Continuation
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Final version of a deck flooring. After assembly the space is lower than flooring boards from three parties (except a board) will be closed by decorative levels.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
 Board, imitation of nails.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
The "facade" covered with one layer of OSMO (that it wasn't soiled in the course of assembly).
Best regards,
Garward
Continuation
The internal covering of a board covered with one layer of OSMO.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Decorative frame (the beech, is a little pigment, 1 layer of OSMO; legs - a black hornbeam).
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Intermediate assembly.
Best regards,
Garward
Continuation
Cannon accessories.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
I decided to redo decorative registration, the beechen frame me doesn't impress something. In new option it is the wooden plate covered with a pink pear on which the art post (assembly "on dry", a plate while without a covering is shown) is established.
Best regards,
Garward
Continuation
Best regards,
Garward
Options of decorative registration of an artillery post various modellers.
Best regards,
Garward
Continuation
Production of buckets tubs (levels from a pear are cut off on a wedge on FET jig save, are covered with a black pigment, are stuck together in the cylinder on an axis from a round timber with a diameter of 6 mm; the cylinder is pierced on a cone 18 x 21 mm высотой25 by mm and drilled).
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Production of ropes for brake (diameter of 2,5 mm, strings of Gutermann Tera 30, Col. 131, 3 strands on 10 threads) and roofing felts (diameter of 1,07 mm, strings of Gutermann Tera 60, Col. 131, 3 strands on 6 threads).
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Service of ropes for  blocks (a string of Gutermann Skala 200, Col. 464).
Best regards,
Garward
Garward Beautiful rope work. could you explain how your rope walk works?.
Michael
