Construction of the ship "Le Mirage" started in October 2010
Have a lot of pictures. I will post photos in small batches.
Edited by PSF
Попков Сергей Федорович
Hello (privyet) Sergei,
Thank you for starting your own buildlog of Le Mirage.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
I installed the lower right Gallery
I installed the lower deck at once
I immediately made ​​the lower deck flooring
test knyavdiged
I write special terms in Russian
Test бархоут (Russian) = barhouty (Latin) = Rubbing pieces (Englishfor trying
External casing from a nut, instead of from set Corel
The material of an external casing is sawed on circular saw FET Proxxon from a file of a nut for a parquet
The бархоут (Russian) = barhouty (Latin) = Rubbing pieces (English) is made of a nielloed hornbeam
extension
Edited by PSF
Ornaments from set Corel the bad. I will alter ornaments.
Hello (privyet) Sergey,
You did a lot work today posting all these photo's of your build.
Thank you very much.
Take care,
Anja
Sergey -
VERY nice looking model - look forward to following as you continue.
Welcome aboard!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
I welcome at a forum, Sergey! Good work, here that means thoughtful approach to model construction from a kit!
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Wow, she really looks good, you are doing a super job!  I look forward to seeing more photos.  :)
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Here that has found from photos
Such you will accept improvement?
And now windows and balcony doors
Keith left the set decoration, I made the right
later remade
