I have been experimenting with making filler, HobbyLite in this case, firmer so a good corner or edge can be
shaped  I have mixed various strengths of Tile Bond II to the filler in small amounts to make a thick paste.  Even full strength works and makes a very solid mass when dried which is easy to sand or file. Adhesion to wood also seems to improve.  Painting is no problem, but have not tried stains.
I have used a filler called plastibond (2 part) I was successfully able to mix a stain (Feast Watson) into the filler before applying it. The results were quite good.
Hornet
             Current build HMS Granado - Caldercraft
             Completed Ship Builds. - USRC Harriet Lane - Model Expo.
             Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Tuff, you just described most bottled sanding sealers. No reason they couldn't also double up as filler. I like it!
Ken
Started: MS Bounty Longboat,
I have mixed Wood Glue and Elmers Wood Filler for a stronger bond - it works well, but will not stain propperly.
Ulrich
The wood glue prevents staining, essentially sealing the wood. If you want stained wood, do it before doing any glue ups. You may have to apply pre-conditioner, especially before staining basswood.
Ken
Polyester car body filler?
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Is that stainable? I've used the red stuff on plastic, works well. But, it was getting painted after it dried and sanded. Painted up well..
Ken
Resin fillers like car body fillers wont be stainable because they are impervious and not meant to be finished in the way.
Norman
Norman
