This is my first model ship build after the Elizabethan Galleon, which was a simple 1st ship build.  This is my first build which requires planking and much more.
Here are all the parts cut out and laid out on the blue prints.  I had my local Staples make a copy of the blueprints so that I could cut them up and abuse them without destroying the originals.
FIrst drew the Bearding Lines, using the blueprint section that I cut-out and laid on top of the Center Keel.  I then drew the vertical lines for the Bulkheads so that when I go to fit them they will assist me in keeping them straight and not leaning forward or back.
keel.jpg.d31cd15b380082bf7c4ae400a7bc743f.jpg1375116326_keel1.jpg.7017a7e9addd983ae2d6f0364ae06bbf.jpg
Next i began to pre-fit the Keel, Stem and Sternpost31772897_Keel1.jpg.c6c89e8cff0fbd886ae5b6c5c149276b.jpg82981177_Keel2.jpg.ae5beb07a40c3dc181157db57684bbe0.jpg
As you can see there were some places that I had to sand to get the parts to slide together better.
This is the part that I was most unsure of.  Cutting the Rabbet.  I have only done one side so far I wanted to get some feedback before cutting any more, or beginning on the other side.
1454054980_Keel4.jpg.aa1948f0973c733366bfd5a6b268b562.jpg1002124047_Keel5.jpg.b21cf5b8cc72b101caec079d06b2b1de.jpg2115913528_Keel6.jpg.e3281b925d84bb8225dd0bcfb359b1d3.jpg
I am most concerned about the depth, width and location (Every aspect) :) .  I had read where the Rabbet cut is more of a squared off U than a V.  The groove needs cleaning up a bit, but I welcome any input on how it is progressing.
That is as far as I have gotten I am using a flat square Chisel Exacto knife to cut the Rabbet.
Thanks in advance!!
  • 1 year later...
are you still progressing this build. love to see your work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
