. We went to see it a couple of times. Well, back in my early teens the only kit manufacturer I knew about was Billing Boats. Quite handy the also had (and still have) a kit of the Wasa of 1628.
So, after a summers job with money in my hand I went to the local hobby shop and lifted the kit from the shelf.
Four-five years later, after a lot of struggle, it was finally finished. We now write 1990 in the calendar.
One thing was clear to me, with the next kit, I was to do a better job. It did not completely turn out to be a pigs ear or so, (only close) but I confessed I bit off too much for me to chew with it. So, after scanning BBs catalogue my eyes stuck to a kit called Regina.
It was a plank on frame construction, but the frames were spaced very long apart I see now.
Work commenced quite quickly in the beginning, the superstructure, deck, hatchways and the planking. Yes, about the planking, on Wasa I did not really know how to handle the stem and stern. On the edge of giving up my dad stepped in to rescue me, again. Not that he knew much about building boats, be he saw the problem and understood the sparse instruction better than I. So this time, I was very careful about the planking. Reading books about how to build full scale English smacks and so. It was a tedious job but the result was well worth it.
And another close up
From the pictures name you can read the day when I first uploaded the images. In a way you can there fore follow the build in time.
More to follow
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
As most of us now, I will just write shortly about the various steps of the build and repost the images.
A few more of the state of the build when I restarted early Jan 2011.
Edited by Wintergreen
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
A bit dusty she was, but in remarkable good shape after sitting 20 years on a book shelf...and surviving 7 (seven!) home relocations. It has been the apple of my eye all the time and I've treated the hull with the greatest respect.
The next picture is wee bit funny. I decided to remove the ballast (she will never sail any seas) and turned the hull up-side-down. My now 20 year old daughter smiled ear to ear when she saw what was hidden inside...she admitted to almost having a memory of putting them there in the first place...
The anchor is a spare one from my first build of Dana.
Next up is the binnacle. From left to right; as supplied, finished, a real one found on www
And here in place on deck, just forward of the poop deck, within sight for the helmsman.
More work, the hawse holes. From the booklet:
And how I turned some furniture nuts and bolts into decent looking ones:
After blackening and mounting:
More bits 'n pieces, now on anchor and buckets.
Before some touch up:
And after, along with the first version of the anchors.
Ventilators, I did not drill out the interior, just painted them. Mounting aid is clearly showed below.
It felt good to have the life-buoy laying around, I never knew when the owner of the shoes might turn up, hollow eyed and dizzy...
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
I realise that this will be kind of a picture-diary, a word here and there and mostly pictures. Next set, the windlass parts.
On top the supplied plastic ones, to the bottom left my attempt from many years back, and to the bottom right the newly made ones.
Assembled, painted and ready to be mounted:
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
After this I started with the bowsprit. Long time afterwards I understood that this is highly NOT recommended. Think like this: Why would you attach a spear to your precious model, a spear that most inevitably will catch something and snap, leading to an oral expression worthy of Cap'n Haddock from TinTin...
Well, I can say today (201302015), when the ship is finished only waiting for its stern boat, that the bowsprit is intact. One reason for that is the tent I made for the build. My man-cave is my wood working hobby shop, and with a lot of heavy machinery the dust fog is sometimes intense...
Back to the bowsprit.
The first thing I had to do was to cut a notch in the stem for it to sit in...
Just kidding, this is the saw I used :)
And here it is dry fitted.
Building
a ship is kind of a 15 game, you know the small plate with 15 movable small plates, once in order they will make up to a picture or something. On a ship build, there is almost always something that depends on another thing, in this particular case the bowsprit and the windlass.
Here
I remember that I posted a question whether to leave the knee under the bowsprit natural or paint it like the windlass. The consensus was to paint it. So I did.
Only to receive the next cheerful update from my friend John that said that it would have been better unpainted...
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
On the theme: "Is the hull strong enough?" Not that I've build to any of Loyds or Norske Veritas certificate, but I can assure you, yes, the hull is strong enough...
Those are iron ingots, iron has a specific weight of almost 8kg/litre, that is somewhere around 10kg (18pds) laying on the deck house...
Now a short episode about enhancing supplied parts. The water(?) barrels, could well be brandy barrels filled with single malt for that matter...
The Before-After shot:
Further enhancement lead to a couple coats of clear flat varnish. The reason for that is in the picture below.
And varnished.
Next enhancement of the build was to add more bulwark stanchions. Since it was only the frames top timber that made up the stanchions and these were quite few I thought it should look good to add some extra.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
What I also replaced was the pinrails. I did not use the very soft supplied strips of wood or the turned brass pins. The scale is 1:30 (close to 3/8" - 1'), and easy to work with.
A long way down the road I realised that I was too close in tolerance between the pin and the hole...some careful work with the Dremel's flexi-shaft and a small hammer solved the obnoxious pins though.
A insane close-up of cleats
post-6-0-77588900-1413876723.jpgpost-6-0-75895800-1413876724.jpgpost-6-0-67551100-1413876727_thumb.jpg
I can only take credit for the actual performance of the work, not for the steps of doing things. All the ideas I picked up through various logs on the old site, through work of others.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Hi Hakan,
This build log repost gives me the chance to ask a question on some of your older work -- what type of wood did you make those beautiful belaying pins from?
Cheers,
Robert
Current Build: HMS Mars
hakan,
Very nice build, some very lovely details you've added. Although we have lost a lot, it gives us a chance to relive some older builds we haven't seen.
Carl
Hi Robert, thanks for the kind words about the pins....boy, which wood? The first attempt was from ordinary tooth picks, but they turned out to be too soft. The 2nd and final attempt was made from the same wood as everything else scratch built on my Regina. Unfortunately I'm not 100% sure of what it is since I inherited the slabs of wood with the workshop...my best guess is pear (probably Swedish though). It is very close grained and hard.
/H
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Thanks Carl!
I'm not done with the rebuild of my log yet so there will be more to follow later (read tomorrow).
/Håkan
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Håkan,
inte hålla mig i ovisshet för länge (do not keep me in suspense to long)  ;)
Carl
Håkan, Great to see that you are back, how did you get the google cache I have no Idea how that works.
Michael
Yes, the common truth, "you don't know what you've got until you loose it" was very apparent during MSW's downtime...
Michael, I did an ordinary search for my log, using some keywords, like Regina, Wintergreen, and so. In the resulting list, there was some kind of preview pane that had a link called "cached". It was the full first page of my build log.
I now tried to find yours and Google came up with this:
http://webcache.googleusercontent.com/search?q=cache:4tYLYwcToxEJ:modelshipworld.com/phpBB2/viewtopic.php%3Fp%3D346150%26sid%3De3072b6fbd26850c1dd798e1389e7f17+&cd=1&hl=en&ct=clnk&gl=se&client=firefox-a
Looks like the last page of your log...
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Other small stuff that I did apart from cleats, were blocks and bulls eyes. For the bullseye I used a rod of suitable diameter, drilled out the centre and squeezed into an eye bolt.
The main sheet horse and block
All of a sudden it appeared that I had a visitor in my yard...
The crowbar was a bit worrying I thought...
Next up was chain-plates and deadeyes..
After blackening.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
I tried my luck at some jigs also. First a jig to aid drilling on narrow strips.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
I would assume that the sw wanted to change page now, but not. Interesting.
Next was produce the dead eye strops.
To drill holes in dead eyes this is a fairly common setup (with variations)
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
ok, I guess the sw has the limit at 25 posts a page. The old one had 10 so this is better. Need to keep the posts a little shorter though.
A quick "how to" I turned the dead eyes.
There are various ways of setting the diameter. Since I only have a wood lathe, this is what I use.
Mark the thickness of the eye.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Chainplates installed.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Over to mast and spar making. The supplied rod for the boom was too thin so I made my own. Provided mast hoops was of plastic, replaced. Other mast rings and boom rests also plastic, needed replacement. And yes, the mast had the shape of an bow that would make Robin Hood happy...replaced.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Ironwork for the mast.
Comparison between suppliend and scratch made jaws..
Soldered, blackened and waiting to be installed.
Dressed with blocks also.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
The boom dry fitted and a bit naked. I later trimmed down the reeve boards at the end.
Here a bit more crowded with tackles of various functions.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Here is this gaff finished and the mast winches.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Bowsprit rigging.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
More sails.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
The Danish Ensign hoisted "Dannebrogen"
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
The above picture was the last in the old log. From here on I am up to date.
The boat is mainly finished (pics will come later) and work has started with the stern boat. The final picture for now is below. Remco was teased to do a proper splice for his mast pendant and that triggered me too. It WAS fiddly but in no means impossible to splice the thread.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
