Scott,
Looks like your Phantom is off to a great start!  I am in the middle of my Phantom build as well and will be re-starting a build log soon.  Keep up the good work and try to be thorough because your build log will likely get used a lot by others considering there are so few on this forum now.
-Max
-Max
"We should not moor a ship with one anchor, nor our life with one hope."
Current Build: Benjamin Latham, Model Shipways
On Hold:  Pilot Boat Phantom, Model Shipways
Completed Builds:  Chesapeake Bay Crabbing Skiff, Midwest;  The Dinghy, Midwest;  Sharpie Schooner, Midwest
Hope you have a great day today, Scott -
HAPPY BIRTHDAY!!!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Well all i am back at it, I started cutting the wood for the launchways, I have decided to do that for now then get back to the ship. I have started to get ready to trim the keel, I am going to use the process that Hopefull did, by using the 1/8x1/8 wood and center it and use it as a guide to fair the keel.
I do have a question, for a 1/8 x 1/8 piece of wood 12 inches long how long do i have to soak it so i can bend it so it will sit on the keel
pics to follow soon
pics to follow soon
Hi Scott
It depends very much what the wood is I think
Something like Lime takes very little time at all and even a few minutes soaking in hottish water will enable shaping
A hardwood however will take a lot longer to soften, maybe several hours
Just keep taking it out and have a feel  :piratetongueor4:
Remember softwood will swell and soften quite a bit and then shrink back as it dries, so keep that in mind and also treat the wood gently
Prepare it before soaking as it does not sand well at all when soaked  :huh:
Good luck with the build  :)
Edited by Micklen32
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
thanks for the in put i forgot to mention its bass wood, at least i think so it came with the phantom kit
Well basswood is fairly soft and malleable so should not take too long
Lovely work with the launch Scott
It's coming along really well
<p> </p>
<p> </p>
When I want just a bit of protection without it really showing I have a can of spray satin lacquer
That does the job very well and with a steady hand you can put a couple of coats on without it really showing
Edited by Micklen32
<p> </p>
<p> </p>
Im still slimming the keel, ive noticed on the stern i cant find anywhere that shows how far down you trim and on the sides around midship how far out do you trim down
i can see on the midship area that it looks to be at the right witdth
any in put would be great thanks
Edited by gulfmedic1
Have you not got any full size plans with the kit you can work from??
Or if you do, do they not show what you want to see
I can be of no help as I haven't a clue
All I can do is compliment you on how well the build is going
Certainly a nice job
Edited by Micklen32
<p> </p>
<p> </p>
I unfortunately don't have any pics that will help visually,  but the easiest way to figure it out is...
Find the centerline of the keel and draw a light line the length of the keel.
Measure 1/16" to either side of that line and mark that the length (so now you have 3 lines).
The two outer lines are where you want to bring the keel in to give you the 1/8".
When shaping it you just want to bring it in and then up a little (to keep the keel) and then blend it back into the shape of the hull itself.
Hope that helps a little.
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Gulf,
I found that following the templates turns out a nice shape.  The templates for amid ship pretty much don't have you thin that area down at all, maybe 1mm to 2mm (just guessing there).  Once you get to the area of the hull leading to the sternpost area, that is where you begin to thin down to the 1/8" thickness pretty far.  Here are some pics to show what I mean.
Here is a photo of the thinned keel from the bow before the false keel was installed.
And from the stern.  You can see here that the thinned area extends down much further at this end of the hull.
Now here is one from the side showing the sternpost area where the thinned part extends down.
Now one with the hull being coppered.  the first plate on the bottom covers the false keel, then you can see where the thinning ends on the second plate.
Here you can see that even if your shaping of the hull is not perfect, the results after you copper can still look nice.  Don't mind the waterline on this side of the ship haha.
I hope this helps.  Let me know if you have any other questions or anything, I will do my best to help.
-Max
all thanks for the help sorry i didnt communiicate my question correclty
Max
thanks thats what i needed i tried reading the lines on the plans but couldnt get it right i just needed a reference to see how fat the 1/8th trim extended from the false keel
im almost done with the keel
so I have the keel trimmed and I have the markings to get the hull fared helps when you follow the directions lol
I also used a laser that Alexey i think used and it works great
now I am ready to fare the hull
Are you supposed to wear some kind of glasses when using lasers
You're doing fine.  Steady on.
Bob
Current build:  SS_ Mariefred
