Hi all
I would like to no if anyone can help me out with the build I am needing the instructions for the below. Or does anyone know where I can get it from .
DO you need both the plans and the instructions, or just the instruction booklet?
I have both, but I would have to go to a copy shop to make copies of the larger plans sheets @? expense. If it is just the instructions you need then I could make copies of the book on my home printer unless someone here advises me that this is a copyright infringement.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
See the attached files for the instructions.  I hope this helps you out:
ENTERPRISEINSTRUCCIONES-1.pdf
ENTERPRISEINSTRUCCIONES-2.pdf
Ryland
               - Nautical Research Guild
Looks like Ryland has a better way. Good luck on your build she is a nice looking ship.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Take a look in this index for Enterprise logs.
https://modelshipworld.com/applications/core/interface/file/attachment.php?id=644868
Consistent, rather than " various " scale lengths would be found most often and also look best..
Here is a pretty good example of some deck planking.
― Jimmy Buffett
On Hold:    Rattlesnake
