how "1. profile gauge " works?
It is a stack of movable pins.  Push it against a curved object and it duplicates that shape.
One side is negative of it, the other is the positive.
The present versions are plastic and the "pins" thicker.
A potential use -  getting a precise shape for the breast hooks for a close fit - gets defeated because
most of these tools are too wide to fit inside a hull - unless a heroic scale such as 1:36 or 1:24 .
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
The profile gauge is metal with moveable pins. I usually used it to get a profile of the bottom of the hull to aid in the building of cradles to mount on building or display boards. Yes, one side will indicate positive and the other side indicates negative. I have also used it to help fair out frames.
mike
Some information on what price you wanted for them might've helped your sale?
Ongoing:
