Well, this is my first post. Thanks for having me. I have a few builds in different states, including a Midwest Lobster Boat that I’m going resurrect and finish as a derelict left behind boat.
My build here is modern Naples Sabot dinghy that is in 1:12 scale. It’s modeled after my buddy’s son’s boat.
I worked off of real boat plans and then scaled things down. I wish I had captured everything in pictures from the time I made the jig and hull, but alas, I found you guys too late. So this will be a disjointed build log and if you have any questions, please ask.
The build has been going on for almost a year now. All of the wood and metal used was purchased at Ace Hardware.
Please excuse the ramblings as I post things, I will breakdown each part of the boat as I post pictures. I still have the boom to mount, rigging and mount to the base.
Here she is in the current state, I’ll post more tomorrow.
The model looks great, looking forward to seeing more about how you built it!
I researched ‘kits’ of the Sabot and found none. Thinking that these boats are primarily made by plywood and simple (some are fiberglass purpose built racing boats now, but they still need to comply with dimension and weight rules), I thought I could build one to scale. My first job was to get dimensions and possibly plans and found the Texas Win’ard Sabot Association plans online.
The boats kids race now are a hybrid of the 'recreational' Sabots you see out there, with enclosed bulkhead seats, covered bows and modern 'quick adjustment' rigging. I wanted to make this as close as possible to the real thing.
As every good build starts, it needed a base. And like anyone building this boat for real, I needed to create a brace jig to wrap the 'plywood' around for the hull. Using a scrap piece of real plywood and scale wood purchased at Ace Hardware, I built a frame jig. I chose 1:12 scale because all measurements would be easy to covert from 1" on the model would equal 12" in real life. I'll post a picture of the jig on Sunday (it's at work).
Edited by DownEastHeart
The hull being the foundation of any boat, the construction followed many trials and tribulations that you all have fought. First, was how to get the stock ‘plywood’ to bend where I needed it to in order to get the shape. There was a lot of hand fitting the transom and bow, but this boat being so small, it was straight forward to get the scaled down pieces from the plan into the right position.
This model is created based on the real boat having a plywood base with a thin fiberglass layer,  boxed seating and covered bow. On the model, due to scale, paint became my ‘thin fiberglass’. Sanding and ‘trueing’ were done before several dusting layers of spray paint occurred. The paint was first brushed/sanded, then rattle canned.
Life caught up with me along with trying to figure out modern sailing pulleys in scale. I ended up getting a mini electric miter saw to cut slivers of dowels to make my own pulleys. More to follow.
