lines to the fife rails?
Go to solution Solved by DonSangria,
Not sure what you mean either by over or under, Paul.  As a relative newbie, I always have to remind myself how to tie off to belay pins or cleats.  Here's a nice short video reminder.  Hope this is what you were asking about.  Tying to fife rails wouldn't be any different, I don't think, than to rails or mast cleats.
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
no no no not about the knots.
when a sheet comes down the mast to a deck block and exits the deck block inside the fife rail... does the end of the rope exit under the fife rail or over the rail and belay on a pin?
Edited by paul ron
  • Solution
I know what you mean, but I don't know the answer. I think it depends on the relative positions of the block to the rail. Maybe also just the preference of the crew or the officers in charge?
I would go with the left version of your drawing.
Current build: HMS Sphinx 1:64 (Vanguard Models)
Finished: HMS Beagle 1:60 (Occre)
