Saucy Jack by Dfell - Vanguard Models - 1:64
Hello - Just wanted to start this log by uploading the box cover and contents.
The contents are nicely packed and in good order. As with Vanguard model kits there is a lovely illustrated instruction book along with 11 sheets of plans.
Also ordered the upgraded sail set.
Regards
Doug
Completed: HM Brig Supply - JoKita / Caldercraft 1:64
HMS Fly - Caldercraft 1:64
HMS Sherborne - Caldercraft 1:64
HM Brig Flirt - Vanguard 1:64
Link to comment
Share on other sites
Hello - initial stages started. All Bulkheads that require some bevelling have been done prior to assembly to Keel as per instructions. Only minor sanding of slots to ease assembly was needed to prevent any breakages. No glue used at this stage.
Lower Deck added along with the Well / Hold. The Well / Hold was glued in place.
Then the various pieces that make up the Stern fitted along with the two parts that run parallel almost the length of the frame.
The Sub Deck was slotted in along with some additional pieces at the Stern which were glued in place. Then the all Bulkheads etc were glued.
Next will be some more piece to add to the underneath of Stern section.
Thank you for looking and the previous 'Likes'
Regards
Doug
Link to comment
Hello - a bit more progress. Additional Keel parts added along with the Bulwarks. Made the mistake of wetting the wood so as to bend it which resulted in some dark stains. Heat to bend probably been better.
The maple veneer part was added with as much wrapping around as possible but had to do it as separate pieces.
Onto the first planking - we will see how much of a mess I make of this......
Regards
Doug
Link to comment
Hello - Further progress. First planking completed - not pretty but hopefully a good base for second planking,SaucyJack012.jpg.ec19c6db6159530e27aa07e719678cd8.jpg
Second layer added to Keel and pegged. Also rear sections glued into place - this was a bit tricky especially getting the lower section to bend round.
Managed at a later stage to break off the top part of the upper rear section - hence window pieces have come off before their were required.
Also glued on the side parts.
Next stage is the second planking.
Thank you for looking.
Regards
Doug
Edited by Dfell
Link to comment
Looks great, I broke the top off the upper rear section on my Saucy Jack too.
Dan
Current Build: HM Gun Brig Adder (Vanguard Models, 1:64)
Previous Builds: Fifie (Vanguard Models, 1:64), Nisha (Vanguard Models, 1:64), Zulu (Vanguard Models, 1:64), Saucy Jack (Vanguard Models, 1:64), Erycina (Vanguard Models, 1:64), HMS Alert (Vanguard Models, 1:64), Grecian (Vanguard Models, 1:64), Ranger (Vanguard Models, 1:64)
Waiting to be Built: Speedy (Vanguard Models, 1:64)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
