This will be my first attempt in planking a hull the right way. My frame pieces are already glued on and I have the bottom of the keel in a jig. My problem is the top of the keel is still warped and I'm not sure of how I should correct it without putting on some planks. That seems like the most difficult solution. Is there an easier way then making a complicated jig for the top of the keel?
Hi Ed, if your keel is crooked, it can cause countless problems later with the rest of your build. If your kit is Model Shipways, I recommend ordering free replacement parts from the company & starting over. If it's another company perhaps you can post pics so that others can asses how bad it is and etc.
Cheers,
Jay
Current Build:  Ariel
Its not Model Shipways so I have to fix it. I made sure that the ribs are square with the keel. I just have to straighten the keel on top so I can plank it.
Hi Ed
I know the majority will say strip down straighten and then reassemble.I would be tempted to try a couple of things first.Can the deck not be temporarily be pinned in place to straighten the keel out?Failing that you could get a piece of timber and cut notches out to clear the bulkheads.This could be slotted on from the top and clamped or bolted to the side of the keel.I would go for bolting as clamping my restrict space for planking.This could be removed after you have got as far down as is possible with the outer planking.
Kind Regards Nigel
Currently working on Royal Caroline
Another thing you can do is to straighten out your keel and fill inbetween the bulkheads.  Take your measurements from the slots and cut out blanks that are at a right angle and fit them into the bulkheads.  This should the job.
David B
Ed,
Just a different take on the stiffening/straightening strip -
Flip your carcass over and take a rigid strip at least as long as your keel. Temporarily tack the strip at the bow of your keel. Continue aft along this strip straightening and tacking the warped keel as you move towards the stern. This will keep it straight and not impede any planking. Once you've got the strip on you can also add some blocking between bulk heads to take some of the stress off the assembly.
Sam
ABSOLUTELY NOTHING UNDER DEVELOPMENT
Ed.
  Congrats on straightening your keel.  Now if you just fill in the spaces you will not have to worry about your model warping during the planking process.
David B
Hi Shipmates.
Now this is what MSW is all about.
Someone in need of help with ther model ship. And asks for advice.
Lots of good and valid suggestions come forward from members with expearance and thought.
A fix is found :)
And a happy modeller.
Well done MSW and to all it's members.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
