Hello! And welcome to my third build log. Today I'll be sharing some of my initial progress on the Mary Rose kit by Caldercraft.
Introduction
I lived in Portsmouth for a few years, and was very keen to build one of the historic dockyard ships - HMS Victory of course being the most famous. Caldercraft also produce a kit for the Victory, but it is prohibitively expensive for a relatively novice builder. The Mary Rose was the next obvious choice.
Mostly made famous for her tragic sinking in the Solent in 1545, the Mary Rose saw active service for over 30 years of Henry VIII's reign. In the early 1970s, she was rediscovered, and many will remember the live broadcast of her being brought back to the surface in 1982; you can watch this on YouTube here, alongside a very young King Charles.
I visited the Mary Rose museum as a child, during which time the remains of the hull were being sprayed with preservative chemicals. I've since visited now that she's dry and on proper display, and I'd wholeheartedly recommend it if you're ever down in the city. I can recommend some good bars too.
Caldercraft's model was designed in conjunction with the Mary Rose trust. This, you would think, guarantees historical accuracy. You would think. Here's a stock image of the completed kit:
If you're reading this, you might already be aware of the problem, but for the uninitiated here is the only contemporary picture of the Mary Rose, from the Anthony Roll, an inventory of the Tudor fleet:
Compare the two photos and the issues will be very clear; Caldercraft's kit is based on a 17th century galleon, and the Mary Rose was a carrack, with high castles fore and aft. Caldercraft also has far less cannon than the Anthony Roll depicts, and as we know, the more cannons the better. Incidentally, this was one of the factors that lead to the original ship's sinking, as her open gunports sank beneath the water of the Solent. I digress.
I would really rather make a kit that resembles the original ship, and though there is very little of her remaining above the gunwales, the historical evidence for the high castles appears to be very convincing. As such, my intention is to build the kit - but to add a number of decks to each castle and make a few other amendments to bring the finished product more in line with the historic original.
References
Other than the above image, there are a number of references I'll be using for this build alongside the instructions for the base kit.
If you're a regular broswer of ModelShipWorld, you may have come across @Baker's fantastic (ongoing at time of writing) scratch build of the Mary Rose, which was a huge inspiration behind my thinking about editing the kit. I'm certainly not ready to scratch build my own version, but his build is a masterclass in both building and research. I'll certainly be referring to parts of this throughout.
I also had a brief chat with @Louie da fly, who was extremely helpful with both advice and some recommendations. Thanks Steven! I'm still not sure how to make those deadeyes ;)
There are two key books I'll be using: Douglas McElvogue's Anatomy of the Ship: Tudor Warship Mary Rose, and Peter Marsden's 1545: Who Sank the Mary Rose?
McElvogue's book is a fabulous resource, full of his own fully scaled drawings of his interpretation of the ship. It's likely a lot of it is made up, but it does follow the majority of the archaological evidence, and I'll be using his measurements throughout. After all, we'll never know exactly what she looked like - this is my interpretation.
Marsden's previous book Mary Rose, Your Noblest Shippe was my original port of call, but unfortunately it appears to be nearly unobtainable in the UK. I emailed the author, and he recommended 1545 instead, as this is a more recent version of his research - one which corroborates the extra decks in both fore and sterncastle. As a note, Peter Marsden is a well-established maritime archaeologist, and alongside his work on the Mary Rose he's also partly responsible for the UK's protection of wrecks act. Fascinating!
On to the build.
First Steps
Caldercraft's kit packaging is first class. The instructions are pretty detailed, and printed on massive sheets of paper in full scale - really useful.
Here's my first look at my expensive purchase:
A look inside:
And beneath the instructions:
That's a lot of dowel!
You'll have all seen the basics of kit building before, so I won't go into much detail, but here's a nice little indication I'm on the right path with my alteration ideas:
This illustration is from McElvogue's book, and is in 1:96 scale. The 1:80 transom piece is obviously missized, but the general shape matches up - all I'll need to do is add a few decks. Simple.
The bulkheads from Caldercraft's kit match up pretty well to those in both McElvogue and Marsden's books. I expected this - the hull is the best preserved part of the ship, after all, and it'll remain mostly the same in my build. Here it is dry-fit.
I've only worked with laser-cut bulkheads before, and Caldercraft's are CNC'd 5mm ply. It cuts nicely with just a Stanley blade, but the sawdust was something else. Probably not one to do on the kitchen table again.
Glueing the keel on:
And the lower main gun deck in place, with false backs for the main guns:
N.b. I may move these false blocks around later, or just add some more blanks for the missing cannon. I figured I'd slot them in place for now as they provide some structure to the next deck. I've emailed Caldercraft's parent company Jokita and am in discussion with them about getting some extra cannons shipped over - if that falls through I'm going to have to learn some new skills!
Here are the two top decks provided with the kit dry fit on the bulkheads. I'll be using the sterncastle piece, but the forecastle is completely the wrong shape.
And here's the upper deck glued in place:
You can see that this has a big crack in it in the photo. To get it into place below the forecastle supports you have to bend this piece nearly in half - I don't think it would have ever survived the process even if I were more careful. It's going to be planked over anyway, so no huge issue, but a weird design choice.
Laying in some first deck planks:
McElvogue's book has these all at the same length on this deck, which works out to 45mm in 1:80 scale. The wood is also excellent, with a lovely grain that I think will come up nicely.
I did the classic trick of edging each plank with a soft pencil to simulate caulking.
And here's the sterncastle planked:
I've only planked up to this point as the front of the sterncastle is going to divide the deck at this point. I also realised midway through that with my additional decks above, this is going to be near-invisible, but I carried on for completion's sake. There will be an open doorway and a number of gunports allowing a view inside, so I don't think it's wasted time.
And on the subject of extra decks, here they are:
Excuse the various paraphernalia I've used to space these out!
Except for the first sterncastle deck, which is Caldercraft's original, these are all 0.8mm ply cut to the shapes laid out in McElvogue's book. Both McElvogue and Marsden agree that there were likely three decks on both castles, with another small half deck atop the forecastle, just behind the foremast. The forecastle here will be slightly further forward - I need to cut some slots in so that it can fit within the bulkheads.
I'm glad I took the time to cut these to shape now - I wasn't entirely confident in my plans, but seeing this rough mockup has filled me with a possibly unearned feeling that this is actually achievable with my skills.
Obviously there's a long way to go, but I can actually visualise this looking 'correct' - and that's a start.
Thanks for checking this out, and please do follow along! Any input is more than welcome.
Edited by djford
Accidental extra photo!
Doug
In the shipyard:
Caldercraft's Mary Rose 1:80
Finished Builds:
Mamoli's Gretel 1:54
OcCre Palamos 1:45
Off to a good beginning! One thing I'd recommend is that you see if you can find out how many gunports survive on the wreck and if you can extrapolate from there how many she actually would have had. I think it's pretty well accepted that Anthony Anthony exaggerated the number of guns in his picture. More guns is not necessarily better, if you want to duplicate as well as possible the way she was. But also check the Anthony Roll for the number of guns the text below the picture says Mary Rose has.
Yes, McElvogue did definitely make some things up - for example, there was no boat found with the wreck, but he has drawn one. Just be aware of that and use your best judgment as to whether to believe him, and check his book for actual evidence he's based his stuff on. I'm talking from experience - I went with some of his ideas and found to  my regret they were speculation rather than evidence-based.
And if you don't already have it, I'd recommend R.C. Anderson's The Rigging of Ships in the Days of the Spritsail Topmast for when you get to the rigging. Yes, it relates to ships from a later date - his book starts at 1600 - but it's possible to extrapolate backwards and get a fair idea of what would have been already in use in 1545. And also refer to the two contemporary pictures that show Henry VIII's ships - the Anthony Roll and the painting  The Embarkation of Henry VIII at Dover for the Field of the Cloth of Gold - for more details of rigging. For example, the latter one (despite its faults, and it does have them) shows sailors working on the yards without footropes - they were a later invention. And also other contemporary images from around the same time. See in particular my collection of 'Great Carracks' at https://au.pinterest.com/lowe1847/great-carracksnaos/
Interesting that Marsden is also thinking in terms of three decks for forecastle and aftercastle. McElvogue seems to think that's maybe taking it a bit far, but I think it's best to just use your judgment (and cardboard mock-ups) to see what you think. It's all speculation past a certain point, and your guess may be as good as anybody else's.
Looking good, mate.
Steven
There is a very nice Mary Rose build log on another site by a member named Graham who also bashed the kit to bring it more into line with the Anthony Roll. He is nearly complete with his and it is looking very nice.
Under construction: Mamoli Roter Lowe
Completed builds: Constructo Enterprise, AL Le Renard
Up next: Panart Lynx, MS Harriet Lane
In need of attention: 14-foot Pintail in the driveway
Great start, and good luck with Mary 👍
I also have the book "Anatomy of the Ship: Tudor Warship Mary Rose" a very interesting book.
But, I sometimes wonder how they get the detailed drawings of a parts of the ship of which nothing remains.
Be careful with the information from this book.
3 decks in the castles is quite high. I am curious what the result will be.
Yes, I'd noticed the extra gun deck and wasn't going to include that. Certainly the Caldercraft model doesn't include any rear-facing cannon on the transom or in the fore or sterncastle decks - those I'll be adding in for sure. I think at this scale any of the smaller anti-personnel guns are too small to include, but I've got my eye on a few additions - stay tuned!
I've picked up a copy of The Rigging of Ships, thank you for the suggestion.
Thank you very much! Yes, I'd agree - McElvogue is very free with his interpretation. Ultimately my model will have to be my own interpretation as well.
To both of you - yes, I'm interested to see how three castles looks when fully mocked up. Note that the forecastle will also have a small 'half deck' just behind the foremast - I'm certain that it will seem very top-heavy, but it would also appear that that's how the carracks were designed. I'll update with progress soon!
Thanks for the kind words.
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Me too. Looking forward to that stage of the build. Oh, and the rest of the build!
Steven
Time for an update!
I made a lot of progress on the kit this last week or so, and began making some amendments as discussed in my first post.
First, I finished planking the deck under the forecastle:
As mentioned in the previous post, the planking ends here as there's a dividing wall at the aft end of the forecastle.
I also made my first scary major amendment to the kit, and cut off the stem to replace it with my own. I think it looks okay - the join is much less noticable in person, especially after some sanding.
I made this out of the sprue which the keel was CNC'd from in the first place as it's the same thickness and wood type.
First planks going on:
And at the top:
For better or worse I followed the line of the deck for the first plank. This necessitated a very early gap for a stealer. Not sure if that's correct, but this a double planked hull, so any crimes can be hidden later with the second layer.
I also stuck some extra 'dummy' blocks into the transom. The Caldercraft model doesn't include the sternchaser guns shown in the Anthony Roll, and there were no guns found in the transom, but Marsden does allow for their inclusion in his overview of the main gun deck. If nothing else, I can always decide against including these later.
In between planks drying in place, I also cut two holes in the transom for the sternchasers. Obviously the photo shows the holes before cleaning them up!
If I decide against these in the future I can always plank over these when I put the main planks on the transom. Still debating!
On the subject of cannon, here are all the provided barrels. They're some sort of very soft white metal, which I assume may be lead. They're also not very well cast - lots of the barrrels are filled with flash from the casting process, and there are a lot of seam lines.
I emailed Caldercraft's UK distributor asking for more cannon to meet my needs, and they quoted me a quite extortionate amount for what I asked for. I think I'll have to make my own.
So to finish off this update, here's where I am on the first layer of planks:
As you can see, I've reached the base of the first sterncastle deck. I'm 2/3 of the way to the keel with the lower planks. Overall, they've gone on quite easily - I took to soaking them thoroughly, but the lime? is very pliable even when dry and I've not had many issues. There are small gaps in a couple places around the bow but nothing a bit of filler and some sanding won't cure.
And, to finish off, a new addition to the stempost. This follows the scale drawings in McElvogue's book, which came out to 38mm at 1:80 scale. It looks correct to me compared to most of the material.
Hopefully my next post will come to you with a completed hull and possibly a cannon update. Watch this space!
Thanks for reading.
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Aaah, planking. So much fun. Your changes look good. And I think you're right to add the gunports to the transom.
Not sure what the metal is they made the guns out of, but almost certainly not lead - that stuff's toxic and probably illegal to use in most countries - certainly would be avoided. But there are plenty of metals and alloys which can do the same job. Also IIRC lead shrinks in the mould when it's cast. These ones, for all their faults, don't look like they have done that. Yes, you can probably cast your own using these as 'blanks' to mould from.
Steven
I'm actually looking at 3D printing a few test pieces at the moment - there's little variety in the metal ones provided, and I'd like to include a mix of bronze and iron cannon on the main gun deck as the Caldercraft 'dummy barrels' are only culverins and not port pieces or slings. Hopefully an update on that soon!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
And another update - with a very shipshape ship!
Here's the full hull planked (first layer of course).
I'm really pleased with the work I did on this. My last two attempts had a lot of gaps which required some liberal use of wood filler, and whilst this is certainly not flawless - there's a few ridges, especially around the bow - it's a huge improvement on my last attempt.
I even threw in a couple mini scarf joints instead of just cutting filler wedges:
But of course this won't be visible in the final model, as the next layer has to go over it.
Anyway, some more progress, gunports opened up:
As a note, the ports in the plans from Caldercraft are not in the right place - not because they'd be historically inaccurate, but because one of them actually intersects the bulkhead within the ship and not the block where the barrel is supposed to go. Quite surprising really, as the instructions have been otherwise quite good.
The eagle-eyed amongst you might also notice the front two bulkhead uprights in the forecastle are now gone. I cut these off earlier as my adapted forecastle won't match the shape of the uprights. I think I'm going to take the third set off as well, but for now they're quite useful for laying the ship upside down whilst working on the hull.
Here's the hull after a vicious attack from an orbital sander:
Some of the gaps are more obvious now, but the main bulk of the hull is smooth enough that I'm comfortable planking over it. I did take a woodcarving gouge to the planks by the keel as I'd not cut the rabbet deep enough.
I tidied up the waist in preparation for its sidings - removed the bulkhead uprights and cut the ends of the planks framing each castle to a nice taper.
And here's the next layer beginning! You can see the waist panels have also been put in, along with a reinforcing plank behind them. I think I should have started the first plank layer 5mm higher so that this plank ran all the way along the length of the ship, but it'll likely be planked over anyway.
The Anthony Roll only shows three gunports in the waist, and four in the 'nether' deck beneath the sterncastle. Marsden's Who Sank the Mary Rose? details four in the waist and three in the nether, and McElvogue's book agrees on the four in the waist, but has a series of smaller gunports in the nether deck. I think I'll probably go for the three in the nether deck, but I'm not going to open these out until I'm ready to begin the construction of the sterncastle proper.
Here's a few more second layer planks in place:
I've put two untapered planks at the keel and at the wales. From here I think I can get away with about a 1mm taper for the majority of the work - I'm sure this will change as I go lower down the hull. The walnut provided is a nice quality of wood, but there is a lot of colour difference in the various planks. I'm tempted to go with it, as I'm sure with some finish over the top it'll all blend together anyway. I know the actual boat was likely painted, especially with 'white stuff' as antifouling below the waterline - unsure if I'll recreate this. I do intend to add the stripes on each castle as depicted in the Anthony Roll.
And on the subject of castles:
Here's McElvogue's interpretation of the forecastle scaled up to 1:80. At present my plan is to follow this, at least as much as is feasible. After some discussion with @Louie da fly on here, the structure of at least the first deck of the castle is a little clearer - especially the two 'prongs' at the prow.
My deck cut-outs from the first post sit nicely on this:
(Note that the hole for the mast will need to move - I measured this against the original kit's mast placement, and the foremast in the adaption will be slightly forward of this.)
Here's an initial mock-up with some of the scraps from the initial planking:
Obviously this is a very rough start - I'm not entirely sure how the planks will meet at the prow, and I'm less sure about how the two prongs will sit. I'm sure there is better terminology than 'prongs'.
And here's the underside, which will rest on the knee at the top of the stempost. Again, all old scraps of wood, mostly from a previous build.
That's all from me today - feels like a lot of progress, but also like there's a huge amount to do.
Thanks for reading!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Very nice! I'm gonna watch this one if you don't mind. And as for that box of pain meds holding up the deck on the sterncastle....good choice. You just might need them during this build.
And you've consulted two fantatic and reliable sources. Agreed @Baker is a builder in a class of few. His work is stunning. And @Louie da fly, well his work is in that class as well. He is also a reliable, kind provider of info. His knowledge is vast.
I, too, have interest in this ship and am not ready to scratch build. I thought about your path as well with the kit. I'll be eagerly watching it unfold.
Edited by MikkiC
typo
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
  Will there be any latrine holes in the bottom of the forecastle ?  Obviously, the heads will be concealed within the structure, so there's no need to construct the seats ... unless you want to - in case anyone wants to examine the underside of the forecastle using a mirror.  Hmmm, kinda like some show cars where the undercarriage gets painted-up nice and they show it off with a mirror on top of a wheeled floor jack.
That's coming together well, Doug. Good work on the placement of the guns, the formation of the forecastle. For the full forecastle are you going to make a preliminary cardboard replica (as per the highly esteemed wireless-type Goon Show) to see how it looks before you cut wood?
Steven
indeed.
first making a cardboard replica of your forecastle can't hurt.
And then you can also check if you have enough space for your standing rigging of the fore mast
Thanks Mikki - yes, I suspect so. Agreed, both are an apparently bottomless wealth of information!
Yeah, I don't believe that I could have scratch built this with my current skillset - the castles are a looming concern on that front 🤣 thanks for following along!
I had not considered it - I'm not sure where exactly they'd go, and I'd be a little reluctant to cut random holes just for that sake. If there's evidence that they existed in specific spots I'd be interested to hear more!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Steven
On 11/15/2024 at 6:28 AM, Baker said:
indeed.
Hi both, thanks for the comments!
Yes, I spent a little time mocking the castles up in cardboard. Here we go:
First, the forecastle. Liberal use of sellotape - please don't take this as evidence of my modelling skill.
I took the measurements for this straight from McElvogue's book - Marsden's is slightly different, but largely follows the same design principles and height, so I'm happy to continue with this.
A piece of string tied to the mast where the top will be - again, based on McElvogue's rigging plan. This didn't interact at all with the sides.
Obviously this is not 100% accurate, but I'm pleased with it so far. I feel like the height is good, and it's not too obnoxiously tall.
Here I put the other masts into their respective slots - the foremast is further forward than the Caldercraft model's instructions as it comes up through the forecastle. I might have to move the other masts around a little bit too but at the moment I'm happy with their placement.
Inspired by this success, I continued with the sterncastle:
I had trouble getting the cardboard to hold the right shape without internal supports, so it may look a little skewed in some of the following photographs - there really isn't much to attach it to at the moment.
Here all the masts are in place with the 'shrouds' at the correct height. Again, no interaction when held straight and when the sterncastle is the correct width - in this photo it has splayed open at the top where the mizzenmast shrouds fall.
My only concern with this is how high the shrouds are on the mainmast - they start slightly lower than the shrouds on the foremast on my model, and I think this is because I'm measuring McElvogue's distance from the Caldercraft model mast. I would guess the waist panels on my model aren't as high as in McElvogue's drawing. Either way, the solution is to raise the height of the top on the mainmast slightly, which won't cause any issues with shrouds against the sides. I'll definitely be measuring this again before committing to that change - but as we don't have the masts of the original ship, it is of course up to my interpretation. I also don't think the shroud channels on the Caldercraft model will be accurate to the original, so I might well end up customisng these.
As you can see in this photo, the height of the shrouds on the fore and mainmast is relatively similar - the mainmast would ideally be slightly taller:
Either way, I'm pleased with this experiment - at least for now I know that the proposed forecastle design will work with this height of foremast top, and I can work around the heights of the shrouds in the mainmast once I'm closer to putting in the superstructure.
As you can probably tell from these photos, I've been doing this in between letting planks dry on the ship - here's where we are with that:
Getting there!
And finally, here's some of my experiments with 3D printing cannon barrels!
It's hard to get across the size of these, but I've modelled them off of drawings in McElvogue's book - there will be 16 'dummy' barrels which have 2mm x 8mm pegs at the back to stick into the gunports on the main deck, and then a number of full-length barrels for which I will have to create carriages. I'm currently printing a second batch of these, so I'll report back once I've made more progress.
Thanks for reading!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Looking good, Doug. Generally, the cardboard replica seems to be good. Grytpype-Thynne and Moriarty would be proud of you - for those not acquainted with the original lantern-slide type wireless Goon Show (see 8:50 and onward for the cardboard replica)
A couple of observations which you are at liberty to ignore if you wish - it's your model after all.
First, perhaps the forecastle is a tiny bit high. Is there a deck on the top of that structure or is that the height of the bulwark/railing, with the deck somewhat lower? If the second, not so much of an issue, but you might still just have a bit of a look at it and see if you're happy with it.
Next, are the triangles at the front of the forecastle going to join at the apices (plural of apex) as you have on the cardboard replica? I would have thought there should be a flat plane and/or perhaps a curved surface, across the forecastle at each point, comme ça -
That seems to be what is shown in contemporary pics, though admittedly they are a little hard to interpret.
I think your placement of the shrouds looks good, and yes, they never recovered the masts, so you can only go with the best available guesswork information. I'd agree the maintop should be somewhat higher than the foretop, in line with the whole mast being bigger and taller.
And those guns look very good.
Coming along nicely.
Steven
Edited by Louie da fly
Yes, so as per all the sources I've found the forecastle likely had three decks and then one 'half deck' that was more of a sort of cabin on the top. I'd agree that it seems a little high, so I'm prepared to lower the total height by 5-10mm as I build it - my aim is to have each deck between 18-22mm in height, equating to around 2 metres of real height, and see how it looks once I've reached that point. As it doesn't exist any more, I don't think that there's a better way of getting it perfect.
Agreed, a flat plane it is. Here's my first draft in wood:20241121_145943.thumb.jpg.5f0cd4e0869af2d52103bb45223ea774.jpg
This was achieved by taking a dremel and some curved files to a piece of oak firewood. The intention is for the clinker-style planking of this deck to curve against the edge of this piece in order to replicate the style shown in the Anthony Roll. I've also taken a great deal of inspiration from this modern image:
Where again we can see a flat face at the apex of the triangle. I think the forecastle in this painting is a bit short, but you can still see the 'half deck' on the top just behind the foremast.
My forecastle interpretation has developed a little further as well - I added in some test uprights and cut out the second deck.
I've actually since removed the foremost upright here as it was slightly too far forward - the next two decks are significantly shorter than the prow of this one. I'm not really sure how I'll handle the transition there - it seems strange to have a completely flat 'delta' shape at the prow, but the point of the next triangle is around 30mm back from the point of this bottom layer. The modern image I shared above does have a small flat area in the same place, but it's not quite as large. I've been ruminating on this issue for a while!
Another issue is that even the cannon carriages provided in the Caldercraft kit are too large for my forecastle. 20241120_155509.thumb.jpg.965f586a34ef5a4e10fa20215f1e3066.jpg
The recoil from these would back them straight into the guns behind them.
However! looking through McElvogue's book and he has some drawings where the wheels on these carriages are further back (the two in the photo are assembled according to Caldercraft's instructions), and the front third or so of the carriage itself protrudes out of the gunports. I think this might be the solution - other than modelling up some shorter barrels!
Speaking of which, here's a whole bunch of cannons primed and ready for a bit of a paint job touchup:
These are all based on the scale drawings in McElvogue's book, but I'll be placing them on the ship based on the rather detailed overview of each gun deck in Marsden's book.
And here's the other work I've done this week - the planking is done!
I'm really pleased with this. There's a couple areas with slight issues, but overall it's the best planking job I've done by far.
I'm especially proud of the scarf joints I used for the last planks:
Whilst slightly raised here, they've sanded down really nicely. Well worth the hour or so of frustration to get them right.
Here she is after a go-over with 80 and 100 grit sandpaper:
20241124_114940.thumb.jpg.363e1e679dbe01667882468b3da163ec.jpg#
And then with a nice 400 grit finish:
The wood's slightly damp here as I wiped it down with a wet cloth to remove some of the dust - I'm hoping a coat of Danish oil will give her a nice natural finish.
I also added in some uprights to the sterncastle to around the height I'm aiming for:
And in doing so I encountered an interesting discrepancy. McElvogue's scale drawings were used as a basis for this, and they roughly match the height in some of the illustrations from Marsden's book. However, in McElvogue's case he suggests two internal decks in the sterncastle plus the poop deck - three total above the nether deck and main gun deck that're already in place on my model.
In Marsden's book he suggests three internal decks above the nether deck - lower, middle and upper sterncastle, with the poop deck above covered in boarding netting. As mentioned earlier, I'm planning on keeping my decks around 20mm in height, and these uprights are 70mm high - giving me some leeway to shorten them if needed.
I'm not sure which deck number would be correct, but after studying the Anthony Roll I'm leaning towards three internal plus the poop deck - the Anthony Roll has two very obvious lines of portholes, but they're spaced very far apart. Either the top deck was a good few metres high, or there was another deck in there. Marsden's rationale is that there must have been more decks in order to accommodate the 400+ men aboard the Mary Rose, and I'd be inclined to agree with him. I'd be keen to hear other people's thoughts on this too!
Finally, the last thing I did this weekend was put together some gun carriages:
These are much more like the actual carriages would have looked compared to what's provided in the kit. However, they're quite labour intensive to create, and are really not very visible inside the ship:
I think I'll keep these ones in place, as the front of the sterncastle will have an opening, but for the carriages at the back I'll likely default to the Caldercraft provided bits.
Anyway, lots of progress here - now for the tricky bits where I have to make big decisions. See you next time!
Edited by djford
Removed extra photo
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Looking good, Doug. Perhaps you're using the wrong type of gun for the forecastle. I'm PMing you a paper on the range of contemporary guns in use, by Max Guerout, who was in charge of the excavation of the Lomellina.
The rest of it looks really good. I'll have to look at my documentation for the distance between decks on the Lomellina, though you should also be able to get info those distances on the remaining structure of the Mary Rose, which would be more appropriate to your build.
Looks great 👍
I think I should also provide a ladder or stair from the lower deck on my model here.
Edited by Baker
7 hours ago, Baker said:
Looks great 👍
Thanks Patrick!
Yes, the sources I've read seem to think there must have been some sort of stairway below the forecastle leading into the first deck of it. Another reason that these full-size carriages wouldn't have worked. I would guess that the stairwell would be aft of the mast, but I suppose up to interpretation! Looking forward to seeing what you come up with on your build 😁
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Dont now yet.
These stairs come in the deck in front of the fore castle.
it is thought that they went further up to the fore castle if i understand the text correctly.
i don't understand the english text so well.
In this case there are two stairs on the outside of the fore castle
Patrick, I think I've found the stairs! I believe that the aft wall of the pilot's cabin is at an angle of 70 degrees and the stairs follow it - that in the red circle we see the Pilot's cabin, and that its aft wall is indeed inclined at 70 degrees, and the stairs can be seen on the other side of that wall, with the treads running from side to side, up the aft side of that wall.
And if that's the case the forecastle would be directly above the Pilot's cabin, and extending both forward of it, and aft far enough to allow room for the stairwell. And furthermore, I think it's likely that the rear wall of the forecastle would also be at 70 degrees, and would perhaps be only far enough aft of the aft wall of the Pilot's cabin to allow space for the stairwell. Here's the Anthony Roll picture of the Mary Rose, and the aft wall of the forecastle certainly seems to be leaning forward.
And it seems to me there'd be room each side of the stairwell for the (light) guns facing aft toward the waist of the ship to defend against boarders.
Best wishes,
Steven
I think you're right, Patrick. The Pilot's cabin seems to be fairly close to the ship's side, and if the staircase is behind it, it makes sense there'd be another one near the other side of the ship.  I think there would have been an enclosed walkway - between the aft wall of the Pilot's cabin and another, parallel, sloping wall some distance behind it, which is also the rear wall of the forecastle. And the stairs would be between these two walls. But there'd have to be enough room between the aft wall of the Pilot's cabin and the aft wall of the forecastle to allow for people to walk past the opening in the deck for the staircase - so perhaps the forecastle would have extended about 2 metres behind the back wall of the pilot's cabin?
The staircase seems to be somewhat inboard, and that would make sense - there appears to be a walkway between the pilot's cabin and the side of the ship, which would serve the side-gunners. And this would perhaps be mirrored in the forecastle.
By this time ships may or may not have had the 'great arch' any more - you can't tell because the boarding netting and its gangway are hiding that part of the ship, but above that just a relatively small arched opening for access from the gangway that supports the netting, as you've shown. And you'd walk through the arch and into the walkway behind the Pilot's cabin.
And the rest of that enclosed space between those two walls would allow room for the gunners of the rear-facing guns (which the Anthony Roll shows at the ends of the forecastle rear wall), as well as of the men serving the sideward facing guns, who would work in the fore-and-aft walkway.
That's my thoughts on the matter.
Steven
Marsden's book suggests a staircase underneath the forecastle in the 'nether deck' at the end of the waist, going up into the lowest deck of the forecastle. There was also a large arch-like entrance on the aft end of the lowest forecastle deck, as shown in the Embarkation painting and in the Anthony Roll - I'd postulate that there must have been internal stairways at the front of the forecastle, as there wasn't really enough room elsewhere and the baording netting over the waist would have impeded stairways on the outside.
But that aside, here's my new update!
After some discussion with @Louie da fly and a very helpful article he provided, I've decided to go with smaller cannon in the forecastle. Peter Marsden retains that there were 'slings' in the lowest deck, based on a letter exchanged with Henry VIII:
However, I don't think they'd fit, and they certainly wouldn't look right in my build. As such, on Steven's recommendation, I'll be using Pierrier à boîte swivel guns - in both Marsden and McElvogue's work I believe these were known as 'fowlers', and here's a drawing from McElvogue's book:
As you can see, these were short iron cannon, mounted on a spike and breech-loaded. Here's a 3D printed one at the 1:80 scale I need:
That's 17mm long.
I glued a small upright in each of the forecastle gunports as a mount. I'll insert the cannons later, as I'm sure I'll knock them around whilst building otherwise:
This leaves me with far more room in the forecastle, and so I'm considering putting in the stairway as discussed earlier in this thread - I'll have to have a think about that.
Whilst I was working on the forecastle, and now I'm happy with the cannon situation, I stuck in the next deck and cut holes for foremast and bowsprit. The bowsprit is slightly offset so as to not conflict with the mast.
The upright at the front marks the apex point of each triangular deck from here on up, so I'm going to need to work out how to make the walls work around this and the bowsprit as I build them. I've got some ideas, but there might be a few revisions!
Back to the... back. The sterncastle is coming along well:
The carriages for these guns are now in place, and I'm able to add and remove the barrels through the gunports - again, I'll stick those in permanently when I'm not likely to break them off in the building process. I still want to paint these up a little nicer as well.
The Caldercraft kit comes with these nifty plywood sheets for the small gunports on the higher level of the sterncastle, so I used them.
Here I've also put in the upright standards provided in the kit. McElvogue's drawings have these extending up the whole height of the sterncastle, but Marsden's don't, and as these were nicely shaped for the hull as part of Caldercraft's original build I've kept them at this length. Above these the sterncastle will continue for another 40mm, or around 4 metres of real height.
I've decided that three decks makes most sense - that's therefore four including the poop deck at the very top. There won't be railings on this, but there will be a boarding net 'tent' supported on short poles. This is visible in the Anthony Roll - I'm just not quite sure how i'll make it yet.
Another view from behind, where you can see some of the work I've also done on the transom:
Each of the shaped gunports was planked over with overlapping clinker-style planks. McElvogue seems to think that the actual ports would have had flat sections of board on them instead, but honestly I'd already started doing this by the time I reviewed his drawings, and I'm sure not going to undo the work here.
Well, I suppose I could, but I think this looks quite neat as it is. What do you think?
I have also put in the strakes on the hull:
And added various other details, including the beginnings of the channels and the planking around the waist bulkheads:
It feels like quite a small update this time, but it's been a lot of time-consuming work. I'm close to completing the hull whilst also very far away from it!
Today I began planking the waist deck:
And this brings me to a close. I've organised to borrow some bronze paint from a friend, so I'll be painting up the cannon that go on the next deck of the sterncastle very soon, which will allow me to progress significantly. Otherwise, it's just more laying of planks for me. Thanks for reading!
Doug
In the shipyard:
Finished Builds:
OcCre Palamos 1:45
Large update 😉.
The strakes normally follow the lines of the planks and seal the seams between two planks
neat indeed 👍
Here indeed there was no clinker planking, but removable shields.
Good and nice work
