I've notice it seems on some small ships, such as 6th rate ships, they forgo the belaying pins and jeer bits pin racks for varies ropes and instead opt for a similar set up with cleats seized to the shrouds.  Would I be correct in saying that the seized cleats on shrouds function just as the belaying pins?  If so, what ropes would be exclusively secured to the jeer bits?  The halyards?  The clews?  The lifts?
If this is the case, when the ropes are secured to the cleats seized to the shrouds, are they secured by simply coiling the ropes and using the end of the rope to secure the coil to the shroud?
Thanks!
do these pics help at all? Taken aboard the Endeavour replica.
Edited by hornet
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Yes it does.  Perfect.  Thank you!  I'm guessing the less weighed down ropes such as the sheets and clews went to the shroud cleats, but what ropes went to the jeer bits?  I'm assuming the halyards went to the jeer bits.
Edited by timboat
  • 4 months later...
I'm not that knowledgeable about shroud cleats. What lines actually went to them? Was this common? I've never seen a kit or instructions have them. Would like to learn more about this if anyone has any info. info on this.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Halyards and sheets from topsails would go to the jeer bitts, clews, buntlines and leech lines would go to the shroud cleats or pins next to shrouds if fitted. Shroud cleats were used on ships to clear the deck area for the use of guns and if there wasn't much deck space etc on a merchant ship. A pin rail built up on the bulwark where the shrouds are take up a lot of space.
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Not only small ships had this, even to be seen on the Victory.
+Cheers, Daniel
