I finished the Lowell Grand Banks Dory a month ago.  I planned to work my way through the Model Shipyard Shipwright series. I got my credit from Model Expo for the Dory build and ordered the Norwegian Pram.
However, during the Dory build I couldn't help perusing eBay and I picked up several Midwest Model kits for what I considered really good prices.  The Dory had some issues, so before diving into the Norwegian Pram, I decided I would build the Midwest Skiff first as a confidence builder.  As you can see from the box photo this was a pre-Model Expo kit but I have no idea if Model Expo made any updates to the rereleased Midwest kits.  I will say the instructions are very good for a beginning ship modeler.  From reading through the instructions, this appeared to be an easier build than the Lowell Grand Banks Dory.
Current Build
Midwest Crabbing Skiff
Completed Builds
Model Shipways Lowell Grand Banks Dory (1/24)
Midwest Skiff (1/12)
Build Queue
Model Shipways Norwegian Pram, Model Shipways Muscongus Bay Lobster Smack, Midwest Crabbing Skiff, Midwest Sharpie Schooner, Midwest Sea Bright Dory, Midwest John Alden Sloop, Midwest Chesapeake Bay Flattie, Midwest Sakonnet Daysailer, Dikar Hawkins Gunboat #3, Dumas Skipjack, Corel Shenandoah Confederate Smuggler, Blue Jacket Schooner Yacht America 1851, Amati Pinta
The parts appear to be die cut and there were no clean up like there would be with laser cut parts.    The parts were quite easy to separate from the wood sheets, so no wood burrs to clean up either.  I started by removing the bottom plank.   I marked the center line and the positions of the cleats.
The instructions said to use slow CA glue but I used Aileen's Fast Grab tacky glue.  The stem and transom knee are both two identical parts you glue together.   I glued the knee the transom and the stem to the bottom plank.  The I glued the transom to the bottom plank.  Here was my first problem.  Somehow, I managed to not get the transom flush with the end of the bottom plank.   Here's why I used white glue as I was able to use alcohol to undo the joint and correct the fit of the transom.  This would be my only time to undo a glue joint.
Cleats and frames where added and I gave the glue time to dry.
Current Build
Completed Builds
Build Queue
Boat has been mounted to a strong back with pins.  You had to bevel the first 4 inches of the strong back which let me make use of my new Jorgensen mini plane.  This leaves 3 holes that have to be filled later.  Had some trouble getting a clamp on the stem but got it done.  I think I'll use rubber bands next time.  Side planks are on.  I did get the bottom of the starboard planed corrected.
Edited by jcurtis55
Current Build
Completed Builds
Build Queue
Chafing plank and skeg attached.  I also got the oars started.  I think half the time to build this kit is spent sanding the oars.
Current Build
Completed Builds
Build Queue
Breasthook, rear set risers, stem cap and knees added.  Frames trimmed and sanded.
Edited by jcurtis55
Current Build
Completed Builds
Build Queue
Exterior painted white and interior blue.   Floor boards added and middle seat risers added.  Natural wood items sealed with Shellac.  I know Shellac and Varnish are different items, so the label on the Terlans bottle is somewhat confusing.  I figured either one would work.
Edited by jcurtis55
Current Build
Completed Builds
Build Queue
Oar locks, inwales, rub rails and painter added.  Skiff is finished.  A quick easy build, but when you are a beginner, it is still a nice feeling of accomplishment.  I have not glued down the oars, as I may sand them some more.Skiff7.jpg.62778a5c7efb7b7772b6ed37d36aeb80.jpg
Current Build
Completed Builds
Build Queue
Thanks!  Now to pull out the Norwegian Pram.
Current Build
Completed Builds
Build Queue
