I have the 1-2-3 blocks but no holes. When I got mine they were very heavily oiled. You are right, they can make a mess of the build. They do work well in the right situation.
Best RVB
Masts are cut to length and tapered. I put the mast into a long clamp that would hold it at an angle with one end flush and the other protruding above the surface. This made it easy to sand down to the surface of the clamp creating a tapered faceting of the mast. I did this multiple times rotating after each facet was sanded. Final sanding was done by hand to remove the transitions from facet to facet rounding the surface. I tried to take pictures of the process, but they didn't seem clear enough to be helpful.
IMG_0004copyLarge.jpeg.c5a978906b18a3fdac1f0ed4becebbb7.jpegIMG_0003copyLarge.thumb.jpeg.8f8c891a3fdb61905105b3c289ffd53c.jpeg
Bounty Launch (current build)
Wappen Von Hamburg (on hold)
In thinking ahead, I need to do some research on how to handle the rigging. I didn't drill holes in my thwarts to add belaying pins because I thought I had read somewhere that this would not have been used on the real boat. Am I correct or not? And if so, would anyone be able to point me in the right direction for proper rigging attachment points?
Without belaying pins, how would the sails have been properly set, tied off and fixed into any needed position for 'sailing'? The sails would just swing wildly in the wind with nothing to hold them in place!
Edited by tmj
