A question about the hull planking of harbor barges. They are basically rectangular, slab sided vessels with some sloping of the bow (?)  and stern areas from the deck to the waterline and down to a keel. Would the planking across the slanting bow/stern areas overlap the boards of the sides or would they be interleaved? The 2" x 6" scale boards (planking) are glued onto a plywood former.
I ask as I have an old Sheepscot Scale Products kit of a pile driver on a barge. Pictures are too small or grainy, even with extra light and using my Optivisor, to tell what the configuration is. Just gathering info for a future build.
Ken
Started: MS Bounty Longboat,
In my experience I have never seen any thing other than the planks overlapping the side planks.  Many times there are reinforcing boards at the edges - sometimes on both surfaces.
Hope this helped.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Maybe this is interesting for you. Found it on a pdf (the construction sequence of the princess channel wreck)
Kurt and Patrick, thank you. I planned to have the bow planks overlap the side planks. Your info validates my plan. The kit is more into the pile driver appearance versus a built up hull.
Ken
