Hi
Whats the best way to paint eyelets? Acrylic paints with brush tend to come off. I read that email paints should do the trick?
Also tried spray paint Mantua one but that came off really easy. Brass black is something i cant get to work.
So i would prefer painting. Is investment into spray paints now a thing maybe?
Please share your experience.
i'm sure you will get better responses from more experience people, but i believe cleaning the fittings prior no matter what you use is the most important thing.  i assume you are talking about brass eyelets...i'm surprised the brass black isn't working,  i had luck cleaning with vinegar, and doing 2 or 3 dips in the brass black.  There are many good threads on blackening.  Maybe try sanding them lightly so the paint has something to stick to?    Again, i have faith someone else will lead you in a better direction.  Best of Luck!
