Other than soaking them in glue, is there a way to make reef points behave? The reef points on my 1:24 scale sails go in any direction but down! I think they are going to drive me mad!
I "painted" them to the canvas with diluted white glue (Elmer's) and a small brush, and gently "persuaded" them to hung down until glue dried.
Once glue is dried, it is invisible.
My model is in 1:48 scale.
Edited by Dziadeczek
I've found that using PVA glue is tedious because it takes the glue a while to dry and you have to hold the reef point in place until it does. That can be a problem when you have to hold the entire length of the reef line against the sail to get it to hold its proper shape while drying.
I use white (clear) shellac instead of water-based PVA glue. I thread the reef point through the sail with needle and thread long enough to allow me some thread to work with (e.g. two or three times the length of the reef line.) I remove the needle and tie an overhand, figure-eight, or surgeon's knot tight up against each side of the sail to hold the reef point line in place on each side of the sail. Then I place a strip of masking tape on the sail face with its upper edge the same distance from the line of reef points as I want the length of my reef lines to be. (The reason for this is explained below.) Remember to determine the scale length of your reefing lines. There's no precise rule that I know of, except "not too long and not too short, but definitely not the same length from row to row." Reefing lines need to be long enough to encircle the reefed portion of the sail and be tied off with a reef knot, leaving a bitter end sufficient for holding and untying the reef knot. The length of the reefing lines must be sufficient for the amount of canvas that will have to be secured by the reefing lines at each line of reef points. This depends on the size of the sail and the placement of the lines of reef points. Each line of reef points must secure all the canvas below it so if a sail were divided into three equal areas by two lines of reef points, the upper line of reefing lines would have to be approximately twice the length of the reefing lines through the lower line of reef points.  If the lines of reef points don't equally divide the sail into separate segments, the length of the reefing lines required to secure the resulting roll of canvas will have to be individually determined.  If there are sail gaskets on the head of the sail or fastened to the yard, they would correspondingly have to be approximately three times the length of the reefing lines in the first row of reef points in this example, or, in other words, sufficiently long to encircule and secure the entire furled sail.
I then take a paint brush loaded with white shellac and, holding the long end of the thread out away from the sail, and taking care not to flood the knot and send the shellac soaking into the sail material itself, I place a drop of shellac onto the knot and reef line on one side, spreading it down a bit farther than the intended length of the reef line. (i.e., the shellac should end on the masking tape itself when the reefing line is pulled down where it's supposed to end up.) The thin shellac will immediately wick into the knot but, if done carefully, should not wick into the sail itself. Hold the free excess end of the shellac-soaked reef line away from the sail and gently blow on it for a few seconds. (The dry free end of the excess reef line keeps the alcohol from getting all over your fingers which when they get sticky will make a mess of it all.) The alcohol in the shellac will quickly evaporate and the shellacked reef line will become increasingly tacky as the drying shellac thickens. Gently pulling the un-shellacked free end of the reef line downward and perpendicular to the head of the sail (or to whatever other angle you desire) and against the sail, use tweezers, a hemostat, or a similar tool to gently press and hold the sticky reef line against the sail into the final position that you want it to take. It's best to use some sort of pointed metal "positioning tool" to place and hold the sticky reef lines because such a tool will only contact the sticky shellacked reef line in a small area and can be easily be pulled free and rinsed off in a small container of alcohol and wiped clean as you go, preventing a sticky buildup of drying shellac on the tool tips. Try to resist the temptation to use a finger to push the sticky reefing line against the sail. You want the reefing line to stick to the sail, not your dirty finger and the small area of a metal tool point will pull free of the stuck reefing line leaving it attached to the sail much easier than the far greater area of adhesion that occurs when your whole finger tip has become glued to it as it dries. The "finger tip method" causes the reefing line to pull free of the sailcloth because more of it will be stuck to your finger than to the sail. The sticky shellac should cause the reefing line to stick well to the sail in short order. Blowing on the shellac speeds the evaporation of its alcohol solvent. If adhesion proves insufficient, apply a bit more shellac to the underside of the reef point line, blow on it for a few seconds until it gets tacky, and try sticking it again. Let the shellacked reef point dry, adhering firmly to the sail. When it is dry, cut the reef lines to the desired final length with a sharp pointed iris (medical) or embroidery scissors using the upper edge of the strip of masking tape you placed on the sail to mark the desired uniform scale length of your reefing lines across the face of the sail in a neat straight line. After all the reefing lines are cut to length, all the trimmed off-cuts, which will likely be shellacked to the masking tape, can easily and neatly be lifted off of the sail along with the masking tape without leaving any shellac on the sail below the ends of the trimmed reefing lines.
This job can be done in any order you prefer. I've found the most efficient method for me is to tie in all the reef lines on one line of reef points on each side of the sail and then shellac, position, and cut to length all the points on one side of the sail and then turn the sail over and do the same on the other side. I install one row of reef points at a time.  Keep in mind that there is a technique involved. The reef point stopper knots are most efficiently tied into the reef lines on both sides of the sail using an overhand or surgeon's "instrument knot" tied around a needle holder or hemostat. This permits the two knots on each side of the sail at each reef point to be tied tightly against the sail without any free space between them. Search for "tying surgeon's instrument knots" or "tying sutures with instruments" on YouTube to watch tutorials on tying knots with surgical instruments. (If you haven't learned these skills, they will change your life as a ship modeler. Their training in the use of medical instruments is one of several reasons why doctors and dentists are generally such good ship modelers.) Once the length of the reefing lines is determined and you've placed your masking tape strip across the sail to mark this length and you are ready to start shellacking, remember to keep your hands out of the shellac. Otherwise, you can fall victim to the "tar baby effect" and end up with fingers to which everything sticks but which are useless for getting anything done. To this end, take the long end of the reef line in your nondominant hand and do not let go until the shellacked reef line is stuck to the sail and masking tape right where you want it. Better yet, if you have a suitable instrument such as a needle holder or hemostat, grasp the end of the long reef line at a point just below where the reef line crosses the lower end of your masking tape length marker and use that instrument to control the line instead of your fingers. In that way, you can leave the line to be held by the instrument if you must let go of the instrument. Use your dominant hand to apply shellac from a small cup or jar and to manipulate the tool you will be using to put the sticky reefing line where you want it to be. Use your dominant hand to rinse your shellac brush and positioning tool in a small cup or jar of denatured alcohol as need be.  You might want to imagine yourself a surgeon as you install your reefing lines. You want to "keep a sterile surgical field" within which to work and you want to use your instruments to do what your fingers are too large to do. Once you get in a rhythm installing reefing lines, you'll find that it's a task that can be performed rather quickly and precisely without a lot of practice.
The shellac will seal the knot in the reef point, secure the reefing line in the proper position on the face of the sail, and prevent the free end of the reef point from unraveling. If you are careful to work neatly, there should not be any visual evidence of the shellac on the reef point lines or the sail when you are done. The advantage of using shellac for this purpose is that it dries very fast and, should the need arise, more shellac can be added if greater adhesion is required. Sticky shellac has excellent archival qualities. While the method may seem involved, it's really a lot easier to do than it is to describe. The shellac allows the reef points to be stuck flat against the sail for the entire length of the reef line, providing a proper scale appearance. Shellac is very forgiving to work with. It cleans up very easily with denatured alcohol, which instantly dissolves it.
Edited by Bob Cleek
