PVA is polyvinyl acetate.  Ac is an organic chemistry abbreviation for acetate.
Changing Ac to AC is probably advertising hype.
I see five types of PVA:
pH neutral (pH7)  bookbinders - good for cotton or linen rigging
white - dries clear
yellow - wood workers - dries amber - is acidic
Titebond II - yellow - water resistant - dries amber - is more acidic
Titebond III  - brown - water proof - dries brown - is a lot more acidic
white or yellow is probably sufficient
Titebond II if you are compulsive
Titebond III if the model is to be aquatic - otherwise probably not worth the negatives
I doubt that there are that many companies that synthesize the base chemicals so most name brands are probably different names on containers of the same stuff.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
