First issue with the drawings, moulds 2 and 4 have the labels swapped, 2 should be 4 and 4 should be 2.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Some progress, in a forwards direction :cheers:
Build board built, 'deck beams' bent, everything glued up to and inc the 'deck beams'.
Wale being test fitted (again), waterway being worked out (they're next I think).
After the waterways it'll have to be the counter timbers, that will be fun.
Craig.
26 minutes ago, Tony Hunt said:
Looking really good Craig! The hull looks nice and fair.
Thanks Tony. Biggest worry at the moment (apart from everything else) is the MDF bulwarks, I have to fair one side unsupported so that I can plank or line them so they are supported to fair the other 🤷‍♂️
Craig.
A tiny update representing a lot of head bashing.
The inner pair of counter timbers:
I had to remove 'deck beam' 18 to get them in, all six will be attached to it before being installed as an assembly.
I thought I had the outer counter timbers worked out (several times) but I think I'll have to give up and do them in multiple pieces like Chuck did Cheerful.
Craig.
Next two counter timbers done. Also some planking, a wale, the counter and stern roughly mocked up. I think the counter is going to need a slight curve on the sides.
Craig.
