1:48 Longboat
CAFModel
Catalogue # B-05-190
Available from CAFModel for $55.00 USD
This kit is one which I think will be included with CAF's La Renommee kit at some stage. It is possible it's available as an extra, should you wish to either buy it as a separate project, or for completion of La Renommee. In the near future, I'll also be taking a look at the full kit of La Renommee herself. Until then, let's look at this separate, related project. This kit is packaged into one of CAF's smaller corrugated boxes, with the product label on the top box flap. The kit itself is 190mm long when complete, and features a full frame construction, as per the real vessel. Inside the box, the A4-sheet instructions are wrapped around the various parts packets. The parts sheets themselves are then sealed within a tough, clear plastic wrap which further protects the parts. I do know from experience that it's worth leaving your parts in the wrap for a few days before opening them. I once unwrapped a pack as soon as it arrived and over the next hours, the sheets warped slightly. I've learned my lesson so you don't have to. The overall quality of the parts is extremely good, with very little in the way of laser blowback on the reverse of the sheets. What there is will be easy to lightly sand away.
Being a POF (plank on frame) kit, the model is constructed in a build jig. The parts below are those for building that jig. The parts are very self-explanatory, and you'll also see the numbered frame notches on the upper face.
The frames consist of multiple parts that much be assembled. This sheet of cherry wood holds all of those parts. These will be assembled within an acrylic jig which we'll see shortly.
All of the planks on this boat, are supplied as pre-cut/shaped parts, so if you take your time with this build, then all of these will fit without stealers or other remedial action needed. There is both external and internal hull planking on these sheets. Note that they are the same, just mirrored so they fit 'per side'.
Most of the internal fitting out parts of this project are to be found here, such an inner strakes for planking up to, thwarts, decks etc. The part engraving is also very good and will look nice under varnish or oil.
When the build starts, the keel and rear bulkhead are  first assembled and then all is slotted into the jig. The keel is provided as upper and lower parts. Once you sit the completed frames into their respective slots in the lower keep (and within the slots on the jig upper face, the the upper keel is fitted, trapping the frames in situ. The long parts on 1F, are the wales.
The longboat's gunwales are evident here. These are provided as two parts per side due to the step in the side profile of the longboat. Several lower transverse frame sections are also seen.
Brass wire, tube and photo-etc are provided for detail parts. I'm pretty sure that the small length of dowel is used to align the mat steps, but I could be wrong.
Several packets are also included. These are short lengths of brass rod, brass nails (now copper as stated on packs), 3D rudder tiller, and brass belaying pins.
The frames have a very clever system of assembly. First, you sit the blank sheet on the bottom of the stack, then fit frame #A on top of this and add the parts to the shaped hollows. Corresponding frame #C then sits on top of this, all aligned by pegs at the frame corners, and the next layer of frame parts are glued into place. Acrylic sheet all around the frames means that the wood glue (NOT SUPERGLUE!!) will not adhere to it, and the completed frames can easily be removed from the jig and then cleaned up before assembly to the keel.
Instructions
These are very self-explanatory. When I come to build this boat, I'll likely create something similar to my VM build logs.
CAF Assembly photos
Conclusion
A lovely little kit from CAF and I consider it to be excellent value for money. It all looks very buildable, but I'm in no doubt that you'll really need to take care and time when building. I don't think this will be too easy a project, so wouldn't recommend it to someone who is fairly new to the hobby, however I do think it looks a great little kit, and I'd love to see some build logs on MSW of this one.
My sincere thanks to CAF Model for sending this kit over for review on MSW.
caflogo.jpg.b3df71d3ac2a0ca28084c3338783d68c.jpg.418291583826c9c52ead5657b0f50741.jpg
Ongoing:
  • 11 months later...
Actually, Chuck's is in 1:24 scale (1/2") and is no longer available
James, I read your description of the kit, in detail.
I have to say that CAF Models improved immensely their instructions and approach to building their kits. These instructions make sense, are clearly detailed in English (and not in Chinese) and they are providing you with pictures, which is a first in the History of CAF Models !!! The acrylic jigs are also a great addition.
After building two of their earlier kits (HMS Bellona and Le Requin), I can tell you that their original instructions and directions were not that great....and you had to spend a lot of time, just wondering and trying to find a solution to the assembly.
Yves
Edited by yvesvidal
James, you mention that you intend to review the La Renommee kit; any progress on that project?  It's one that I've been considering, and would love to see your take on it!
  • 5 months later...
In a week, I'll have all sections of the La Renommee kit. There are 7 individual set kits, and I'll be looking at each pack over the Christmas hols, onwards.
Ongoing:
