good afternoon
Been getting my knickers in a twist about purchasing my new build from Lumber yard
I appreciate that I will need extra timber to do the extra bits I need, like decking and internal planking and panelling, mast's etc
I have found a supplier in the uk, my question is, can I use it after being processed through a thicknesser and bandsaw
perhaps it sounds a stooped question, but the costs from the states are high
www.yandles.co.uk/bowl-blank-shop/c907
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
to purchase these exotic in billets of spindles and bowl blanks as woods to complete, saw, and mill to complete the timber work that is not included in the lumber pack,
This company is very close to me and the question was - could I use these, sorry I badly worded the original question
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hi Kevin.
Have you closer to home ?
Timbersource Ltd, Marston Park, Tytherington, Frome, Somerset BA11 5BS
http://www.timbersource.co.uk/
Hint.. Go there and have a chat to them.
They will cut timber down to size and there range is quite good.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
With a proper band saw and a thickness sander, you should be able to provide yourself with all of your timber needs from normal stock lumber or what you can harvest in the wild.  The wood from the supplier in your link seems to be really expensive.  Is there a hardwood supplier near you who sells to furniture makers?  Or better, a wholesaler?
The bowl blanks will not help you. Of the self select, only the cherry (Prunus serotina), maple (if sugar/rock Acer saccharum), sycamore (if English -not our Buttonwood/Planetree Platanus occidentalis) and steamed pear.  The steamed pear would rate as Swiss pear and is the only one that I think would be worth anything like those prices.
You want clear, straight grained, no pore, as little contrast in grain as possible. These are not characteristics of interest to wood turners and exotic furniture makers.  Find a supplier of banal looking wood.  Think about using wood dyes (not stains) on light colored wood for contrast rather than exotic tropicals which often have contrasting grain and open pores.
If you are going to pay prices like those, you need a good quality band saw blade.
http://www.highlandwoodworking.com/woodslicer12resawbandsawblades705to137.aspx?utm_source=iContact&utm_medium=email&utm_campaign=Wood%20News&utm_content=THW+5
This blade is excellent steel, thinner than most with not much set, so the kerf is less and the finish is close to planner smooth.  Only use it for resawing.  I have it in my mind that this product is made from material made in France.  I cannot verify that, but you may find it in a local product and not have to import it.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Were I you and had the ability to mill, re-saw, sand or plane to thickness, I would be down there looking at billets and blanks to find out what they had and in what form. You probably could find and use a local tree service outfit to obtain some limbs or small trunks of local wood. The wood the bowl makers have is probably seasoned, the tree service wood would not, but you could do that yourself. Take the time to look around and see what is available, bet there is something local you could find in abundance that would work well for you.
jud
  • 4 years later...
