Canadian Pacific Wood Passenger Cars by Realworkingsailor - 1:87 - scratch-built & kit-bashed
2 hours ago, druxey said:
Could you mold and cast from the 'good' queen post?
Metal casting is a little outside my skill set, unfortunately. About the only type of casting I feel remotely capable of even attempting would be resin, but I’m not sure how strong the resulting parts would be.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Grandt Line made plastic queen posts, See here: https://www.grandtline.com/for-the-model-railroading/ho-scale-model-railroad/ho-scale-car-detail-parts-187/
Precision Scale also sold plastic and brass ones. They're individual posts that you mount on needle beams. You have to open up their catalog, a good sized pdf.
https://www.precisionscaleco.com/
Ken
Started: MS Bounty Longboat,
I was terrified of trying to cast in metal, but when I finally tried ( in pewter) I found it was not so difficult. RTV moulds are similar to resin casting ones. The only thing with a two-part closed mold is to provide air escape vents. A regular propane torch is fine for melting the metal.
Just spent a little time perusing what was available on the Micromark website. A few different casting metals with different melt points, definitely want to avoid anything containing lead, though...... maybe something to consider looking into in the fall.
Out of sheer stubbornness, though, I will have to try to salvage at least one of the castings I received.
Andy
USF Confederacy
