Well, after reading a few books:
And the instructions:
I thought I'd better get started spilling glue and sawing my fingers. I want to learn to build model fishing boats from scratch and this here, well it's the start! I hope I can handle level number 1.   😅
I'm going to keep a build log:
And will always invite a few friends over to play some music as I create magic  🤘
I checked my parts, like all professionals do! One sheet had a few parts detached by rough shipping, but nothing was broken. I'm proud of myself for spending the time to check the parts.  I'm easily confused, so I put the loose parts in a baggy with the sheet they came off of.  😁
Thanks to Miroslava for making and packing this kit for me. I think I have a new friend!
Every boat builder gotta have them tools. These here are what I start my shop with and the toilet paper is for the tears:
With any luck I won't need this one:
Following the instructions I removed the bottom planks and sanded the edges, checked fit, and decided how I would align them. When I lined up the lines for the cleats the bow and stern edges weren't really lined up well.
I decided where to line the bottom planks up and sanded the nubs and char off the edges. It's said that the char can prevent a good gluing surface, but I didn't get too crazy sanding I don't think.
I then removed the cleats and prepared them to be installed. I sanded them, althogh I found it difficult to hold them without a small hobby vice or some other implement. I used tweezers. I put a chamfer on them as well, but didn't remove all the char because they will be painted.
I found some soft wood in a couple of the cleats:
I made a couple new cleats from extra wood that was harder.
I then started spilling the glue all over. After all, it wouldn't be fun without a mess. I glued the bottom planks together by applying glue to the edges. Once put together,  I brushed the excess glue away with a watered down paint brush. I then attached the cleats to their locations and, once again, brushed the excess glue away.
To be continued...
Edited by SaltyNinja
Wow, you're making a lot of progress. You actually read all those books already? Great job thus far!
Norwegian Sailing Pram 1:12 Scale. 2nd boat in the learning series.
In Dry Dock:
Muscongus Bay Lobster Smack. 1:24 scale. Model Shipways, 3rd in the learning series.
Not sure what'll be next, probably the Santa Maria by Artesania Latina 1:65 scale. Unless someone has a better suggestion for a beginner.
Pride of Baltimore. Model Shipways. Clipper used in the war of 1812.
Black Falcon. Mantua Model. 18 century corsair brig.
CSS. Alabama. E. Manolie? Can't read the font. Build in Liverpool in 1862 for use in the American Civil War by the Confederates. Steam and sail, sloop of war.
Of all the things I've lost, I miss my mind the most.
A baseball cap my Dad wore.
You use a chain saw to cut wood. I can help with cutting the cheese too. I'm making a little progress on mine, (not the cheese) but with the wife in Critical Care, I'm not much into it. She is "supposed" to come home tomorrow, but we shall see. Her kidneys are still not up to snuff so they can't give her the BP meds because the kidneys process them. Now she's in A fib. I almost lost my beloved Admiral! The doc said another 12 hour delay and I'd be a widower! Why are nurses so stubborn about the ER?
Anyway, what color should that deck be?
Edited by Clueless
In Dry Dock:
I've been interested in this kit, so very interested to see how your build goes. I'm about halfway through reading the Milton Roth book "Ship Modeling From Stem to Stern" and enjoying it. I bet having all that foundational knowledge is going to help you with a good approach to this model. It will probably be fun to see the stuff you read about becoming reality in your model.
I sincerely hope you see calmer seas and smoother sailing soon over there 👉.
I'm going to paint the inside and outside hull the "Yellow Ochre" and the trim the "Dark Sea Green", as I'm not too adventurous.
I'm fortunate if I retain a single idea from an entire book.😆
Recording the build log takes some extra time with the writing and photos, but I think it's adding to the fun of trying to put this dingy together!
Yeah, the replies are worth it all:)
In Dry Dock:
My finished bottom planks have a small misalignment that I'll be sanding more fair at some point soon.
But for now, I'll be moving onto step 2 and 3.
I pulled the parts for the next two steps and prepared them.
I used the #11 Excel blade cutter this time, rather than the wider bladed chisel type that I used before. This was due to the smaller parts with tighter clearance for the blade. I know...genius!
I also used the back of the blade to scrape the tabs off before sanding. It saves a bit of sanding time. I read that in one of those books up there 👆, or maybe it was in the directions?
I then made up a sanding stick from this stuff...
The sanding stick came out alright, so I ended up using it a bit on the flats of the parts in preparation to be fitted.
I sanded the bottom of the stem and stern knee pieces at a 90 degree angle as the directions state. I found it easier to move the square and sanding stick as opposed to moving the parts against the sanding stick and square. I found that way to be more reliable for me. However, I figured this out after I took these photos.
That finish there 👆 is not complete, as you can see. That is the bow stem piece. When I was done with the sanding on it, it sat well and square on the mounting area at the bow of the bottom planking.
The stern knee was a different matter and it didn't come out too well. I sanded it at a crooked angle other than a nice 90 degrees, so it sat cockeyed. Yeah, the directions warn a person, but that tiny little piece felt square! I don't have a picture, but it took some fussing to get compensated upon the fixing of it to the transom and stern mounting area of the bottom planks.
I prepared the stern cleat and transom by using sanding with a small piece of 220 grit in my fingers and I used a half round diamond file to clean up the slot on the transom where a steering oar would sit. Check it out 👇
I used a couple pins to hold the transom and stern cleat holes in alignment as I glued them. The pins didn't fit real tight, but they worked well enough.
I then checked the alignment on dry fits with the bow stem piece and it's mounting area on the bottom planks.
I then checked the stern knee to the transom alignment.
I decided to glue the stern knee to the transom 👆  before chamfering the compound angles that the stern knee needs to keep the hull planking fair. I wasn't sure if this would work, but it allowed me to better see how much material needed to be removed.  the directions have you sand the area and chamfer before gluing.
I used the diamond file to chamfer the stern knee 👇
It seemed to work out alright. 👆
Next I mounted the bow stem and transom/knee assembly. I had an issue, as previously stated, with the stern knee not being a true 90 degrees at the mounting point. I compensated and used the square tool to keep it plumb as the glue dried. The following photos show the stem and transom mounted. I used the lines on the cutting mat to eyeball alignments as I went. 👇
Dude, your attention to detail is amazing! I used toothpicks that I sanded down. Where did you get that square?
In Dry Dock:
Thanks Clueless, I got the square off Amazon. I think it was $15. The toothpicks is a good idea! 👍
5 hours ago, druxey said:
Very nice and methodical!
Thank you for taking a look druxey! I think I don't mind spending the time on this because it gets my mind out of work.👏
I have completed the bending/forming of the bottom planks.
The little pieces of wood are 1/8 inch scrap from the kit. 👆
I painted some water on the bottom as instructed and placed the weight onto the planks. 👇
The result after drying overnight appears to be alright I think, but I don't remember how much bend per foot it was supposed to be?
I'm going to start setting the frames up today. But first a little mood music and refreshment. Gotta stay off the rum because I'll never get off the dock.
 This isn't the first boat I've worked on. That there is my dad's dory and that's back close to the beginning of a long journey on the sea. Take note of the Sony Walkman and all the red lead bottom paint on my hands! 😆  👇
Maybe they caught some of these on the dories? The Italians call these Bocaccio.
One more from my story and  for getting to know the SaltyNinja.
Looks like were going rock cod fishing. When I first started fishing with my dad I got sea sick every time for months. I loved it so much that I kept going until I overcame it. I would never go through that again, I'm such a wimp now! 🤓
Anyway, I started the framing steps and took a minute to look at it all before getting rolling.
I started cutting from the back because the tabs are easier to cut there I think.
I cut my pattern out of the directions book and taped it to my bench. I then fit all the pieces to the patters. I noticed areas that needed to be trimmed to fit the pattern more accurately.
The frame holder part needed trimming at the two places where the frames get glued to it. I split the difference on the tab that goes into the holder board and then made the holder frame tab area more narrow on each side with a nice little square file. I also sanded and prepared the frame pieces and put a chamfer on the edges a tiny bit. The pictures above aren't showing it well, but when the one top tab was centered the side tabs, where the frames go, were too wide so I made them fit better and put a chamfer on the corner so the frames would have more room to be properly placed.
When I had all the pieces trimmed and sanded I laid them out and decided to glue the spacer to the paper pattern with this stuff 👇
As you can see I taped the mold piece to the pattern in addition to gluing the square spacer on. I didn't use tape on the spacer because the tape would put the frame into all kind of kilter. I glued the spacer inboard too, for more secure base and purchase for the frame. Check it out 😅
I was a little better about keeping my work space clean with a vacuum, but don't suck those small parts up like I almost did!
I finished with final placement of the two frames and glued them. I placed the small weighted square I have on top to apply some gentle pressure. I didn't see too much glue running out of the seems, so I didn't brush the excess off.  I'm going to repeat this process for the other frames next as it seemed to work out well enough.
One thing I learned here is that people don't like it when you don't complete a build. The Dowry is my 4th attempt and no one is interested. I've abandoned too many ships. Well, by George I'm no quitter! I have the next two in this series. After I finish the Dowry, I'm doing the NRG half hull to learn planking before going onto the next boat in the series.
Edited by Clueless
In Dry Dock:
Sounds great Clueless! Just take your time and do what you need to do to be content with what you do. If making an attempt is what brings you peace in your spare time, then it doesn't matter if it takes a thousand and one times! Keep on the keeping on and seek help when and if you need it.
I'm on the same program as you over here, as I've got the entire shipwright series in my drawer, next to the NRG planking kit. I probably won't be finishing this little dory anytime soon, though, it takes me hours to complete the simplest steps. 🤣
Well, I noticed an issue today with my bottom planks. They've warped convex athwartships. I think I'll try to wet the center plank from exterior side of the planking, but might just wait to see the next steps. Maybe the a little heat and pressure against the center center of the bottom planks when they're mounted up to the frames will pull them flat a bit. I don't want to ruin my bottom sheer.
To correct, only dampen the concave side; in this case it's the bottom surface and clamp across. The wood fibers that side will expand.
Edited by druxey
Thanks druxey, I appreciate your time and assistance! 🎸🤘
I painted some water onto the bottom of the "bottom planks", which is also the bottom of the boat. I only wet a length or section between the center two cleats and then clamped it. I'll let it sit until tomorrow evening and then check it out. I may need to do a bit more adjusting and clamping at that time. I sandwiched the boat planks between some strong clamps and some thick scrap bass wood I had bought previously.
It was a long work day. I work in a hospital and the pandemic has worn me down after two years of it, but druxey inspired me to go out in the garage and try and correct  the minor issue noted up there. 👆
Since I was out there I checked up on my frames that I had last left to dry.
You can see that my frame joint isn't too fair and I've left myself with a bit of sanding. I tried to correct this when I was gluing them together, but I settled in the moment because I didn't have a plan or idea how to better deal with it.
Well, here we are with some DropKick Murphys pirate tunes and some deep contemplation!
I'm considering my next step, which I think is attaching the bottom planks to the frames. I decided to try and verify the frames squareness to the build board with my little square. I then thought about attaching a batten on each side to preserve the frame alignment more accurately.
I considered different ways to steady the frames where the bottom planks are going to attach and decided against battens due to the removal and sanding that may end up being difficult. I then thought of using some 200MPH tape. I tested it at the base and it seemed to to help hold them closer to square, but the flexion at the bottom portion (mounting area) of the frames was still too much for my confidence. I had additionally, considered using blocks at the build base board to square the frames, but decided the tape would suffice and I would be able to cut it and prevent possible binding from the blocks upon removal.
I then decided to run with the tape idea to hold the frames at the bottom area, in place of a more solid batten. This would facilitate easier removal and be a more simple solution. I'll see if it works out here today I think.  👀
I'll be putting the tape further up to the bottom than this photo suggests.
I made a new, flexible sanding stick and prepared to sand away. I sanded the frames athwartships, slowly and gently. The tape idea was a fail, as the frames flexed too much for them to be considered worth the time. I don't have any proper wood clamps so I used that vicegrip thing in the picture. I've got the frames sanded and ready to attach the bottom plank assembly.   👇
I then checked the bottom planks fitment to the frames. It seemed alright, so I made my plan of attack and tried to anticipate issues.
I went ahead and attempted the assemblage with cold sweats. The instructions say to use a couple of rubber bands to hold the assembly when drying. Well, 10 rubber bands must be better then?
Nope. My frames started shifting and slanting away from square and I tried to fix them before the glue dried. I couldn't get them to square up well, so I pondered my options before it was too late.
I decided to remove all the rubber bands and try to align them again. When I removed the rubber bands I noticed that the frames returned to square, or close to it, without the rubber band pressure. I decided to just use the couple of rubber bands as suggested and checked it all again. It looked alright so I'll let it dry well now.
Looking good, Salty. If you used the flexible stick by rubbing it across the frames rather than along them it would stress them less. Try that next time.
Thanks drux!
I did go transverse and it was stable enough, but I was thinking that the practice of attaching a batten would hold it more firmly. I  tend to over think most things, however. 🤓
