of course I didn't like the metal gratings and I will try to build wooden ones if I could... otherwise I will buy...
Currently building
San Francisco II by Artesania Latina
My first wooden model ship
Next building
San Francisco II Section by Artesania Latina
Wish List
US Constellation by Artesania Latina
and when dealing with the other parts of the ship I will frequently go on sanding the hull a little bit more...
Currently building
Next building
Wish List
Looks like you did a good job fixing up those open spots on the bow, its amazing what glue and sandpaper can do, my best friends in this hobby  :pirate41:
Your ship looks great, you must have an older kit, the newer kits have most of the metals parts replaced with wood, such as the grates and ladders.
-Aaron
“The World is a book, and those who do not travel read only a page.” - Augustine
Artesania Latina San Francisco II 1:90 Scale
On the Shelf:
Model Shipways Armed Virginia Sloop 1:48 Scale
-Aaron
yes I think it is the earlier version but II; grates and also ladders are made of metal :(
Currently building
Next building
Wish List
I will try to make the gratings using cofee stirrers :) but in the meantime I've also purchased some...
Edited by msberkman
Currently building
Next building
Wish List
it is a very hard job to cut the notchs; I broke at least 20 just to make a perfect one :(
Edited by msberkman
Currently building
Next building
Wish List
after all the troubles I think this is the fun part :D
Edited by msberkman
Currently building
Next building
Wish List
Edited by msberkman
Currently building
Next building
Wish List
I have only tried to fix the upper deck portholes not glued :)
Edited by msberkman
Currently building
Next building
Wish List
I began to line the inside of the bulwarks...
Edited by msberkman
Currently building
Next building
Wish List
Looks great, I have been trying to decide when I will install the rubbing strakes (before or after cutting the gunports) have you thought about it?
-Aaron
On the Shelf:
-Aaron
I cut the gunports which were the same level with bulwarks (exterior)... But after lining inside I will do the cut for a second time (interior)
Currently building
Next building
Wish List
does anybody know if I can find any plans or building instructions for the 10 cm wooden boat?
Currently building
Next building
Wish List
Look at Vulcanbombers build log for her San Fran I, she built a new wooden rowboat because she did not like the metal one that came with the kit.
You boat is coming along great!, Wood filler and sandpaper will make all those trouble spots fade away, not to mention that many will be covered by other things yet to be attached to the hull.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
yes I saw vulcanbombers boat; but I wonder if I could find a detailed drawing/template manual or some exact pattern to cut
Edited by msberkman
Currently building
Next building
Wish List
Edited by msberkman
Currently building
Next building
Wish List
I meant the gunports below the deck, the ones with the dummy doors.
-Aaron
On the Shelf:
I would suggest you PM Vulcanbomber, I am betting she could send you some sort of template.
I am working on a template of my own... I will share with you as soon as possible...
Currently building
Next building
Wish List
-Aaron
hmm; I will install the rubbing strakes before the cuttings as I think in this way it will be more shapely...
Currently building
Next building
Wish List
Edited by msberkman
Currently building
Next building
Wish List
here are the plans of my template; I hope I did it right :)
Edited by msberkman
Currently building
Next building
Wish List
I will build it as a 9 cm model...
Edited by msberkman
Currently building
Next building
Wish List
first attempt...
Edited by msberkman
Currently building
Next building
Wish List
due to shortage of time I could not deal with the boat for a while... but slowly progressing...
Currently building
Next building
Wish List
I did the outer planking with thin mahogany strips and the backing with ramin...
Currently building
Next building
Wish List
does anybody know why the size of my previous posted photos are smaller than the new uploaded ones?
Currently building
Next building
Wish List
