I consider this to be a pretty awesome modern shot of Constitution, its very high resolution and shows a lot of detail. Scanning the rigging I saw something odd and I wonder if any of you Constitution modelers have an opinion: There is an odd bit of tackle on the after side of all the Tops, it looks like lines Port and Starboard are led from ringbolts on the after lower sides of the caps down to the after outboard edge of the tops. A means of keeping the tops from sagging? I would assume all that timber up there is newish and in good shape. I don’t think those lines run to the deck as backstays of some sort, at least the Starboard one on the Mizen is viewed clearly against the white paint and doesn’t run to the deck.
Also I note the flag hoist appears to say N A P J and I wonder what that means.
here is the link to the photo:   http://www.navy.mil/management/photodb/photos/120819-N-BJ178-330.jpg
Edited by JerseyCity Frankie
Quote
 Niagara USS Constitution
Great pic and interesting question, but to be honest, I can't tell exactly where the lines run, are you sure they don't go down?
Tom
Current: Sergal Sovereign of the Seas
Previous builds:  AL Swift, AL King of the Mississippi, Mamoli Roter Lowe, Amati Chinese Junk, Caesar, Mamoli USS Constitution, Mantua HMS Victory, Panart San Felipe, Mantua Sergal Soleil Royal
Sorry, can't tell for sure.
Tom
They look like they might be truss tackles.  The pendant clearly goes through the lubbers hole.  But, I can not tell if the tackle belays in the top.
Edited by popeye2sea
Henry
Laissez le bon temps rouler !
Went by the ship today and took a couple of photos.  Those are truss tackles for the lower yards.  From top to bottom in the photo:
1: Truss tackle
2. Truss pendant
3. Truss tackle fall (belays on deck aft of mast)
I could not get aboard to check exactly where this belays.
BTW:  The signal flags NAPJ are the ships call sign.  A unique radio signal identifier for all vessels and/or broadcast stations. All US Naval vessels call signs start with N.  Civilian radio stations west of the Mississippi start with K and those east of the Mississippi start with W.  US Army and Air Force start with A
Henry
Thanks for the detective work Popeye2sea! I'm also glad my theory that they were holding up the edge of the top was wrong, I would hate to think she would be so floppy. Brushing up on Truss Pendants in Lees Masting and Rigging I see he has them led upwards into the top rather than down to the deck under the cap starting around 1830. Prior to that date they were hung from the trestle trees and after 1840 they went back to the trestle trees and became chain too so I guess they rigged Constitution to that 1830's era, going by the Truss Pendants anyway.
Quote
Popeye2sea did it again.
The truss tackles (P and S) seem a bit awkward at first glance, but they serve a good purpose (holding the jack close to the mast). When I came to this part on my Conny I debated about adding them, but a closer look at their purpose made me go ahead and add those lines, blocks, etc.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
