Sorry for the probably bad nomenclature.. I am looking now at shaping my stem/apron. From the front it seems logical - all books I have have a shape to the follow so I can print a template and stick it to the front.
What is confusing me somewhat is whether or not the depth tapers as well or is the side size the same across its length...The Swam books have a dual taper (so 14'' top to 10'' at keel) and 12'' keel to 10'' at boxing - though this looks to me more like the default keel tapering and not a taper impacting the rest of the apron?
My guess is that the side width is stable and the front width tapers around to plan. But if someone could confirm either way then that would be great..
(It's with regard to me 32 gun Amphion in case that's relevant - the sizes will obviously be larger than the Swan)
thanks, though isn't that the knee of the head?
I have must replaced my pc and my turbocad program is refusing to activate so once that is sorted I will add a direct plan of the part in question. Sorry for any confusion (though the knee information will be useful when i move to that section)
Edited by Matrim
Hope the following is helpful,  The following is from Steel  for a 32
STEM  To be moulded 1' 3"
   to be athwartships or sided at the head 1' 7"
   And to diminish from the head to the lower side of the
   lower cheek to upper cheek
To be sided at the keel 1'1" (same as the keel at the fore end)
APRON- The false stem, or apron, to be 8.5" thick (SR gives 9.5") broad as the stem if rabbet is in the middle,
otherwise 1' 7"
To give proper shift to the scarphs of the stem, and the
scarphs to be 1' 2" in length (SR - 10.5")
Allan
All the scantlings from the 1719 Establishment through Steel's Elements and Practice can be found in Scantlings of Royal Navy Ships at Seawatch Books.
Allan
Edited by allanyed
