Folks,
I will be presenting (and hopefully finishing...) a project that I have been working on for quite a long time. The model is a replica in the scale of 1/48th of the famous super-yacht WALLY POWER 118, first introduced to the public at large, in the movie "The Island" covering the delicate subject of Human cloning, for organs harvesting.
e297c5e2433b5cef836d4de8d3597ac8.06_wally118.thumb.jpg.20e962cb6e5f7ec0c1b3fbfe73d0d07b.jpg
The 118 (36 meters) was designed by Luca Bassani, a very innovative architect and designer who made his wealth by owning an electrical equipment company on the northern part of Italy, near Genoa. Luca created many vessels including sail yachts that are years ahead of their competition in term of design and features. The picture below shows Luca resting on the bow of the 118:
yacht-designer-luca-bassani-prow-credit-Guillaume-Plisson.jpg.4a39425bca4d6ccd50cf694ff84a4c65.jpg
My favorite sail boat created by Luca Bassani/Wally, is the 100 foot WALLY CENTO Tango mega yacht that you can admire on the following video:
Of course, all these "toys" are for the Elite and call for millions of dollars. The 118 Wally Power retailed for $33 million when it came out. It is to my knowledge, the fastest yacht on seas, capable of 60 Knots (70 MPH / 100 KM/H) using a triple Rolls Royce turbines producing more than 16,000 HP. At that speed, you have to account for about $4,000 fuel cost per hour of cruising. The amount of technology installed on that yacht is absolutely phenomenal and the following video demonstrates some of the features. Everything is designed to make your life on board, easy and elegant.
No model exists of the 118, even though some south east Asian modelers are offering some very realistic models on Da-Bay. I decided to contact the Wally office in Monaco for some drawings of the 118 but never got any answer as can be expected. I then patrolled some French and Italian scale model boats forums and found some clues and leads of what can be done. I will come back to one of the leads, in Germany. Finally, I went on the 3D printing forums and found a decent replica of the 118 designed at the scale of 1/60, ready to print (STL files). As you will see, it is a very crude representation and does require a lot of modifications to turn it into a decent model, which I hope to attain. The model can be found on CGTrader at:
https://www.cgtrader.com/3d-print-models/miniatures/vehicles/wallypower-scale-model
I purchased that model and started printing at 1/48th scale (increasing the size of the model on my Slicer). The original model was offered in 3 parts for the hull and one part for the cabin plus a tender which has nothing to do with the original Wally tender, and some lounge chairs:
wallypower-scale-model-3d-model-99c7fc6ae1.thumb.jpg.f1f28257b65fa28754023307aebb31e0.jpg
Because the parts would not fit on  my Creality Ender 3V2, I had to use Meshmixer to cut them and print smaller parts:
The second part (from the bow), did not have the opening used to provide some light on the lower decks, I had to cut it as you can see on the picture. Overall, it is a very crude model and will need a ton of modifications to turn it into something decent or even close to what the South East Asian modelers are producing.
I will be showing some progress, but it will be slow, unlike the 118 on the Mediterranean sea.
Yves
Edited by yvesvidal
corrected log title
  • The title was changed to WALLY Power 118 by yvesvidal - 1/48th - Multi-media
Yves - Quite something. I wonder what it is like inside.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I am trying to work on one hull module at a time. It simplifies the operations and allow me to be more comfortable, since the fully assembled hull is quite long and wide. The bow module houses a tender which is not correct in the provided CGTrader STL set of files. The 118 uses an inflatable tender with a solid base for the wheel and the seats. The length of the original tender is 4.50 meters.
A small crane located in the bow, allows the extraction of the tender from inside the hull, all the way to the water. The reverse is also happening. The main deck on the bow is lifting up to allow the extraction of the tender, thanks to 3 hydraulic lifts.
wally-power-118-3d-model-animated-max-obj-mtl-3ds-fbx-3.thumb.jpg.70be28cc0487258738540bcc28239219.jpg
The video below (left bottom image) provides an animation of the tender extraction. We will refer to that short video to show some of the very advanced features of that vessel.
My implementation will be much simpler and I will just install the tender inside and provide a magnetic lifting of the bow deck, to allow the display of the tender (and perhaps the crane).
Yves
Edited by yvesvidal
Great subject, but quite a challenge at that scale!
I assume you've seen this site and the rather rough drawing contains.
https://www.granturismoevents.com/story-wallypower-118-the-coolest-luxury-yacht-in-the-world/
The site mentions 3.5t of fuel per hour for the gas turbine, that would make the bill "only" around $3500 per hour at regular MGO prices.
Edited by Javelin
Roel
She is quite something in a Star Wars sort of way. I think I am going to enjoy this.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
You are correct Javelin, and I have corrected my original post to $4,000 per hour in kerosene. I feel better and can now envision longer trips...:-)
Yves
I am now working on the second module and after cutting a large opening in the middle, I have glued it to the bow:
The very sharp and aggressive shape of the hull, can already be felt. To move at 60 knots on the water, you really need that.
The third module is also prepared as the opening will protrude into it, as well (See below):
Using Tinkercad (I am no expert in designing my printing parts), I created a long window that would fit and provide some transparency, as the prototype is equipped:
For the first time, I am using PETG filament (versus the PLA used to make the hull parts) in green translucent color. On the ENDER 3v2, the bed should be heated at 85 C and the nozzle at 220 C for a decent result. Printing speed is reduced to 50% to allow for a good adhesion with the build plate. PLA uses 60 C and 200 C respectively.
Yves
The connection with the third module is done:
Besides the slot for the deck window, the third module does not require much in term of modifications.
Below, you can see some dim light peeking through the green windows of the deck:
Elegance of the hull:
I am curious to see how the planking will look on the deck. Thus, using basswood strips of 3.0 x 1.5 mm and polystyrene strips of 025 x 1.5 mm , I am starting the delicate planking. The caulking is made in white on the original yacht.
Again, using TinkerCad, I am creating two wedges to compensate for the incorrectly angled seat backrests around the dining area. These two wedges will be covered by planks. It is a constant struggle to make this hull work with the real prototype.
I am also printing some cushions that will be used around the dining area:
And that is where we are today:
I hope you enjoy this model.
Yves
Edited by yvesvidal
I continue to be facinated Yves. Great progress.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I finally finished working on the last section of the hull, the stern.
The water jet system will come later, as I am studying the real vessel and how to replicate them. Here is a crude shot of the full hull:
Another point that needs some modifications is the tip of the bow. On the printed model, this section is too small and needs to be extended. You may recall Luca Bassani taking a nap and sitting on the bow:
GwSHyyZRYqzNv4xOX9gL_luca-bassani-portrait.thumb.webp.30534abe764985115b14feadd5a91e9e.webp
Xhx8ZkgdTjqFLDokz59M_luca-bassani-on-bow-of-wally.thumb.jpg.2f92b3e68a82d9c21719569b6d065e38.jpg
I will fill up that area, so it looks more extended.
Another very disturbing lack on this printed model, is the absence of the beautiful and integrated railings all along the hull (see below):
Using strips of styrene, I have decided to try to replicate them in some ways. I use a small 4 x 0.75 mm spacer strip glued to a 1 x 8 mm strip. The opening is about 45 mm (in scale 1/1) which should correspond to that groove for your fingers on the real yacht.
These are little details that will hopefully, enhance that very crude 3D printed model. Stay tuned....
Yves
Edited by yvesvidal
I finished the building of the handrails, along the hull. This was done with styrene strips as described in the previous post.
The model almost looks like the real thing.... 🙂
I increased the area of the bow, by filling up about 2 additional centimeters:
The railing is not too bad and should give the illusion, once painted like the hull:
At the stern, the railing goes all the way to the boarding deck. The flat pieces are the covers for the winches used most of the times, on the Mediterranean sea (Med mooring).
There are still some minor details and a lot of sanding to add to the hull, but it will be ready for a first coat of primer soon. Now, we need some better weather....not 29-32 degrees F.
Yves
  • The title was changed to WALLY Power 118 by Yves Vidal - 1/48th - (Wood, Styrene, PLA)
